Results 1 to 25 of 25
    Sep 01 2016
    Norway
    Exhaust tips S3 8V
    The tips are getting black and i cant get them to shine again. i have tried everything!!
    Is it possible to take them off? and where can i buy some new one?
    Established Member Two Rings S3owner's Avatar
    Jun 16 2016
    Ontario
    +1
    Sent from my STV100-1 using Audizine mobile app
    Missano Red II S3 Quattro 2.0T - H&R Sport Springs - Spacers 10mm/17.5mm - Sound Enhancing Resonator Delete - USmillWorks tow hook bracket - Pinalloy carbon key fob cover - Carbon Fiber mirror caps - matte black diffuser
    Instagram
    Established Member Two Rings MathildaS3's Avatar
    Apr 14 2015
    Palm Beach Gardens, FL
    They are held on by clips. Have a look from the back side...just have to bend one, I think.
    2016 Sepang Blue S3. MagRide, SuperSport seats, B&O, RS3 grille, wheel spacers 10mm/17.5mm, K&N drop-in filter, stock intake mod, LED interiors, Spulen engine mount insert (modified), BMS JB4 tune. Sleeper AF...
    Sep 01 2016
    Norway
    Oct 25 2008
    Depress clips use a rubber mallet from behind the top to move it off of the exhaust. Just removed mine yesterday and swapped to.the black dc sport tips shown here.
    http://www.audizine.com/forum/showth...DP-OEM-Rez-Del
    https://www.instagram.com/p/BV96RLcnYsU/
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    I'd like to do burnt "blue" exhaust tips.. any DIY install with pics?
    Sent from my ONEPLUS A3000 using Tapatalk
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    I have 23K on my car and my tips look like new. When I clean the car I clean the tips. For stubborn black exhaust soot I use car wax and it comes right off.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    Jan 30 2017
    Vancouver, BC
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    I'm looking to gives these a try soon
    http://www.audizine.com/forum/showth...-stock-Catback
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Apr 14 2015
    Too late for OP, I think, but I wipe mine with a dry towel every time I drive. Call me what you like, but they still look spankin new.
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    I use Brasso metal polish with the help of very fine metal scouring pads for those tough cooked on carbon deposits
    Sent from my A0001 using Tapatalk
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    A wipe every 200 miles (my weekly mileage) does the job.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Established Member Two Rings marquette100's Avatar
    Jun 13 2016
    Tri-State Area
    0000 steel wool, wd40 cleans everything in 30 seconds. Polish with some metal polish. So damn easy. It will change your life. Try it.
    Sep 01 2016
    Norway
    Thanks, i will try it today :)
    Jun 16 2016
    Ontario
    Quote Originally Posted by andre_shift View Post
    Can you take before and aftet shots? Thx
    Instagram
    Sep 01 2016
    Norway
    Before shot.. i forgot.
    But i did it today and it was better but not 100%. I think the tips is fucked up and burned black. Maybe buy some new ones..Somebody have artnr?
    Junior Member One Ring
    Jun 12 2014
    2014 BMW 320i xDrive
    Saratoga Springs, NY
    Have you tried P21S polishing soap? That always does the trick for me
    2018 S4 | Ibis | Technology | Full Nappa | Sport | Carbon Atlas | 19"
    Prior Vehicles:
    2014 S4 Premium Plus | Monsoon | MMI | B&O | Full Nappa | Sport Diff | Carbon Atlas
    2008 A6 S-Line | Quartz | MMI | 20% Llumar
    2006 A4 | Quartz | MMI | 20% Lumar
    2002 A4 | Dolphin | APR Cat-Back Exhaust | 20% Llumar
    Sep 01 2016
    Norway
    8v0253825c ?
    Active Member Two Rings pinski's Avatar
    Jun 22 2017
    Greensboro, NC
    I bought mine used and the previous owner didn't care to keep them in good shape. They had heavy carbon deposits and I'm guessing from a lack of cleaning eventually started pitting a little bit. I tried cleaning normally, then wax, then polish, then abrasive polish, then metal polish, then a scouring pad and then steel wool. The steel wool was the only thing that removed *most* of the carbon build up, but also revealed the pitting in the tips. I've accepted the fact that I'm just going to have to buy new ones.
    2015 S3 | Panther Black | P+
    Gone...2014 Subaru BRZ, 2010 Lexus IS250, 2006 Miata
    May 17 2016
    Hong Kong/LA
    Open flaps mod is your friend.. (Besides the questionable lower end reduced torque issue), they help dispense the carbon evenly on all 4 pipes rather than just the inner two, making it much easier to deal with, weekly wipe with basso will take care of it. Steel wool, although works great, but it will also scratch/dulling the chrome...
    Active Member Two Rings vudoo6's Avatar
    Oct 21 2015
    Tacoma Wa
    I used Bar Keepers Friend. Can be found at any hardware store. Give it a LIGHT buff and it'll come right off.
    Apr 11 2012
    Adams metal polish #1 with a microfiber towel got stubborn soot off for me. Best to wipe them off often though. I use an all purpose cleaner (apc) and mf towel every few drives.
    Senior Member Two Rings MkUrMark's Avatar
    Aug 09 2015
    Southern Cali
    Metal/chrome polish works
    2016 S3
    12' Golf R:. Stg 1+sold
    10' Gti sold
    06 A4 sold
    Established Member Two Rings Hard-Knocks's Avatar
    Jan 04 2017
    Raleigh, North Carolina
    Quote Originally Posted by TCharlesM View Post
    Thanks so much for this recommendation. Ordered a can from Amazon and finally had the opportunity to us it today. Have been using the typical chrome cleaner from the local Autozone and it typically took me two to three applications before the carbon built-up was mostly gone. However, with the P21S it took a light rubbing and the exhaust tips are now cleaner than ever before.
    This forum has been fantastic and I really appreciate all the good information everyone is sharing.
    Senior Member Two Rings Fixeroh's Avatar
    Aug 13 2014
    Central Ohio
    Tried to keep my S3 tips clean but apparently didn't attack them often enough. Read the thread http://www.audizine.com/forum/showth...-stock-Catback and have decided to go with the posters useful suggestion. Ordered 3 stainless Magnaflow tips and will have them installed next week. Will drop my muffler assembly and my neighbor will do the cutting and welding for me. Neighbor works for Mike Shank Racing (Acura NSX factory team in GTD) and will have access to the shop. Really great to have neighbors like that!! I really like the look of the double walled stainless Magnaflow tips and will be easier to keep them clean. I recently used Mother's metal polish on the current oval tips but still can't get all the carbon off. Chrome plating is pitted in spots too. My S3 has 23K miles.
