Im thinking that a traditional style, in block, thermostat(and housing) from a b5 or gti could be used with some modifying to our system (since its used on the b5s). only major changes would be deleting the dreaded J-plug and installing the short loop coolant pipe from a b5 and plumbing it in(in place of the J-plug) and then getting the radiator outlet connected to the thermostat inlet and plugging the now open line on the coolant crossover pipe. (ill be build a new one without it)
this would greatly simplify the coolant system while being able to run a cooler thermostat, 87C even... that is a drastic drop in temp, which really is the main reason Ive been pondering this.
SO, has anyone done this before? or am I crazy thinking I could use a metal thermostat housing, mishimoto 87C thermostat for a gti, b5 short loop coolant thermostat bypass pipe, and b5 lower radiator hose (or cut the bs connection off the b6 and use it)
only downsides I can see would be, thermostat housing might point at the dip stick tube (using the metal gti one) and not having heat as soon in the cabin
Thoughts? opinions? anyone know why 100c on the b6? anyone got a b5 lower radiator hose theyll part with?
will be ordering the parts to attempt this soon.
