Results 1 to 9 of 9
    Veteran Member Four Rings e.Mills's Avatar
    Aug 17 2007
    Park City, UT
    2010 Q5 vs 2011 Q5... donde das AMI plug?!
    I am probably an idiot, but my 2010 Q5 does not have an AMI port in the glove box like our 2011 does. I really want to run Tune2Air in both vehicles. The 2010 has an aux port plug-in in the center console.
    Is there an AMI port somewhere else that I am missing?
    Utah drivers.
    May 12 2011
    Norway
    its located in the glove department, right side.
    You might not have it, but it can be retrofitted
    Aug 17 2007
    Park City, UT
    Thanks! if it's not in the glove compartment - is there a port anywhere else that you could access it? or, do you have to pull the head unit?
    Utah drivers.
    Senior Member Two Rings redeye_jedi's Avatar
    Dec 12 2015
    Sk8teboard, Audi B8 A4 Quattro stg2
    It in the glove compartment on my 2010 B8 A4...
    / AUDI A3/8V Quattro / 034 Motorsports Stg1 ECU/TCU/ ST's /
    18” Split 5’s / 235/40/18 conti’s
    / AUDI B8 A4 stg2 / kw’s, sway bars, intake / 19” Black Peelers /
    / 245/35/19 Federal’s /
    May 12 2011
    Norway
    Aug 17 2007
    Park City, UT
    Quote Originally Posted by hc_TK View Post
    Yep. That's exactly where my AMI plug is in my 2011. For my 2010, I don't have a cutout for the AMI plug, but rather I have a 3.5MM jack input in my center console. Wondering if there's a point in the rear, or are on the side, that's easily accessible that I can plug in a connector.
    Utah drivers.
    Mar 01 2017
    Northplainfield
    Quote Originally Posted by e.Mills View Post
    Same here my glove box doesn't have one for my 2009 b8 but I have the aux in the center console too
    May 12 2011
    Norway
    Aug 17 2007
    Park City, UT
    Yeah, if it's going to cost that much I'll continue using a 3rd party 3.5mm Bluetooth Receiver. Thanks, though! Now I know what plugs I am looking for in the back.
    Utah drivers.
