Results 1 to 10 of 10
    Established Member Two Rings goneAUDIcrazy's Avatar
    Apr 26 2014
    Atlanta
    B7 Rear Upper Control Arm - Upper Bolt STUCK
    I'm in the process of replacing bushings, control arms, bolts, etc on my B7 Avant. As I was loosening the bolt where the Rear Upper Control Arm mounts to the chassis, the nut that I assume is supposed to be welded to the chassis bar on the other side popped loose, now I can't get the bolt out, even though it's loose enough for the control arm to swing on its own.
    I have tried to get a socket onto the nut on the other side of the chassis bar but it's not visible, and I can't seem to get any size I have on there.
    Does anyone have any guidance?
    2008 A4 Avant 2.0T 6MT Brilliant Black - APR Stage 2 Tune and Exhaust
    Oct 24 2015
    Perth, WA
    Do you have air tools? Either way you can place multiple open ended spanners on the bolt head side to lever it off as you turn it. Try using heaps of penetrating oil and may be a jack under the knuckle to lift the whole assembly up to take the weight off.
    My respray thread
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    You will have to lower the frame about an inch on the side you are working on and use vise-grips on the nut. Replace, tighten up the sub-frame before moving on to the other side.
    Apr 26 2014
    Atlanta
    Quote Originally Posted by Okedokey View Post
    No air tools, it's not the weight, the control arm is disconnected completely minus the upper bolt. I feel like you are talking about the lower bolt?
    Quote Originally Posted by JayDog747 View Post
    I was hoping this wasn't the case. Do you happen to know the nut size and if it was originally welded to the frame?
    I'll have to finish the rest of the suspension first so that I can get all 4 wheels off the ground......
    Feb 24 2004
    Minneapolis
    Yea that's a well known bitch. I fought this last fall. I had no chance on that bolt. Read this thead, and see Denio's post number 9 with pictures. I finally took it too a shop. He dropped the subframe, heated that nut red hot, vice griped, turned a few turns, then re-heated, turned a few more, blah, blah, blah.
    http://www.audizine.com/forum/showth...light=subframe
    Quote Originally Posted by goneAUDIcrazy View Post
    I don't think you can just replace the nut. The factory nut has a collar on it that is pressed in at the factory. Once it turns years later, you have to fight to get it out, clean up the threads, and weld it back in place. That collar centers the nut, and consequently the bolt, in that hole. And that location is very important to your alignment. Do not sacrifice or replace that nut.
    I wish I had a better way. But if you search around, others have come to the same point as I was.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Apr 26 2014
    Atlanta
    Tackling this task one day this week, thanks for the help everyone, not sure how I couldn't find more info on this, wrong search terms I guess.
    May 31 2015
    2017 Mazda CX-5 Touring
    Twin Cities, MN
    Quote Originally Posted by mtroxel View Post
    Bumped for the link to a helpful thread
    '06 A4 Avant 2.0TQM S-Line Brilliant Red- | JHM High Flow Cat | Bosal Center exhaust | 034 Snub, motor, & trans mounts | 034 Spherical Front Sway End Links | 034 Street Density Control Arms | Meyle HD tie rods | ST coilovers | 750# Hyperco rear springs | Bilstein B8 rear shocks | S4 rear brake swap | Mk2 TT Turbines w/Pilot Sport AS3 | Blizzaks for snow
    -Plans: 155k and going...
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Its a press-fit nut, no actual size. Not welded but pulled into place when tightened. Need to lower the subframe a good bit to get something on it, to hold it. I used a small pipe wrench to hold it, worked good.
    Sent from my LM-G710VM using Audizine Forum mobile app
    May 31 2015
    Twin Cities, MN
    Quote Originally Posted by Jayz691 View Post
    Yeah with it cleaned up it seems to have about 8 sides. I tried holding it with a vice grips and crescent wrench but the threads have bound up terribly trying to loosen it. It travels about a 1/4" and then gets stuck. I'm just going ahead with ordering genuine nuts and bolts and am going to cut and split the nut to get around it. One of my knuckle-side eccentric bolts was also seized (the main reason I'm doing this project), so at this point I think i have spent as much on these nuts and bolts as I did on the replacement arms!
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by Tsinsta93 View Post
    I did the same, bought Moog arms, and low milage used lower A-arms. All new hardware, all 4 eccentric bolts were seized. Actually just did the 2 big arms a week ago. Worth the headache though, cuz now it drive beautifully, with fresh alignment. Heres a pic of that pressfit nut, believe it is 8 sided(prob special socket, frickin Audi). Good luck.Screenshot_20200922-115510.jpg
