Results 1 to 40 of 51
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Updated and detailed rear tail light coding table (with pictures)
    I spent several hours tonight farting around with tail light coding options, after having very successful results on my previous A4 Avant. I found a semi-complete table on AW, but its custom column wasn't correct, so I went through and made everything correct. I also added binary codes to hopefully figure out what options are being turned on/off with the decimal codings.
    Not pictured are the side markers lights. The are off by default, and will flash in unison with the turn signal only. Pretty cool IMO.
    Coding table
    Tail lights at idle:
    Brake lights (running lights are off from here on out)
    Signaling:
    Signal interim while braking:
    Signal while braking:
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Established Member Four Rings limeypride's Avatar
    Mar 18 2017
    Snohomish
    Quote Originally Posted by GilliamOS View Post
    Nicely done and thanks for posting the hard work!
    2018 ////AMG E63S in Diamond White/Nut Brown, lowered 20mm front/back, spacers, tints, EuroCharged tune
    Gone but never forgotten
    2017//RS7 Performance in Mythos Black, Audi exclusive Titanium edition w/ Akrapovic exhaust
    Senior Member Three Rings ClaudeG's Avatar
    May 27 2017
    2023 Audi Q7 3.0 | Daily 2006 Mazda Speed6
    Santa Clarita
    SWEET! Good going man!
    I wonder if this will work on the 2017?
    2016 S6 Prestige, Sepang Blue, Black Optics, Lunar Silver Interior | APR Exhaust | VMR V802 Matte Bronze wrapped in 275/35/20 | Silly Rabbit Intake | NeuSpeed SS Brake Lines | Lowered via OBDEleven | JL Audio XD7005V2 | JL Audio 10"W3
    GONE BUT NOT FORGOTTEN 2017 A6 3.0 Prestige, Brilliant Black, Black Optics
    Daily... 2006 MazdaSpeed6
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Quote Originally Posted by ClaudeG View Post
    I'll try them out in a few.. good stuff OP doubt it tho
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Aug 03 2014
    Queens
    No go for c7.5..
    If anybody has the stock code for c7.5 can you please send that over .. I think I forgot to save 1 or 2 stock codes.
    Inner tails don't light up with fog lights now lol
    Here is another table old table, op is updated though
    http://www.audizine.com/forum/showth...LIGHTS-DECODED
    I'll play around with my tails and see if I can get something for 7.5
    Previous
    Nov 13 2016
    Houston, TX
    *dumb question alert* is this for the stock tail lights? And where do we change these numbers?
    Also can you post a video with the signals and such? Thanks
    Sent from my SM-G955U using Tapatalk
    May 26 2015
    Mormon Country
    Quote Originally Posted by DGVR6 View Post
    No go for c7.5..
    I tried finding an old post on AZ first before I made a new post, I knew this wasn't brand new info. But I wasn't happy with that coding table and my car's PO did some weird stuff, so it was nice to find stock info and start fresh.
    Good to know this does not apply to the facelift model, hopefully you find stock values to go back.
    I will get a video up later today.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    May 26 2015
    Mormon Country
    Quote Originally Posted by mihneagabriel View Post
    Yes, stock lights. You will need VCDS or something like it. Go to Module 46 (Central Conv) > Enter the security code provided > Adaptations > start at channel 195, taking note of your original stock setting in case it differs from the chart. Hit test with each change, then save before moving onto the next channel. Takes just a few minutes to do.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    May 27 2017
    Santa Clarita
    No go for c7.5..
    DAMN! I hope you find the codes!
    I wasn't holding my breath for the 7.5 Hopefully someone decodes it at a later time.
    On a side note, too bad that none of the coding units, (Carista, VCDS offers a "back to stock" feature.)
    May 26 2015
    Mormon Country
    Quote Originally Posted by limeypride View Post
    I've been trying to develop a working IDE SSD replacement for our MMI too, and I am tantalizing close. Everything but Google Earth works so far. I am getting an MMI update in September, I am hoping that provides the fix I need.
