Results 1 to 12 of 12
Thread: PCV Model
    Oct 11 2016
    Massachusets
    Question PCV Model
    Hi, I recently noticed that the MMI in my 2011 A4 shows i'm low on oil, but I changed the oil 2000 miles ago. I heard that the PCV can cause oil to be burnt but i'm not sure when my PCV was replaced or if its the original version. Is this the latest version of the PCV or is there a newer model that might fix my oil consumption issues?
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    https://shopdap.com/2-0t-tsi-pcv-val...e-06h103495ac/
    The old revisions of this part number will be any of the following. 06H-103-495-E, 06H103495E, 06H-103-495-A, 06H103495A
    I'm as cool as a cucumber in a bowl of hot sauce.
    Oct 11 2016
    Massachusets
    Thanks, so is mine version E? I wasn't too sure since the E didn't look like it was part of the model number.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Quote Originally Posted by Hunter2011 View Post
    It looks like it, but I'm sure someone with more knowledge then me will chime in soon.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Senior Member Three Rings DetRebel's Avatar
    Mar 20 2017
    Chevy Trailblazer (the real daily driver); previous car: '11 Brilliant Black B8 A4
    Detroit
    I was looking at PCV models earlier on ECS... are they really VIN/year specific?
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Quote Originally Posted by DetRebel View Post
    I think you should contact your local Audi dealer to be sure. There is part AC or part AE update. I think for pre 2013 models you don't want AE unless you have Audi updated software and piston rings.
    Se post #11 here: http://www.audizine.com/forum/showth...ew-revised-PCV
    Established Member Two Rings Anthony1491's Avatar
    May 15 2015
    Toronto, Ontario
    I also have a 2011 a4 and just replaced my broken pcv valve. I had 06H103495J in my car.
    I have also received the stage 1 & stage 2 oil consumption fix (ecu flash, pcv replacement, piston & rings)
    You have an old part and there have been a lot of revisions on it. The one that I ordered was the 06H103495AE part but the supplier informed me that part just got updated to 06H103495AK.
    I'm pretty sure that since you did not get your ecu reflashed your replacement part would be 06H103495AC. You should go to the dealer to check and see if an oil consumption test has been done on the car and do one
    2011 Audi A4 Deep Sea Blue
    GFB DV+ - RS4 Grill - ECS Silicone Inlet Hose - Tint - AFe Filter - Ultra Racing Strut Bar - Eurocode HFC - Intercooler Soundbox Delete
    Steering Wheel Paddle Shifter Retrofit - Rohana RC22 19" 9.5 et45 - S4 Struts & Sway bars - Rev Motoring Springs - Custom Magnaflow Exhaust
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    The flash update for the stage 1 fix was not to change any engine parameters, it was to allow the oil level sensor to check and record oil level more often. This way when you came in for stage 2 fix, the dealer could pull the info from the ecu to see the oil level monitoring. The crank seals where also done because people where reporting issues that they had oil consumption, but instead had the early revision of crank seals and would leak after the old style PCV valve failed. Just like the crank seals, the main seal can leak as well from a failed PCV valve.
    The main reason for the software update was done to keep people from cheating the system to get new motors. There are no sensors with in the motor that will get thrown off from the pcv revisions, this is all bullcrap. Plain and simple run the newest revision PCV valve you can find.
    Mar 20 2017
    Detroit
    Quote Originally Posted by audrobotic View Post
    Thanks!!
    I wish there was a thread on updates/revisions of parts for the Early B8 years. Every time I ask people refer me to B8 Buyers FYI thread but doesn't have info like this.
    Oct 11 2016
    Massachusets
    Quote Originally Posted by Anthony1491 View Post
    Lol I'm at 106k so I'm not going to the dealership. I'm still not sure if I should use AC or AH though, but i've heard they are basically the same thing. The AE model looks like its only for 2013+ cars.
    Nov 18 2019
    UK
    Mine just went bad (06H 103 495 J) .. called Audi dealer and they said the new rev is AK (06H 103 495 AK) ordered one for £71.
    ATM I have some shaking and high rpm on idle. The suction on the oil cap while running is crazy!
