Results 1 to 38 of 38
    Established Member Two Rings DAYTA's Avatar
    Dec 30 2014
    TT-RS steering wheel...will it fit?
    I'm thinking about picking up a TT-RS steering wheel to replace my OEM one. Can anyone confirm that it would be a direct plug-n-play scenario?
    I want to make sure it will mount up fine with no adapters and that all steering wheel controls will function correctly.
    Daily Driver: 2016 VW Golf R
    Family Hauler: 2018 BMW X5 xDrive35i
    Weekend Toy: 1997 NSX
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    Yes!
    Jul 11 2016
    Mississauga
    Did the same mod for my car. absolutely love it! I required some modification for my airbag harness as it was being used in a B8 S4 before. But yes all buttons work.
    Mar 11 2008
    B7RS4 & e46Ms
    OP, call Alex@Europrice
    FRRG AZ Ring
    Dec 05 2006
    So. Cal.
    ^Your car looks so furry.
    Wondering if Dallas Custom could recover my Flat Bottom Rs wheel in Alcantara?
    Established Member Two Rings tweak419's Avatar
    Aug 04 2015
    2010 Chrysler Town and Country
    Chicago
    Is the TTRS wheel a smaller diameter like the euro flat bottom? It looks like it's a similar diameter to the US oem wheel to me. Or is that just an optical delusion
    Mar 11 2008
    B7RS4 & e46Ms
    I know, right!?
    I've heard nothing but good things about their work. Have them throw in a 12 o'clock ring in their while they're at it.
    FRRG AZ Ring
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    Do it
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Dec 30 2014
    It's done! Steering wheel should be sent out by next week. Pretty excited about it!
    Question - how hard is it to change the badge on the bottom of the steering wheel? I'm not sure I'll care too much since it'll at least say "RS" on it, but if isn't too difficult or expensive, I may do it.
    Senior Member Three Rings 2008s4's Avatar
    Oct 28 2016
    Central, CT
    Where did you get yours from?
    Is it weird I like the solid leather on the top and bottom of the S wheel more than the air leather in the same locations of the RS wheel?
    2008 S4 Brilliant Red (sold) | 2008 RS4 Daytona Grey (sold)
    2008 A4 2.0 Avant (sold) | 2016 S4 Misano Red (sold)
    2014 MB E63s Wagon Eurocharged | 2015 Q5 3.0 034 Stg 1
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Which colour Alcantara is your trim as I have a tough time finding completely black Alcantara... or is it grey(ish)?
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by ven0m View Post
    It's black, it just washes out with the light.
    FRRG AZ Ring
    Jul 11 2015
    Los Angeles, CA
    Just installed tonight. Looks and feels great and compliments well with 2010+ RNS-E(it should since they're both out of a TTRS)
    | 07 Daytona Gray RS4 - SOLD |
    Feb 24 2010
    And have never been happier
    Whoa!!!! The Audi manual is still there!! Freaking awesome :)
    (little things in life)
    Switched to Tesla and have never been happier. No more shady mechanic bills and excuses - oil top off before an oil change is normal or dealing with outdated forums that have image size limitations. And no more dealing with vendors that do not provide horsepower numbers but sell you random things by labeling them as performance parts. No more dealing with the Audi dealership and having to buy custom Audi specific tools. Wow. I can't believe I lived through all of this. Money pit.
    Jul 11 2016
    Mississauga
    Quote Originally Posted by DAYTA View Post
    It's pretty easy. You just need plastic trim tools.
    Jul 11 2015
    Los Angeles, CA
    Yeah it's not hard at all. Use a plastic trim tool and pry it out. However, those badges are stupid expensive for what they are. Last I checked the RS badge was between $120-140 IIRC
    Dec 30 2014
    So my car is at Excelerate getting the wheel installed along with a few other things. They just called me saying the connector for the airbag is different from the one in the car, not good.
    I thought this whole setup was supposed to be plug n play, am I wrong? If it isn't, what adapter do I need to have the airbag fit?
    Dec 30 2014
    I found these two threads which I believe outlines what needs to get repinned/trimmed on the TT-RS airbag to have it work on the RS4 - can anyone confirm this is correct?
    https://www.audiworld.com/tech/int73.shtml
    http://www.audizine.com/forum/showth...1#post10514293
    I would really appreciate some help here as I'm currently driving with no airbag, horn, or steering wheel controls.
    Mar 11 2008
    B7RS4 & e46Ms
    Where did you buy it from? Or more specifically, did the wheel/airbag/harness come from a TTRS, or another RS4 owner that already had a modified airbag harness? Many of us bought our wheels plug-n-play from Europrice to avoid what you're dealing with now. As long as you've got your original RS4 airbag harness, the TTRS airbag harness, and you've got a good de-pinning tool/set, Re-pinning the airbag harness isn't difficult..swapping connectors is straight-forward as well.