    Interestingly, I have tried a variety of "standard grade" HDDs with complete success, so there is something about the SSDs that is just a tick off from regular HDDs.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Aug 11 2016
    CA
    I take a picture of the VCDS screen every time I make a change showing the original value and the new value. Great to have a picture of what it was.
    I actually wrote a manual for my A7 with instructions and pictures just in case I forgot years down the road. Came in handy when I needed to put everything back to stock for the trade in.
    Sep 28 2009
    suburb
    anyone done this on a a7/s7? anyone with pics of the changes on that car? thanks OP BTW!
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    May 26 2015
    Mormon Country
    Quote Originally Posted by flyfishing View Post
    Write down your original settings, try mine, see what happens? Worst case you have to go back to what you had. As long as you have your stock settings, this is a very safe mod to try and do.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Aug 03 2014
    Queens
    I took pictures of original.. not sure if I missed something or what
    Previous
    May 26 2015
    Mormon Country
    You have to hit save with each change to each channel, otherwise it goes back. Double check 195-210 that everything went back.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Aug 03 2014
    Queens
    I'll double check and make sure I hit save .. as long everything works without fogs on is really only my concern.
    Looks pretty cool if I can get the brake inner light to illuminate while braking with fogs and keep the outters as turns. I'll keep playing around with it and maybe if I can have that setup then I'll keep it.
    It would still be nice if we can get 7.5 coding table for EU and USA.
    Previous
    Dec 29 2016
    south
    OBDEleven has a history tab that notes all coding changes made to each control unit. It is not the most user friendly of interfaces but helped me out once already. You can also backup each control unit i.e. It will read all adaption channels and coding and store the data in a backup file. I haven't tried this yet, but I do see it as a feature.
    However, I agree, a "back to stock" feature would be great, especially if combined with a feature that would allow you to easily restore your modified settings.
    May 26 2015
    Mormon Country
    Quote Originally Posted by BigTex View Post
    Yeah, the PO of my car made several changes to modules that I wish had been put back to factory original. At least I'm advanced enough to know what I'm doing and how I want my car configured.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    May 26 2015
    Mormon Country
    Full video is up.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Oct 27 2013
    Using these instructions...
    MODULE INVOLVED: COMFORT MODULE [46]
    SECURITY CODE: 16017
    CHANNELS RESPONSIBLE FOR THE TAIL LIGHTS CODING: 195 - 210
    Not sure if I'm doing this right but using my vagcom software I opened the module and took pictures starting at channel 195...
    (2016 S6 as far as I know this is unmodified)
    195 = 9
    196 = 41
    197 = 20488
    198 = 20520
    199 = 134
    200 = 166
    201 = 6
    202 = 38
    203 = 20615
    204 = 20647
    205 = 13
    206 = 45
    207 = 51201
    208 = 51233
    209 = 0
    210 = 32
    211 = 51214
    212 = 51215
    213 = 12615
    214 = 3
    May 26 2015
    Mormon Country
    Oh nice! I'll break it down into binary and compare to the preface lift USA chart.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Jun 14 2009
    GA
    If you're referring to K0942, LMK. I have that if you'd like to update yourself.
    2018 IA6 3.0T Sport | Glacier White Metallic | Black Optics | Carbon Atlas | XPEL PPF | Gyeon Quartz
    Gone, but not forgotten:
    2014 A6 P+ Quattro, Quartz Grey Metallic
    2010 A4 P- 2.0T Quattro 6MT, Quartz Grey Metallic
    2007 A4 S line 2.0T 6MT, Phantom Black Pearl
    Nov 13 2016
    Houston, TX
    Full video is up.
    [DROOL] that is sick! I'm going to do that when I get back into the country. Thanks for the information!!
