Results 1 to 20 of 20
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    How to update MMI navigation
    So I tried to update my Navigation maps. I used a 32gb sd card and formatted it to Fat32. then I went over to Audi.com and logged in. downloaded an updated map for the MMI. clicked n dragged the file to the SD card...bang...put it into my car and went to menu and factory update then I get a screen which shows all the options....sd1 sd2 usb...ect...ect. well nothing is lit up. Can someone plz help.......
    p.s I also tried to load it onto a usb stick but no luck as well..... Can someone plz tell me what I am doing wrong?
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by jiannu View Post
    euhhhh ya....so I take it no one here has updated the nav with new maps?!
    Veteran Member Four Rings a4000's Avatar
    Nov 30 2004
    Pittsburgh
    I have just don't remember exactly. Is it a zip file? Are u supposed to extract it to the card?
    '17 Audi S8 plus // DS1 // E40 // SRM TCU // SRM Flex // SRM Manifolds // SRM 3" Intakes // 034 HPFP // ARM Downpipes // Milltek Non-Res // Ibis // Black with Arras Red Stitching // Dynamic Package // Bang & Olufsen // Black Optics // Driver Assistance // Cold Weather // CETE ASC // 21x9 Ferrada FR8 // PS4S
    '19 Q7 3.0T Prestige // Audi Design Selection Murillo Brown // Luxury // B&O // Black Optics // Adaptive Chassis // Cold Weather // Tow // Night Vision
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by a4000 View Post
    It was a JLNP file. very small in size. I copy n pasted to my sd card but when I put it into the MMI it was not lit(didn't recognize it). Tried also with a USB.... Thought I didn't have the sd card in right format so I checked and it was fat32. I loaded some songs onto it and reads the songs fine.....
    May 03 2016
    Champaign, IL
    I don't recall the exact steps, but I believe the initial download is for a Java applet, which you must then run on your computer (with Java installed). The applet then connects to Audi's servers to download the actual map data. It should not be a small file. It was around 6GB altogether.
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by bigxie View Post
    ok so after playing some tricks and researching it.... I realized that I was using windows 10 with Edge and it does NOT support java...so I had to download Chrome and Java.... After it prompt me to connect to Audi server and now its downloading the proper files.... I chose North America so its like 16GB... will confirm after it downloads and check back that it downloaded into my MMI...
    Thanks every1!!!
    Mar 23 2016
    Ontario,Canada
    well after downloading 16gb for all maps, I copied onto sd card but again, it was not highlighted when I tried to choose destination path in the MMI..... I had some music on it as well. Will try and just place only the nav files and see.....
    Oct 10 2016
    Houston, TX
    I did mine a couple of months ago and had no issues. 16GB download sounds about right. My Mac automatically extracts zip files on download, and I copied the extracted folder to the SD card. The upgrade was detected and worked fine... took quite a while to install. 30+ minutes. I don't think you can place the zip file onto the SD card, it must be unzipped first.
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by lastig21 View Post
    There's was 4 files.....after connecting to audi server. Once downloaded I placed onto SD card.....I will try and see if they need to be unzipped.
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    Just curious and slightly off topic here but is it possible to install and activate navigation on an a3 that otherwise does not have it? To my understanding it seems it is doable with the sd card, is there anyone that currently sells a aftermarket retro?
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Mar 23 2016
    Ontario,Canada
    updating or bumping this ......
    I tried for the life of me and CAN NOT update my MMI maps in Navigation. I went to Audi .com/ca and downloaded the updated map files.. Installed them all on SD card and when I pop it into my car......nothing...it does not light up. I even tried on a SSD drive and same thing.... Need help please!!!
    Nov 13 2009
    the OC, SOCAL
    dumb question, when updating the nav, what exactly is it getting?
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by 949 View Post
    any updates to the roads, highways, new businesses or places. any other changes that have been made.
    Established Member Two Rings S3owner's Avatar
    Jun 16 2016
    Ontario
    How do you open the jnlp file? You can not drag/drop the files. JavaWS should be used to run the jnlp, then select the SD partition as "destination", then it will push the update files into your SD card. This way your MMI will recognize the SD card as an update medium.
    Missano Red II S3 Quattro 2.0T - H&R Sport Springs - Spacers 10mm/17.5mm - Sound Enhancing Resonator Delete - USmillWorks tow hook bracket - Pinalloy carbon key fob cover - Carbon Fiber mirror caps - matte black diffuser
    Instagram
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by S3owner View Post
    ok...slow down here....lol......step by step....how do I do it? I am on Windows 10. What do I need?
    Jun 16 2016
    Ontario
    The jnlp file is just an "installer". It does not hold any actual data. Javaws allows you to download and run that from the web.
    1. Open a command line and type: cmd> javaws xxxx.jnlp
    2. Follow the setup wizard and select your SD card partition when it asks for installation destination
    3. It takes couple of minutes to download the actual maps and install it on your SD card (be patient)
    4. when done, safely remove your SD card and hop in the car :D
    Hope that helps!
    Instagram
    Jun 16 2016
    Ontario
    If you had issues running CMD (command line) follow this for opening the jnlp file:
    http://vmt.mathforum.org/VMTLobby/VM...s.html#windows
    Instagram
    Mar 23 2016
    Ontario,Canada
    Hope that helps!
    So if I remember correct, When I downloaded the updates, I used Java to install it on my PC. The file was around 18Gb. When it was complete I copied the files to my SD card but when I tried to install it on my car, it was not highlighted or it didn't recognize it. I even read it needed to be in FAT32 format.
    Mar 23 2016
    Ontario,Canada
    I am trying a new method.....I will download the files with JAVA and have it installed directly on to my SD card instead of picking a destination folder on my PC and then dragging onto SD card.
    Mar 23 2016
    Ontario,Canada
    So I tried again and still it was not highlighted. I will try once more and reformat the sd card and make sure it's in faT32 .
    Sent from my SM-N950U1 using Tapatalk
