Results 1 to 13 of 13
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    What oil are people using?
    Saw this kit on ECS (https://www.ecstuning.com/b-assemble...e-kit/2332kt7/) that seemed like a good deal.
    Doing the first oil change soon, wanna make sure I'm putting in the best oil for my B8.5
    Mann or OEM Audi should be fine for the filter right? Also do people change the oil drain plug every oil change?
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    Check with the dealer in your area which oil they recommend 5W30 or 40. Mostly gonna be 40.
    Filter Mann is good, I use it always. And the drain plug is recommended to replace and it's really cheap but still you can reuse it once in my opinion.
    What's matter is the crush washer have to be New.
    Established Member Two Rings alvintoro01's Avatar
    Mar 26 2016
    Georgia
    I've always used Penzoil Full synthetic 5w30. And oil filter not that picky honetsly usually bosch premium, they didn't have it this time so I went with Castrol premium oil filter. The drain plug I've never heard about replacing it every oil change. I've never replaced mine, doesn't leak, does its job to drain the oil.... Idk why you'd need to replace it?
    Sent from my SM-G955U using Tapatalk
    Mar 12 2016
    The land of Kiwis
    Drain plug cost is below $2 , why not to replace it and be sure you will not have a leak.
    Active Member Two Rings ChambazNY13's Avatar
    Apr 29 2017
    Margate FL
    I have always used Mobile 1 5w30 but I would recommend any full synthetic oil for any car. Last time I changed the drain plug was when I changed the oil pan itself other than that if it's not leaking I am cool with ir
    Sent from my SM-G950U using Audizine mobile app
    TSEuroTech 2006 Audi A3 FSI
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    this is the list of oils for the 2.0T recommended by audi
    OIL
    VW 502 00
    Preferred- SAE 5W40
    Acceptable- SAE 5W-30 or SAE 0W-40
    Mobil Mobil 1 SAE 0W-40
    Mobil Mobil Syst S Special V SAE 5W-30
    i use magnetic drain plugs everywhere (diff, too).
    just change the crush washer with each use.
    oil changes every 5k or once/year
    ocd.......?
    yes, but cheap insurance....
    while syn oil does not break down as fast, it is not immune from dirt & contaminates or aging......
    filters.....Mann or Mahle, only
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
    Apr 29 2017
    Margate FL
    Quote Originally Posted by wkhanna View Post
    OIL
    VW 502 00
    Preferred-SAE 5W40
    Acceptable-SAE 5W-30 or SAE 0W-40
    ocd.......?
    Magnet drain plug. I must look for one.
    May 12 2017
    Quote Originally Posted by ChambazNY13 View Post
    LINK for ecs part.....but i am sure others carry them, too.....
    Billy
    Avatar Chart
    Aug 06 2017
    Central AL
    Any reason you guys don't use a vacuum to remove the oil? I'm coming from the Benz world where the recommended method to remove the oil is through the dipstick... Are there parts of the pan that would hold oil with this method?
    Active Member One Ring kehubbard's Avatar
    Feb 05 2017
    2012 Audi A4 2011 Honda Pilot
    Sycamore, IL USA
    I have never used a vacuum system to change oil but have recently started thinking about buying and trying one. The convenience is attractive to me but honestly I would probably still drop the drain plug every other oil change. Call me old school.... Oh and when I do change oil I use Mobil 1 0-40 and a Mann filter every 5000 miles.
    May 12 2017
    Quote Originally Posted by kehubbard View Post
    ................ Call me old school.... Oh and when I do change oil I use Mobil 1 0-40 and a Mann filter every 5000 miles.
    THIS
    Billy
    Avatar Chart
    Active Member One Ring StealthyQ's Avatar
    Jul 28 2017
    Texas
    I recently got a Mityvac to change the oil in my Q5 2.0T and it works well. Saves me time and seems to get most if not all the oil out. I also vacuum out whatever oil is left where the oil filter goes before replacing it. I've used Mobil 1 0w-40 European Formula, and German made Castrol Edge 0w-40 European Formula, both with LiquiMoly MOS2 additive and have had good luck with both. Always use OEM filters.
    Jun 05 2017
    Norfolk, VA
    My next oil change I plan on putting in that new Molygen oil that's being advertised by ECS, the one that's green and glows under a black light for ease of finding leaks. I will also be installing a Mann filter for the change.
    S4 B8 3.0T, Silver: Current - Sports Diff. APR Stage 1
    A4 B8 2.0T, Silver: SOLD - APR: Stage 2
