I was looking at the spec sheet for the Continental ContiSport 5P that came stock on the S3. There's a couple different versions in 235/35R19 aspect yet they quite different width dimensions. The first is the OE tire, I believe. What is up with the other two? I see no difference in the 2nd tire other than tread width. The third has a different speed rating, slightly shallower tread, and is listed as "RO2 Audi" instead of "AO". Is the last tire (a full .5" wider) a shallower tread depth to maintain rolling radius?? As this demonstrates not all 235 width tires measure the same, is that also true of the 35% aspect ratio? All three are listed as 815 revs per mile (fwiw). Do they all have the same sidewall height or do they vary because the true width varies?:
235/35R19
"AO Audi"
91Y XL
UTQG 240 AA A
Max Load: 1356
Tread depth: 10/32
Weight: 21lbs
Tread width: 8.2"
Revs per mile: 815
235/35R19
"AO Audi"
91Y XL
UTQG 240 AA A
Max Load: 1,356
Tread depth: 10/32"
Weight: 21 lbs.
Tread width: 8.5"
Revs per mile: 815
235/35ZR19
"RO2 Audi"
91Y XL
UTQG 240 AA A
Max Load 1,356 lbs.
Tread depth: 9/32"
Weight: 22 lbs.
Tread width: 8.8"
Revs per mile: 815
https://www.tirerack.com/tires/tires...3&autoModClar=
