This is from the manual....
3.2.1 Starter, Removing and Installing
Removing
– With the ignition switched off, disconnect the battery ground
cable. Refer to
⇒ “1.3 Battery, Disconnecting and Connecting”, page 14 .
– Remove the right engine mount. Refer to ⇒ Rep. Gr. 10 ;
Subframe Mount; Engine Mount, Removing and Installing .
– Remove the nut -1- and free up the ground cable on the engine
support.
– Loosen the catalytic converter. Refer to ⇒ 4-Cylinder Direct
Injection 1.8L; 2.0L 4V TFSI Engine (Generation II); Rep. Gr.
26 ; Emissions Control System; Catalytic Converter, Removing
and Installing .
– Remove the bolts -arrows- and the right engine support.
– Remove the bolt -1- for the cable holder -2-.
– Disconnect the connector -3- by sliding the retainer back and
pressing the release down.
– Disconnect the wire -2- from the starter.
– Remove the bolts -1- and -4- and remove the starter.
Note
-Item 1- can be reached from above.
Audi A4 2008 ➤
Electrical Equipment - Edition 02.2016
50 Rep.
edit: This link explains how to remove the mount.The pic links are broken but you can probably figure it out. There are 4 bolts holding the engine support bracket.
http://www.audizine.com/forum/showth...placement-2-0T
