Results 1 to 22 of 22
    Established Member Two Rings Dwightlud's Avatar
    Jan 08 2016
    2006 A4 Avant
    Eagan, MN
    Just purchased 2008 A4 S-line-fault code question-Updated with pics.
    Just got a sweet deal on a 2008 A4 2.0L S-line. The car has 57,000 on it and is in pristine condition. I test drove it two different times over a period of two weeks and it performed great. Before the purchase I did a scan with my VAG-COM and came up with this entry and I'm not sure what to think of it. None of the numbers match to any of the trouble codes in my Bentley manual
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0801
    Coding: 04141
    Shop #: WSC 06335
    VCID: 41DC4FE6189E371F627-4AA4
    1 Fault Found:
    02071 - Local Databus
    37-10 - Faulty - Intermittent
    Nov 21 2014
    Montreal
    Congratz, post a pic of the car we would like to see it. How much you got it for?
    Looks like an issue with wires somewhere:
    http://wiki.ross-tech.com/wiki/index.php/02071
    Oct 24 2015
    Perth, WA
    My respray thread
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Could also be something as simple as water in the ECU box, pull the wiper arms and pop the ECU cover, water in there will throw random errors but usually more than 1...
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by mgfranz View Post
    That's a simple cause, but not a simple problem. It's generally an electrical nightmare.
    -Adam
    Apr 08 2016
    Mission Viejo, CA
    Yeah, I had like 3-4 codes when I discovered my ECU swimming pool...
    Jan 08 2016
    2006 A4 Avant
    Eagan, MN
    $12,500
    Veteran Member Three Rings A4B7Avant's Avatar
    Jun 07 2017
    PA
    MT or AT?
    You may have the SE edition instead of the true S-Line package.
    2019 A4 P+ Brilliant Black, Black Optic, Sports Pkg
    2008 A4 Avant SE Ibis White SOLD
    Jan 08 2016
    2006 A4 Avant
    Eagan, MN
    Tiptronic, and I believe you are right about this being an SE. It has the S-Line badge on the front, but it does not have the badge on the steering wheel, and the wheels are 17".
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    57k...brand new! Congrats!
    Jan 08 2016
    2006 A4 Avant
    Eagan, MN
    Also, with respect to the fault code, I have not had any indication of any intermittent electrical problem. I will be checking my ECU this evening for water.
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by Dwightlud View Post
    Before you do that, verify that your cruise control is working, being that it is an intermittent error reported could be something as simple as trying to operate the bluetooth without having the phone paired. Basically the error is reporting that something in the multi function steering wheel is not doing what it's suppose to.
    2008 Audi B7
    2003 Ford F250 XLT
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Congrats man. More pics of the car in different angles please.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Veteran Member Four Rings z_wrecker's Avatar
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    This! Do you have an aftermarket headunit? I've had the same soft code for years now. Everything runs as it should. I wish it was more specific.
    2018 Alfa Romeo Giulia Quadrifoglio
    2014 Arctic White B.O. S5 Prestige manual w/ sports diff
    2002 Arctic Silver Metallic Boxster manual
    2018 Daytona Gray Q5
    2018 Daytona Gray B.O. S4 -Sold
    2009 Pearl White Ducati Monster 696 with Termi race kit, and a bunch of CF -Sold
    2008 Ibis White A4 s-line manual -Sold
    Jan 08 2016
    2006 A4 Avant
    Eagan, MN
    I did engage the cruise control, but I did not test any of its other functions such as accelerate or decelerate. I will check this out on the ride home tonight. I did notice that there is no phone cradle in the center console. Would pressing the phone button on the steering wheel cause this fault if the phone cradle is missing? I have a 2006 A4 Avant that is also missing the phone cradle and there are no codes like this on that vehicle.
    Jan 08 2016
    2006 A4 Avant
    Eagan, MN
    Quote Originally Posted by z_wrecker View Post
    Nope, everything is stock.
    Jan 08 2016
    2006 A4 Avant
    Eagan, MN
    A couple of people asked for more photos so here goes. I also found the original window sticker for the car and a list of options on a sticker in the owner's manual. It shed some light on some of the points people brought up here. Apparently this car is an SE with an S-Line exterior package, so not a true S-Line. I'm not sure what the point of that was. I also found out that it was setup for an iPod. Sure enough, when I took a closer look in the glove box I found the cradle for the iPod.
    http://s1376.photobucket.com/user/Dwightlud/slideshow/
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    they made all 08s with sline badges/exterior but not all true sline interiors
    if you knew that and your question was why, then i have no clue either
    looks good tho, really clean
    Oct 09 2007
    Miele S7
    The 'S-Line' package gives you a little bit more 'sportier' features than the standard version such as the pedals, door sills, 3-spoke steering and sport suspension - which can also be a standalone option. I might miss one or two items like wheels but this is what you get for a few extra bucks.
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    Quote Originally Posted by tloft4 View Post
    To try and re coup lack luster sales, you ever compare the A4 to a Passat? Why pay the extra lol
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    May 15 2016
    Lock Haven, PA
    poor sales of a4 or slines? a guy i know has a passat that i THINK is a 3.2 that looks much better optioned than pretty much any b7, so maybe its a diff gen ( much diff key fob) but definetely not too new.
    Jun 07 2017
    PA
    It was the end of the B7, so they slapped on some makeup on the old hag and pimped her out!
