Results 1 to 24 of 24
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quick And Easy Rear Spring Replacement With Zip Ties (No wrenches required)
    Yes you read that right. With High Strength industrial Grade Zip-Ties available from McMaster-Carr ($7 each) Each zip-tie is rated for 1,130 lbs. I used three per spring for a total holding force of 3,400 lbs.
    First jack up the rear of the car and place jack stands under both sides. You need to jack up both sides to unload the rear sway bar and allow more downward movement of the suspension.
    Remove rear wheel.
    Place your floor jack underneath the bottom of the rear spring perch and fully load the rear spring. Attach three zip-ties around rear spring. Lower floor jack and remove spring.
    Here is the spring zip-tied and removed from the car.
    Next you will need to use you spring compressors (Available from Harbor Freight $30) to remove the zip-ties for reuse.
    Removing the straps from OEM spring.
    Then use your spring compressors to compress your new spring and add straps to hold it in a compressed state.
    New spring compressed and zipped.
    Ready for installation.
    Look at all that room!
    Use your floor jack to fully load the spring. This will release the tension on the zip-ties and allow you to reach in and remove them. Done! Lower the floor jack and proceed to the other side. Total job this morning took about 1 hour start to finish.
    Veteran Member Three Rings h_curtis's Avatar
    pittsburgh
    How lucky I am to now have old guy on this forum. Guess I am following you around from the B6 forum to here. Nice write up as usual. Seems you are playing around with your A5 already. :)
    '14 s5, 6sp, sport diff, b&o, panda, estriol blue
    Veteran Member Three Rings mcbuck's Avatar
    Mar 21 2010
    '19 Jeep Wrangler Unlimited Rubicon, '16 Grand Cherokee, '12 328 cab
    Charlotte-ish
    Shit, that is awesome!
    Buck
    Sent from this little electronic gizmo
    BUCK
    2011 A4 quattro, 2.0T, A/T, Deep Sea Blue Pearl (my son's car, but guess who gets to work on it?)
    GONE 2013 RS5 Daytona Grey Pearl, X-pipe, 20% tint, Arc Audio/Alpine, interior/backup LED, 034 RSB, H&R sport, V-FF 103, 285/30 DWS06, Girodisc, Hawk
    GONE - B7 A4 quattro, 2.0T, 6MT, 250K....dropped, tuned, and everything else
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by h_curtis View Post
    Yep. It's been a slow start. Just doing a few cosmetic things for now.
    * 20mm front/25mm rear spacers.
    * H&R springs.
    * Cleaned up front grille to remove license plate mounting holes.
    * Painted the calipers.
    * Tinted all the glass.
    * Blacked out the chrome window trim with Shadowline trim tape.
    I will eventually get into some performance mods. Meanwhile I still have the A4 if I want to do some "stupid" driving.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Be extremely careful zipping up a spring, there's an incredible amount of energy stored up in a compressed car spring, if the zip-tie breaks all hell will unleash and you can cause some pretty significant damage/injury. There's a reason spring compressors are so robust.
    If you undo the lower damper bolt, you should be able to drop the spring out with the need for a compressor.
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    Quote Originally Posted by JamesRS5 View Post
    .......there's an incredible amount of energy stored up in a compressed car spring...........There's a reason spring compressors are so robust.
    as a former mechanic, i can attest to this......
    ......fortunately, the mechanic at my shop was not hospitalized.....
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
    Dec 28 2006
    Western Maryland
    I was working alone and I don't think I could have wrangled the spring out by simply removing the lower shock bolt by myself. That's where dropping the sub-frame a little comes in and I really didn't want to mess with that.
    And believe me, I have no desire to hurt myself. I did do my homework before I decided to use the zip-ties. The H&R OE sport spring rates are 480 lb/in front and 200 lb/in rear. that is what makes the rear springs such a pain to remove. They are very long and have a considerable amount of compression in order to build the load support. In unloaded form they are a little under 13". I compressed them down to almost 8" for a total load of around 1,000 lb. I probably could have done it with 2 zip ties but opted for three for a triple safety factor.
    pittsburgh
    * H&R springs.
    Slow start. lol Geez, I haven't done anything but debadge the sides and get rid of the advertising on the back from the dealer.
    Nice to read your posts. Sort of comforting you are here. :) I would like to see your before and after shots when you get a chance. Not sure what I am going to do with my S5. Might go APR stage I only. No messing with the pully at this time, but people on the S4 forum don't agree with me.
