Results 1 to 12 of 12
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Throttle body gasket replacement
    Hello!
    I ran a boost leak test and found my throttle body gasket is leaking heavy.
    I ordered the gasket and replacement bolts which I should have on Friday.
    My question is this a straight forward gasket change? Do I need any type of gasket sealer besides the gasket itself? Is there any special install instructions I should know about?
    Besides all the bolts being stripped already I'm hoping there isn't much more to the change.
    Oct 11 2016
    Connecticut
    Sep 09 2014
    Grand Rapids, Michigan
    Just clean it well
    Oct 11 2016
    Connecticut
    Quote Originally Posted by Trb1 View Post
    Just clean it well
    Alright!
    Thanks I'll be sure to.
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    you may also want to do an alignment with vcds once your done and its cleaned.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Be careful tightening them up. The threads in the mani are soft and can pull out.
    Most of the time bolts that size would be 10nm (90inlb), but that is right at the point the threads pull out of the mani so go a little easier on them.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Oct 11 2016
    Connecticut
    Thank Blitz I read about that and will add that to the list.
    And thanks Zillarob, that is a very important note to make on this job. I'll make sure to be gentle. Hopefully they won't already be stripped inside considering the heads are toast.
    Aug 24 2014
    Newport Beach, CA
    Those bolts holding the TB on can be pretty stuck if they've never been removed, just be very careful trying to crack them free.
    2024 M3 Comp xDrive
    Oct 11 2016
    Connecticut
    Parts arrived. Finally.
    Made a discovery when I pulled the stripped throttle body bolts out.
    The bolts used that I removed are longer than the bolts I picked up at Audi.
    After some measurements and a test installation it's no wonder that throttle body was leaking all this time.
    Aug 06 2008
    Canadia
    Wow, way to make a mountain out of a mole hill...
    Oct 11 2016
    Connecticut
    Quote Originally Posted by MacDaddy View Post
    Indeed...
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Crazy stuff.