    FRRG AZ Ring
    Dec 30 2014
    The wheel/airbag setup is brand new and for a TT-RS, bought from a member on Audizine. I was told by the seller it was plug-n-play as is from the factory, so I had no idea there was additional modifications needed.
    Based on the threads I found, it looks like I can use the harness from the TT-RS airbag once it is repinned and the tabs are trimmed? Or do I need to reuse the harness from my RS4 airbag?
    FYI - part number of airbag is 8J0 880 201 N 6PS.
    Dec 30 2014
    Quick update - dropped the car off with my guy at Audioworks in Milford, CT. He was able to repin the harness for me and install a revised interface to allow me to use the steering wheel controls with my Pioneer HU.
    Everything now functions: horn, airbag, and steering wheel controls. Definitely a worthwhile mod - love it!
    Veteran Member Four Rings mad70sx's Avatar
    Mar 12 2009
    Silver '04 S4
    North Central CT
    Hmmm.... DAYTA, you did this on an B7 RS4, correct? Any idea if the TTRS wheel can be adapted to a B6 S4?
    JHM Tune ~ JHM Intake Manifold ~ JHM Version 2 Headers ~ FI/JHM 2.5" Exhaust ~ JHM 40/60 Rear Diff ~ JHM LSD Rear Diff ~ KW V3 Coilovers ~ Porsche 18Z calipers ~ BBS CH
    Jun 11 2013
    Quote Originally Posted by mad70sx View Post
    Different airbag but you can swap your airbag in I believe
    Feb 15 2007
    The trim piece pops out from the back of the silver trim, which can only be done when the wheel is off the car. Here's my RS6 wheel from 2009 (still running it). I'm running a blank piece now.
    And a vinyl red stripe at 12 o'clock, because why not. lol
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Feb 17 2004
    Liberty Hill, TX
    physically yes, but the TT-RS airbag is dual stage, whereas the B6 uses a single-stage setup, and there's no single stage airbag that fits the TT-RS wheel. While some people have wired dual stage airbags to fire together as a single stage, there's no proof that this is safe or effective, and is generally discouraged.
    That said, I had a TT-RS wheel/airbag on my B6 A4, wired both stages together, and the airbag did deploy when I was in a front-end collision. But it was relatively low-speed and so I can't say if the inflation was correct to protect me in a more serious accident.
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Mar 12 2009
    Silver '04 S4
    North Central CT
    Quote Originally Posted by Matt Devo View Post
    Great info, thanks!
    Veteran Member Four Rings tjb616's Avatar
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    Bumping an old thread here. These wheels are getting easier to find but often without airbags.
    Does anyone have a P/N for the correct airbag to use in a B7 with this TTRS wheel? Or know specifically what cars they came in?
    B7 RS4 - Mugello, Wingbacks & Jackal
    B7 Avant S Line Ti 6mt - 2.7t & 770R
    B5 S4 - Santorin, EPL Stage III
    993 C2 "RS CS" Track Car
    964 C2 Coupe
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Quote Originally Posted by tjb616 View Post
    I have an airbag for the TTRS wheel if you’re looking
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    I used airbag Part No. 8J0 880 201 N 6PS with my TT-RS wheel and it had the silver ring on the cover instead of black.
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Oct 03 2011
    Buffalo
    Anyone know if A8 airbags work?
    Aug 02 2015
    Corning NY
    Quote Originally Posted by Rilla View Post
    No they don’t. Bigger diameter on the A8 bag
    Feb 17 2004
    Liberty Hill, TX
    only fits the Euro RS4 wheel, not the TT/TTs/TT-RS wheels
    Oct 03 2011
    Buffalo
    Ah, too bad, it is way cheaper!
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    B7 Euro RS4 and MK2 TT-S airbags aren’t interchangeable?
    964 C2 Coupe
    Feb 17 2004
    Liberty Hill, TX
    correct
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    correct
    Well that sucks. I just bought an RS4 Wheel + Airbag and a TTRS Wheel, and was leaning towards selling the RS4 wheel. Guess I'll have to buy another airbag if that's the case.
    964 C2 Coupe
    Jun 30 2016
    NNJ
    Hey, does anybody know what part number I would need for the RS4 badge that would fit a TTRS steering wheel? It looks like a b8 one would fit but I'm not sure.
    Veteran Member Four Rings rnlabas's Avatar
    Dec 01 2009
    Exclusive (1 of 1) TT RS, e-tron GT, C8 Allroad 20th, RS 4 Cab
    Upstate SC
    Quote Originally Posted by MadMaxD View Post
    8D0419685A - ~$60 ebay ...
    - Roger
