Results 1 to 9 of 9
    Veteran Member Three Rings Fourpoint282's Avatar
    Oct 11 2015
    Atlanta, Georgia
    Is this water in my brake fluid?
    Just flushed brake system. Fluid was maybe 3 years old (tops) and only about 20k miles on the fluid.
    It looks a bit like oil and water when the two mix. There doesn't appear to be much, but several beads of something (assuming its moisture) in the fluid.
    Anybody know what this is?
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    Doesn't make sense as the water would be on the bottom. Might be gasoline or another lighter oil. But you'd probably figure it wouldn't separate.
    Headers to Milltek non-res catback, LWFW, LWCP, JHM synchros, 034 Mounts & end links, BC Racing Coilovers, Stern adjustable UCAs, RS4 Hotchkis anti-sway, JHM 93 tune and short shifter trio, Brembo 18Z, 19" RS4 reps.
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Brake fluid is hygroscopic, which means that it mixes with water. You can also wash it off with water, if you spill it. Those bubbles in the fluid look more like oil, if you ask me.
    #1 is contaminated old brake fluid with moisture in it (2 year old)
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Oct 11 2015
    Atlanta, Georgia
    Quote Originally Posted by ven0m View Post
    Interesting...how is motor oil mixing in brake system? They're two separate systems, how is this possible? And if it is oil, what does this me And?
    May 10 2015
    Slovenia
    No idea if it is motor oil. Could be grease when somebody before tried to lubricate the dust boots on the brake pistons or something.
    James May: "Yes."
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    hygroscopic means it absorbs moisture easily (leaving a brake fluid container open for a couple hours will ruin it)
    Oct 11 2015
    Atlanta, Georgia
    It's likely grease as I had to disassemble the calipers for powder coating. I lubed the Pistons a pretty good before install. Sounds like it's fine as caliper lube should be ok to mix w/ brake fluid.
    Someone mixed dot 3 in your ride
    May 10 2015
    Slovenia
    Quote Originally Posted by Fourpoint282 View Post
    Depending on which grease you used for lubrication?
    Popper caliper piston grease like "ATE BREMSZYLINDER-PASTE" disolves in the brake fluid. I use it on my brake pistons and I don't get such spots in my brake fluid.
    (link to product http://www.ebay.de/itm/ATE-BREMSZYLI...-/151080931542)
    Quote Originally Posted by jakeoboy67 View Post
    Potato potatoe. We both meant the same thing.
    James May: "Yes."
