Results 1 to 36 of 36
    Jan 16 2016
    S3, 4runner, R6
    245/35/19 on my stock wheels
    I had a razor blade cut thru 1 of my oem contisport tires......
    So I decided its time to upgrade, going with Michelin pilot sport 4s. I wanted to ask if anyone knows if I could fit 245/35R19 tires on my oem (19" x 8", 49mm Offset) wheels? if so are there any rubbing issues?
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    Quote Originally Posted by SoCal S3 View Post
    Silly question but what size rubber is on now?
    Jan 16 2016
    S3, 4runner, R6
    Quote Originally Posted by bakedcorn View Post
    oem tires are 235/35R19
    Jul 27 2015
    Ontario
    Based on a tire calculator you can but your speedo will be off by 1.1 km when doing 100km
    Sent from my A0001 using Tapatalk
    Grr mobile phone, you can also try tirerack calculator on their website.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    i would never imagine as its only a wider tire than oem.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Established Member Two Rings MathildaS3's Avatar
    Apr 14 2015
    Palm Beach Gardens, FL
    The 2nd number of a tire size is an aspect ratio, which dictates sidewall height, and therefore total diameter. 35% of 245mm is more than 35% of 235mm.
    2016 Sepang Blue S3. MagRide, SuperSport seats, B&O, RS3 grille, wheel spacers 10mm/17.5mm, K&N drop-in filter, stock intake mod, LED interiors, Spulen engine mount insert (modified), BMS JB4 tune. Sleeper AF...
    Sep 20 2004
    Paradise Valley, AZ
    Quote Originally Posted by MathildaS3 View Post
    Gotcha!! Thanks.
    May 20 2015
    Pacific NW
    Check out the specs. The 245/35-19 PS4S has only 1/10" wider tread than the 235. But the 235 is already 3/10" wider than the stock 235/35-19 Conti 5P. I'd stick with the 235/35-19 so you aren't changing he overall diameter but still getting a wider tire.
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2008 BMW 535xi (sold)
    2006 A3 2.0T (sold)
    Apr 29 2017
    Quote Originally Posted by Nathing32 View Post
    Your post made no sense..... Lolll
    2017 Audi A3 Progressiv S-line with 19" Wheel Pack
    2017 Audi A3 2.0T Progressiv Quattro S-line w/ 19'' Wheels
    Sep 28 2014
    ontario canada
    No issues. I run 245/35r19 pilot super sports for a year. No rubbing and will work with up to 20mm spacer in rear without rubbing.
    Jan 16 2016
    S3, 4runner, R6
    thats what I needed to know, Thx
    May 20 2015
    Pacific NW
    Quote Originally Posted by 17A3 View Post
    Oh it doesn't? Look at the actual dimensions of each tire on their websites or Tirerack. A 245 does not actually equal 245 mm nor does 235 actually equal 235 mm. Tire manufacturers use these dimensions to roughly equate to the overall width of the tire from sidewall to sidewall. It's more of a "class" of tire than a true measurement. It also has little to do with the actual tread width. It just so happens that the PS4S 235/35-19 is much closer to the 245 in tread width than it is to a Conti 5P 235/35-19. Even more confusing; there are multiple versions of each tire size due to them being OE spec'd by differnent car manufacturers. There are three versions of the Conti 5P listed on Tirerack in 235/35-19 with tread widths varying between 8.2" and 8.6". The ZR rated 235 Conti 5P is actually about 1/4" wider (tread) than the 245 PS4S.
    Not trying to hijack this thread but I think you'd just want to be aware of what size tires you're actually buying.
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2006 A3 2.0T (sold)
    Jan 16 2016
    S3, 4runner, R6
    I just got the 245/35R19 Michelin P4S Installed, they look really good and they don't rub at all with my OEM wheels..... Car feels good.
    I never really liked how thin the OEM wheel looked and how I could feel every little bump.
    Feb 27 2012
    2016 Porsche GT3 RS
    Marin, CA
    Are you using spacers or just the OE wheels?
    Nov 14 2014
    pnw
    Pics of the 245s installed?
