Hello fellow drivers,
Driving an '08 A4 b7 2.0t, 141k miles manual transmission. Had a check engine light pop up 3 days and 50 or so miles ago, finally had a chance to check it out. Code p0299, turbocharger underboost. never replaced the turbo on this car.
Symptoms: Not pulling consistently in first and second gear, slower than normal. I also put in a half quart of oil a week ago, and the light just popped up again saying I was down a quart, indicating I've burned through a little more than normal. Around 100 miles driven since I put that oil in 1 week ago. Seems like I've gone through a little more gas than normal but I can't tell for sure, been a lot of around town miles as of late.
I was looking into replacing the turbocharger re circulation valve, which was suggested by a local autozone/this error code, understand this is a $250 to $350 job unless I hear otherwise (I have no lift, so it will go to a shop). Called around, local Audi dealership said code could also indicate the need for an entirely new turbocharger... quoted me around $2500 over the phone. Not sure if the usual dealer talk or being serious.
Questions: 1. How far can I drive this car without wrecking the engine? 2. Does this look like the simple valve fix or a bigger turbo problem? 3. If I take it to a shop that isn't a dealership, what would I expect to pay to replace a turbo?
Any advice, help, etc. is greatly appreciated. I'm used to the NA engines and this is my first turbo from Audi.
