Presentation
This is it, in the box.
I'd add more pics, but there really isn't that much more to see (being honest, I didn't take any more pics... my bad). The flywheel is bare aluminum and the only aesthetic addition is a laser-inscribed "JHMotorsports" around the hub. To me, this is a huge plus. i've seen companies like ECS and EC pull out all the stops in anodizing their flywheels and pressure plates different colors, but really, what's the point? Once it's installed, you'll (hopefully) never see it again, so I'm glad money was saved on a no-nonsense approach.
Performance
Oh yeah, there are some great benefits... Number one, and I know I can't properly quantify this, I swear I gained ~25 hp on the butt dyno. Really big difference, although some of it can be attributed to the addition of a HFC at the same time (really wish I could have tested the two separately, but oh well). Engine braking is now more effective, thanks to the decrease in rotating mass. Rev matching is SO much easier and more satisfying. Just takes a little "tap" of the pedal to get it up to speed, you don't even need to think about it. However, the flywheel is still heavy enough that the revs don't drop instantly, which would have resulted in rough shifts. 9/10 times the RPM is right where you want it. There's now a nice "springy" feeling to the clutch pedal, which takes a bit of getting used to, but I actually ended up enjoying this because you never have to guess at the bite point anymore. It's clear as day, and makes starts from a stop much more consistent. I'm pretty sure it goes without saying that there is absolutely NO slip in the clutch, even when you're launching or power shifting (not that I've done either of those things... haha). Overall, it adds a good bit of fun. Cue the "should have come from the factory like this." Well... I might not go that far (Read the next section.)
NVH
So, here's the issue most people have with lightweight flywheels... They chatter, they make groaning sounds, vibrations... I've heard a few complaints. The trade-off with JHM's is nearly negligible. The only time you'll ever hear anything out of the ordinary is accelerating at a REALLY low RPM. As in, something you shouldn't be doing anyways. On the highway, cruising at 70 in 6th, you won't hear a difference, even on hills with the cruise control on, up until you decide to pass someone... If you give it too much throttle, you'll probably hear some groaning (I might get a video of this if people are interested). Chatter? I definitely can't hear any from inside the car. Even with the windows down... nothing. The only time I've ever heard anything close to chatter was when I had my head under the car with the A/C on. Even then, you'd have to look for it. The clutch takeup is butter-smooth, and won't be an annoyance in bumper-to-bumper traffic. It's very easy to modulate once you get used to it. I'm a very particular person when it comes to NVH, and, to me, these are acceptable trade-offs.
Conclusion
So... Is the JHM Stage 1 clutch/flywheel right for you? If, for whatever reason, you need to replace the OEM setup already, I'd say it's definitely worth it. If your clutch/flywheel is in good shape and you're not planning to add any more power, I'd be hesitant, based on price alone... If money isn't an object, there are quite a few benefits I mentioned that you might find advantageous (more direct clutch pedal responce, solid shifts and launches, satisfying rev-matching, more power), but still... it's a lot. It's a mod that improves quite a few parameters of the car, and overall I'm very happy I went with it over OEM.
9/10, with the only cons being price (although comparable to other clutch/fw packages) and a little bit of added NVH (which was less than expected)
One more thing...
I feel like I have to mention this as a warning... JHM originally sent me the wrong clutch disk. We didn't find out until the transmission was separated from the car. Luckily, the shop caught the difference before the clutch was installed, but if somehow it wasn't, I'd probably be stuck with another few hours of labor to change it out again. They also didn't charge me for the additional time the car was on the lift while waiting for it to ship, which leads me to the real issue with this situation. I understand mistakes happen, especially since the clutches look pretty similar (see below), but it wasn't just an inconvenience to me but my shop as well, as my car was stuck on the lift until they got the new disk. They came to a resolution quickly and were able to ship the disk the same day... however... they would only pay for ground shipping, which would have easily taken another week from CA. Another week of a rental car, another week with my car occupying a lift at the shop... I ended up paying $30 for 2-day shipping. If you make a mistake on a shipment worth upwards of $3k, what's an extra $50 to ship the replacement part overnight as a courtesy? I really hope JHM reconsiders this policy in the future. Full disclosure, they did give me free shipping on the initial order, which I'm still very appreciative of, and they still make a great product, so I'll probably continue to do business with them in the future... although I'll definitely give future shipments a thorough inspection before installation. Aside from that, Jake was awesome to work with, and I appreciate him answering all my questions.
Clutch comparison:
Used B8 clutch on the left, new B7 clutch on the right.
Props to German Auto Pros for the install... If you're anywhere near the Cleveland area, I highly recommend them. Cary's a stand-up dude, and very knowledgeable of all things VAG. Labor was about half the cost of the dealer, too.