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    I would like to see some pictures of the Michelin 245x35x19 too. My S3 is going to be needing tires by the end of summer/early fall and I am thinking that Michelin is the best option. Thanks in advance.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    Feb 27 2012
    2016 Porsche GT3 RS
    Marin, CA
    +1. My OE Conti's are getting near done. Can't wait to put on decent tires. Would love to go 245 if they don't rub when pitched hard into corners ;)
    PS: Anyone here ever have a sunroof frame replaced? Mine's been in the shop for a week getting this done. Was the result of a roof rattle.
    Jan 15 2010
    Santa Barbara, CA
    +1 for pics of 245 PSS's. Was planning on doing that too on OEM wheels with 12/17.5 spacers.
    Jan 16 2016
    S3, 4runner, R6
    I am overall satisfied with purchase as I now have road hazard warranty on the Michelin tires, my OEM continentals had no warranty.
    purchased @ Sams club for $1107 OTD (costco didn't want to install bigger size tire but Sams club was ok with it)
    1) I am not running any spacers
    2) tires DO NOT rub anywhere
    3) Installed on my OEM wheels
    4) car feels better over the road, hard to break them loose on the freeway on ramp
    5) FYI Michelin P4S 245/35R19 tires are made in france, Michelin P4S 235/35R19 tires are made in USA
    Jan 16 2016
    S3, 4runner, R6
    [URL
    Dec 22 2015
    Nice- Thanks a lot.
    Feb 27 2012
    2016 Porsche GT3 RS
    Marin, CA
    Thanks for being our collective Guinea Pig. They look great and I bet a lot will go that route.
    Active Member Two Rings imbeamer's Avatar
    Nov 03 2011
    2016 A6 3.0, 2008 GMC Yukon Denali XL (for the boat)
    OC Cali
    Any Gas mileage difference with the wider tire. Not that it matters to much just wondering.
    2017 S3 Daytona Grey Pearl With Magma Red Seats
    Established Member Two Rings IamtheStig's Avatar
    May 12 2013
    Greensboro, NC
    Is your S3 on stock springs or lowered? I’m considering getting Michelin Pilot Sport 4 AS in 245/35/19 for my OEM 5 Spoke Wheels (19" x 8", 49mm Offset). My A3 has mild lowering springs. Will the 245 Michelin tires rub without spacers?
    Laser Red 2000 Audi A4 Sedan 1.8TQM
    Dec 25 2004
    Earth
    245 35 19. For several years now....
    I can tell you the different tire manufacturers make'm all slightly different. My Yokahama's are wider then the Nankangs I ran before. Even though both were 245-35-19.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Dec 25 2004
    Earth
    These are 245-35-19 Sumitomo's...
    May 12 2013
    Greensboro, NC
    Quote Originally Posted by MikTip View Post
    Thanks for the pics! Are you running spacers with 245s?
    Dec 25 2004
    Earth
    Quote Originally Posted by IamtheStig View Post
    No spacers...wheels are 8.5" wide with 35mm offset. No rub
    Dec 25 2004
    Earth
    20's with 245-35-20....no rub no spacers
    May 12 2013
    Greensboro, NC
    I'm running stock 19x8 5 spoke wheels with 49mm offset so, I am concerned about rubbing.
    Dec 25 2004
    Earth
    Stock 8 inch wide wheels with 245's don't rub...
    https://www.audizine.com/forum/showt...1#post12506446
    My 35mm offset wheels stick 14mm more towards the fenders than stock offset wheels....no rub
    May 12 2013
    Greensboro, NC
    Thanks Mik! I realized your aftermarket wheels with 35mm offset will clear the fenders. I was considering whether tires with a 49mm offset wheel would rub against the suspension components under load.
    Dec 25 2004
    Earth
    Thats a good point...you could try to see how close to the struts the tires are with the stock wheels...
    Junior Member One Ring
    Oct 14 2019
    Wisconsin
    i gotta ask, did you lower your car to achieve that fitment for your tires? it looks so good!
    Dec 25 2004
    Earth
    Quote Originally Posted by ChrisKasch View Post
    The car has been lowered on APR springs.
    Oct 16 2021
    East Coast, USA
    X2 I love the flush fit without wheel gap look! I've been considering going with245 michelin tires on stock wheels but I'm lowered 1.5in springs (I often carry 2 or more people in the car). Should I get 10mm spacers all round to prevent rubbing?
