I’m in the middle of TB/Water pump job on the 1.8L turbo. I cannot get the crank bolt free; have tried multiple applications of PB Blaster, rapping on it with a mallet, and lots of force using a pipe on a breaker bar. To hold the sprocket I made 2 short metal pieces attaching the threaded sprocket holes to TB cover holes in the block. I’m considering buying a tool I saw online, looks to be 2 ft long or so. Couple of questions:
Any other tricks to free this bolt? (I will try a torch in the next day or so).
If I allow the crank to rotate about 30 degrees or so I can get one of my homemade tools to catch on snub mount bracket - Will rotating the crank ccw cause any damage? (everything I have read about turning the engine over by hand states Clockwise Only - I'm not familiar with the valve sequencing vs. piston movement).
Mike
