Hello all,
The title says it all really, well most of it. I have a 3.0 6spd. Last weekend I changed the motor mounts, the old ones were a little sloppy. I had a CV boot that had been cracked since i bought it so i replaced the whole axle. And then i changed out the transmission oil, and rear diff oil. Both filled with royal purple GL4/5 compatible synthetic oil.
Now i have a vibration that i feel through the car, not so much in the steering wheel. From what i can tell its coming from the drivers side, but i cant tell if its the front or back. It seems to be there mostly when i am coasting and becomes noticeable from 30 up to 80. If i accelerate at all it goes away and if i brake just a tad harder than i normally would, it also goes away. If there is a dip in the road it becomes noticeably worse in all situations; coasting, accelerating or braking. It also feels like it is higher frequency than what a tire issue would be. There are no noises that i can hear associated with the vibration.
Could this have vibration have been there before and now the new motor mounts are transmitting that vib into the car?
My plan is to put the old CV back in temporarily to see if its the axle. I have rechecked the oil levels and all is good there. I have also tried to tweak the motor mounts. When i installed them, i tightened them in with the car in the air and the suspension at full droop. When i reread the tutu, i noticed that i should have had the cars weight on the suspension so i loosened everything and put blocks under the tires and re-tightened. The vib was unchanged.
Any thoughts on the matter?
Thanks in advance,
-Erik