    May 12 2017
    my intent was not to criticize your method, only warn everyone else of the potential hazards when working with compressed springs.
    it has been my experience that it is the stuff we take for granted that gets one in trouble......for instance ...... using under-rated jack stands.....
    also, in the spirit of full disclosure, i am currently a design assurance engineer in the medical robotics industry, it is my day-job to worry about what may go wrong...
    Billy
    Avatar Chart
    Dec 28 2006
    Western Maryland
    Your comments were not taken as a criticism but rather as a totally valid statement. If anyone decides to use my method they should handle the spring by the straps rather than the coils.
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    Is it possible to do a similar method on the front springs? Just asking, I haven't even looked at the suspension yet...
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by RockJGC View Post
    Unfortunately no. It isn’t too difficult but it does require dismantling the front suspension.
    Feb 27 2014
    Dubai
    My standard front springs came out without any need for compressing, we replaced the OE front springs for KW HAS with the damper still connected to the DRC pipes.
    Pain in the ass but doable.
    Nov 03 2011
    All Over!
    I'll be using OG's method when my springs turn up.
    Thanks, Old Guy!
    1986 Type 85 Audi 90 quattro
    Veteran Member Three Rings base14's Avatar
    Jun 01 2017
    OR
    Are these zip ties reusable, or is it a one time use for each spring?
    2018 A6 3.0t P+ Competition Package| 034 Stage 1 ECU+TCU (his)
    2015 Q5 3.0t P+ S-line | EPL Stage I (hers)
    (SOLD)2013 allroad Prestige | APR Stage II | E85
    (SOLD)2010 Q5 P+ | OEM+ Build Thread
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by base14 View Post
    I used the same zip ties to replace both rear springs. I then gave them to another AZ member to do his springs. At that point I told him to throw them out rather than return them to me.
    Once the zip tie is unloaded you need to use a small screwdriver to lift up on the latch to release the tie.
    Dec 18 2015
    OH
    Can you give the exact link to what you bought? I need to do this probably this week.
    Should I use 4 to be even more safe? I reallllyyyyy don't want to risk injury
    Dec 28 2006
    Western Maryland
    I purchased four but only used three. Three should hold 3,400 lbs which is a safety factor of a little over 3X. Use four if you want. Nothing wrong with being safe!
    Established Member Two Rings Jaywalker's Avatar
    Feb 09 2019
    Iowa
    This thread is like Manna from heaven. I have springs on the way, and was getting a dry mouth trying to visualize this install going smoothly after reading a dozen DIY's. Now I only feel that way half the time when thinking about the fronts...lol Can I assume then that this method will work equally well on my '04 A4?
    G.I.A.C. Stage II, AFE induction, 034 Diverter, ER FMIC, 034HFC, 2.0T coils, Miltek non res exhaust, 380cc injectors, 034 snub/bracket/motor mounts, Sparco 18's, lowered on Vogtland sport springs, S4 rear brakes/S8 Brembo 345mm fronts, Podi boost gauge,
    Neuspeed solid shifter, S4 lip spoiler/door blades, honeycomb grill, tinted side markers, black Helix E-code headlights.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Jaywalker View Post
    I can't say for sure. But I don't see why not. When I replaced the rear springs on my A4 (back in 2003;-) I had access to a one sided spring compressor that did the trick in minutes.
    Jul 25 2009
    Bellevue, WA
    I finally got around to ordering a set of these zip ties from mcmaster ( PN #1168N3 ) today in prep for my upcoming suspension job. Also ordered a B8.5 "nuts and bolts" kit from DAP -- hopefully that will have most of what I need. I just need the parts to be released/shipped from NC. They made it from Germany in a day and have been stuck on teh east coast for a week. I know, folks have bigger issues w/the weather at the moment.
    '16 SQ5 ROW/BilsteinB8 CH-R 9s; 997.2 spasm 6spd; '18 Macan S. Many, many audis in the past...
    Junior Member Two Rings
    Mar 21 2017
    Wondering if anyone can identify the actual manufacturer of these cable ties? I can't order through McMasterCarr in Canada due to restrictions on shipments. Therefore, need to find an alternate route to get my hands on these.
    thanks!
    2017 Q5 3.0T S-line
    Mar 21 2017
    2017 Q5 3.0T S-line
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Quote Originally Posted by pattyt View Post
    Page not found - The page you are looking for cannot be found.
    But I'm assuming it's this one? https://hcl-clamping.com/products/he...4a85744e&_ss=r
    How did they work out? Was 22" long enough?
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