    May 26 2015
    Mormon Country
    Quote Originally Posted by magn2o View Post
    Thanks. I got the dealer to agree to update my MMI and nav maps as part of the purchase agreement. The 2018 update comes out in September.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Aug 03 2014
    Queens
    Quote Originally Posted by ryanlada View Post
    195 = 9
    196 = 41
    197 = 20488
    198 = 20520
    199 = 134
    200 = 166
    201 = 6
    202 = 38
    203 = 20615
    204 = 20647
    205 = 13
    206 = 45
    207 = 51201
    208 = 51233
    209 = 0
    210 = 32
    211 = 51214
    212 = 51215
    213 = 12615
    214 = 3
    Thanks
    Weird all my values are the same .. still no inner brakes or turns while fog on.
    190 = 4
    191 = 65535
    192 = 3
    193 = 6
    194 = 7
    Previous
    Aug 03 2014
    Queens
    Never mind, got them to work.. messing with the tails lights threw a fault code I didn't clear.. all good
    Had the fogs coded as turns too which was pretty cool. Brakes didn't activate fogs but turns activated and flash with the signal lol
    Previous
    May 03 2011
    El Paso, TX
    When i do the europe coding as per the table, i can only get the inner turn signal to flash, the outer taillight does not go as do the europe audis. Any clue as to what I'm doing wrong?
    2012 A6 Prestige| Brilliant Black| APR Stage 1 | Bilstein B12 | Eurocode Sways
    Aug 03 2014
    Queens
    Quote Originally Posted by eveleth View Post
    Are you trying this on your a4?
    Previous
    May 03 2011
    El Paso, TX
    Haha no I have a 2012 a6, just too lazy to
    Update my signature
    May 03 2011
    El Paso, TX
    In the meantime I did my coding like the OP, however I would like to test out the German coding to see which one I like better.
    Veteran Member Three Rings RRF985's Avatar
    Apr 12 2014
    Atlanta, GA
    Please let us know if you get this figured out. I'm going to start working on mine tomorrow I think. I'd like to have it set up like Germany as well if possible.
    2017 VW GTI 6MT Autobahn
    2012 A6 3.0T P+ | Oolong | Black | Black Headliner | Sport | Side Assist | Cold Weather (sold)
    Oct 22 2014
    Atlanta, GA
    Coding table
    Thank you for sharing the results of your work!
    I recreated your table with formulas to convert binary to decimal and notice that the bottom values listed for Germany don't match between decimal and binary.
    The binary values for 12 and 44 should be:
    12 00001100
    44 00101100
    The binary values given would correspond to the USA values:
    51219 1100100000010011
    51251 1100100000110011
    Not sure which was accurate. :)
    Here's the Google Doc I created, if anyone wants to use it: C7 Taillight Coding
    Oct 22 2014
    Atlanta, GA
    Interesting... my A7 has different coding.
    I changed the "Turn Signal + Brake" settings to match the Germany settings and like that. I will have to do some more testing.
    German coding example starts at :50
    Apr 12 2014
    Atlanta, GA
    Quote Originally Posted by SpectreGadget View Post
    Great job! I will have time to work on this tomorrow. I very much look forward to this.
    Apr 12 2014
    Atlanta, GA
    I did the coding on my lights today. I went a little different route with the combination of German and US coding. I still wanted the full light ring when braking because imo, your brake lights can never be too bright with how people are distracted these days. I'm very happy with the results.
    Sep 28 2009
    suburb
    Quote Originally Posted by RRF985 View Post
    Can you post your combo please? Thank you very much
    Audi SQ7
    Audi B8 S5 (gone)
    Apr 12 2014
    Atlanta, GA
    I'm away from my car until Monday so I'll get back to you on this. I was trying to remember from memory but I made too many changes back and forth to remember what I landed on ultimate. I'll post my settings when I get home.
    May 26 2015
    Mormon Country
    Nice job. I played with that combo too before settling on what I have now. One nice perk about open info is you are free do do what you want!
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Feb 25 2010
    magimmeMVE
    Usa
    Anyonetell me what i need to change channels 205 & 206 to in order to turn off the bulb monitoring as i have fitted leds.
    Sep 28 2009
    suburb
    Thanks so much!!
    Audi SQ7
    Audi B8 S5 (gone)
