So my car(2006 A4 2.0T automatic) has brand new: starter and relay, alternator, battery, ignition switch, and battery ground cable. This was all in effort to fix a no crank/start issue I was having previously which ended up being a fuse (LOL!) so I'm trying to avoid shooting in the dark with this new issue that I've been having.
The car, most of the time, starts up fine and doesn't give me trouble. But sometimes it turns over realllll slow and then starts. And other times, it'll turn over realllll slow and then not start as if the battery is dead. But the battery isn't dead, and if I let it sit for about 10 minutes or so then try again it almost always starts. Rain also seems to be a factor in this issue so I'm automatically thinking something electrical. I've traced all the wiring I can find, opened the ECU box and made sure all looks well there. I can't find anything that looks faulty, so I'm hoping you guys might have some knowledge you can drop on me to help me out. I appreciate any input you might have!
