Results 1 to 15 of 15
    Aug 12 2015
    Minneapolis MN
    Sport / Dynamic Mode and no downshift?
    Was at the track yesterday and had an issue that I've never encountered before and wondering if I'm missing something or if anyone else has had the same issue? I was in dynamic mode and on several corners used the paddles to down shift into 3rd. However on the next corner I was approaching the car was in 5th gear and I didn't use the paddles to downshift. After turning the corner I jammed the accelerator to the floor and I had no power...at first I thought the car went into limp mode but then realized the car stayed in 5th car. Even in manual mode the car should automatically downshift right?
    After my session I went out and tested it again by up shifting to M4 then braking hard then jamming on the gas with car around 2,000 rpm and nothing? Stuck in 4th gear...am I missing something? The car should be downshifting automatically right?
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
    Established Member Two Rings Arctic Audi's Avatar
    Aug 04 2009
    2013 Audi Q5, 2009 A4, 2007 Buell Firebolt XB12R, Motobecane 29er
    Pennsylvania
    Quote Originally Posted by db12 View Post
    Not if you are in manual mode. At least not in my S5.
    2014 S5 Monsoon Grey, Titanium-Black Optics, Prem+, Nav, 19" Rotors, B&O, Sports Diff, Drive Select, RS5 Grill
    2013 Q5 Moonlight Blue Metallic, Prem+, 20" Rotors
    2009 A4 Black, Prem+, CVT
    Junior Member Two Rings karlaudi's Avatar
    Dec 10 2015
    SF Bay Area
    It should be downshifting- I've gone into a corner and used the paddles to go from 5-4, then when I floored the gas pedal it kicked down once more on its own. However on the street/on ramp I've had it in manual mode and it chugged at lower RPMs before going to full throttle and an automatic downshift
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Are you engaging the kick-down? You can floor it hard but unless you feel the pedal click and engage the kick down the car wont downshift on its own (when in manual mode).
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    Mine downshifts on its own if you let the revs and speed drop.
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Aug 12 2015
    Minneapolis MN
    Quote Originally Posted by SDV325 View Post
    Put the pedal to the floor to test it and still same result. At least the upshift at 6,200 RPM's still works just cant figure out why its not downshifting when running at lower RPM's.
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    There's a physical switch at the end of the throttle pedal. That's the kick-down switch. Triggering it in manual mode will cause the transmission to automatically downshift to the lowest possible gear at your current rpm, otherwise it will only automatically downshift a gear if you let the rpm drop to a point where the engine would lug or stall.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Jan 20 2014
    Calgary, AB
    Quote Originally Posted by superswiss View Post
    Exactly. You can definitely feel the click when you activate it.
    OP are you feeling the pedal click, or are you just fully depressing the pedal?
    Veteran Member Four Rings isles1's Avatar
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Not downshifting because it's in manual mode after you used the paddles. Push back on the shifter to put it back into S mode.
    2022 SQ5, P+, Daytona Grey, S Sport, B&O, Black Optic, Black Badges, Dynamic Steering, OEM Sport Exhaust, Black/Black Dinamica.
    2013 S4, P+, DSG, Ice Silver Metallic, Black/Silver Alcantara, Sport Diff, B&O, 19" Peelers, Pilot Sport 4, SC Badges, Alu Kreuz, Endless MX72 brake pads, StopTech slotted rotors (front), APR Carbonio Stage I & II CAI. Winter shoes: OEM B8 S4 18" Wheels w/ Nokian Hakkapeliitta 7 Studless. Original owner; custom ordered.
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    ^This.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Pure speculation here but I believe there is a behavior difference when the center console shifter is pushed to the right (manual mode) vs. just using the paddle shifters in D or S. My understanding is that if the console shifter is pushed to the right (Manual mode), it will not downshift when you floor the throttle.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Jan 20 2014
    Calgary, AB
    Quote Originally Posted by doughboy17 View Post
    Not true. On my B8 when in D and trigger manual mode with the paddles the car will downshift when i floor it (have to engage the floor trigger).
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Mine downshifts and up shifts when I tell it to.
    May 15 2017
    Central TX
    The auto downshift and upshift can be disabled with a TCU flash. Is yours still on the stock flash?
    Aug 12 2015
    Minneapolis MN
    Quote Originally Posted by dave1078 View Post
    I do not have the TCU flash yet
