Results 1 to 32 of 32
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    Has your S4 ever broken down?
    What was the failure? What year and mileage?
    2012 S4
    Jul 14 2013
    British Columbia, Canada
    Thermostat, 80000km or 49k miles. Thats about it though and now I am at 107km or 66k miles. 2011 6MT.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Nov 30 2015
    Supercharger Pully @ 50k miles
    2011 DSG
    2011 S4 Premium Plus-Sprint Blue
    2009 Q5 Prestige-Ibis White
    2015 SQ5 Prestige-Moonlight Blue
    2002 A4 Avant-Light Silver Metallic
    2002 A4 Avant-Dolphin Gray Pearl Effect
    1969 Mustang Fastback-Acapulco Blue-62B 1 of 5,958
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    2010 with 65k. the infamous t-stat/water pump plastic impeller issue. was replaced under warranty in 2012, @24k mi. It caused a minor inconvenience - driving a few miles with the heat on high/defrosters on in 95 degree heat while en route to the dealership. Have not had an issue since, stage 2 tuned since 58k mi.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Jul 20 2016
    Slave cylinder went out at 22k miles. Clutch pedal was pretty much stuck to the ground. Covered under warranty though :)
    Senior Member Three Rings viceroy1976's Avatar
    Jul 11 2011
    2014 Audi A4 allroad quattro 2.0TDI
    Johannesburg/GA/South Afr
    Serpentine (alternator) belt went at around 100000km
    Clutch slave was starting to go around the same time.
    2010 6MT
    2013 Audi S6
    2013 Audi A5 3.0T coupe quattro s-tronic (S5 wannabe)
    2010 Audi S4 6MT
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    T-stat at 31k miles, just out of warranty by 2 months in early 2016.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Broke down 3 times, but the car has always made it home. T-stat, clutch, throttle body failure. 90k-118k
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    tstat @ 65k, crank pulley @100k, battery at 120k
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Senior Member Three Rings Dash's Avatar
    Jun 07 2012
    St. Louis
    T-Stat at 30k miles. Just about 2 weeks ago. $1500 fix! Ouch. 2010 DSG
    Seems common... Is that about the correct charge? The SA basically told me the T-Stat is under the Supercharger and it took them a solid day to get it done.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    My 2010 left me stranded on the side of the road twice. First when the plastic WP took a dump and about 6 months later when road debris punctured the IC radiator. Metal WP and DIY protector screen have prevented the same issues from recurring. Just waiting for the T stat to go now.
    Oct 10 2016
    1987 Dodge Ram, 2003 Dodge Ram,
    East Coast, USA
    2011 S4 DSG
    50K - AC Compressor (warranty)
    50K - Thermostat (warranty)
    50K - Water Pump (warranty)
    60K - Wheel bearing (warranty)
    101K- Intake Manifold runner ($1600 repair, didn't have time to do it myself)
    117k- Hard coolant line on front of motor, Thermostat, Supercharger bleeder screws. ($2200 if dealer did it, $200 for the DIY)
    Established Member Two Rings jnicho1's Avatar
    Jan 17 2012
    Baltimore, MD
    Thermostat at 48k last week
    2011 S4 6MT. Avoid the dealership if you're out of warranty and find an indie shop (or do it yourself).
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Quote Originally Posted by jnicho1 View Post
    The superstitious side of me is thinking this is kind of a s****y thread to create.
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    S5 here, 0 break down with 57K miles, guess B8.5 has many problems corrected.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Jul 05 2014
    Houston
    Quote Originally Posted by wangshuo1989 View Post
    Shouldn't have said that..
    Jan 13 2014
    nyc
    2015 s4 5300 miles. Beautiful machine
    Senior Member Three Rings viperbenz1's Avatar
    Mar 11 2012
    boston ma
    2012 s4 6MT T- stat and water pump at 48k
    May 15 2017
    Central TX
    Not seeing any b8.5s with t stat or water pump issues.
    Oct 10 2016
    East Coast, USA
    Quote Originally Posted by dave1078 View Post
    They superseded the parts from the B8 to the B8.5.
    The original (B8) water pump was plastic and recall/warranty put in an aluminum/cast one. Thermostat was designed. Similar, but more efficient.
    2011 S4 | Phantom Pearl Black | Unitronic Stage 2+ ECU & TCU | Roc-Euro Intake | Airlift 3P Air Ride | ECS Drivetrain mounts, Skid Plate, Boost Gauge, and Carbon Wing | Strafe Design Aero Splitters and Diffuser | 20% Tint | RS4 Grill
    Mar 21 2015
    14 with 15k miles and my pump was leaking slightly. 20k miles and plastic front coolant pipe had a small leak also.
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    Quote Originally Posted by Dash View Post
    that price is high. a good tech with knowledge, skills, tools etc should be able to do that job in under 4hours, I know the bookrate is something stupid like 6-7 hours, but it is not a full day job.
    I paid $900 at the dealership after going back and forth, they wanted $1300 originally and i told them to pound sand.
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Apr 04 2012
    MSP
    No it hasn't ever broken down.
    Nov 06 2013
    Australia
    B8.5 45000km currently in shop due to waterpump leaking.
    Apr 04 2012
    MSP
    Is OP asking if the car's ever had an issue? Or if it's left you stranded? Those are two very different questions.
    Jun 07 2012
    St. Louis
    Quote Originally Posted by Johnnycash View Post
    Bummer! They did actually give me 10% off the $1500 quote.... but still.
    Jan 09 2016
    How did you find those leaks?
    2021 BMW 540i
    Mar 21 2015
    I started smelling coolant when I would pull into the garage and park it. I hunted for the leaks for a couple weeks, could never find the source so took it to dealer and had it pressure tested both times under warranty.
    Jan 09 2016
    Cool, thanks!
    2021 BMW 540i
    Aug 11 2015
    Quote Originally Posted by MrFunk View Post
    If the car has been totally disabled. It would be useful to see what pre-emptive repairs might be smart, as mileage gets higher. Especially before an extended road trip. So far, old water pumps are prime suspects. I think most of the bad bad thermostats have been replaced already.
    2012 S4
    Jul 31 2014
    Mpls, Mn.
    this is why dealerships get so much hate is because they use questionable tactics to charge high rates, and most people acquiesce out of convenience or fear.
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    My waterpump started leaking at 65,000 miles and was replaced. Never has left me stranded though, am currently at 73,000 miles.
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
