Hello,
I have an 2001 Audi A3 1.6gasoline, AVU engine.
I have the car for a year and I have a problem with cooling system, instrument cluster and automatic air condition.
1. When I put the ignition on both fans are starting and run until I put the ignition off. If I start the engine the fans keep working without interruption.
My water indicator from the instrument cluster shows only 60-65 degrees. I looked into air condition hidden menu on channel 49 it shows me all the time 121 degrees while on the 51 channel it start from 25 degrees these days when it is warm outside and rise up to 75 degrees. Whatever I do I can't raise that temperature which I think is normal while fans are working in stage 2.
2.In the instrument cluster(which is Magnetti Marelli code 8L0920900) it shows me water sensor warning (in yellow) and oil sensor warning(in red).
3.My conditioned air compressor don't start at all.
As you can see from my vcds log which is listed bellow on the engine I have a fault with my thermostat which was changed with a new one last summer.
At instrument cluster I have 2 faults regarding temperature sensor G2 and one regarding oil temperature sensor G266.
Water sensor G2 was also changed last summer when I changed the thermostat.
But even with that I keep having the same problem.
Regarding automatic conditioned air I have 2 errors:
Temp Sensor in Instrument Panel (G56)
and Fan for Interior Temp Sensor (V42) which is working(when I start A/C it start to spin, i saw it...)
Please tell me if you know what to do with my car.
Saturday,10,June,2017,16:30:57:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAU ZZZ 8LZ1A 00 2228 License Plate: SB11JDE
Mileage: 208590km-129611mi Repair Order: 1
Chassis Type: 8L (8L - Audi A3/S3 (1997 > 2003))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAU ZZZ 8LZ1A 00 2228 Mileage: 208590km/129611miles
Address 01: Engine Labels: 06A-906-033-AVU.lbl
Part No: 06A 906 033 J
Component: SIMOS33 1,6l 2V 00HS3488
Coding: 00211
Shop #: WSC 06435
VCID: 26431013C212D62ECEF-5000
WAU ZZZ 8LZ1A 00 2228 AUZ5Z0Y6102048
1 Fault Found:
17700 - Map Controlled Engine Cooling Thermostat (F265)
P1292 - 35-10 - Open Circuit - Intermittent
Readiness: 0000 1000
Address 03: ABS Brakes Labels: 1J0-907-37x-ESP-F.lbl
Part No: 1C0 907 379
Component: ESP 20 CAN V005
Coding: 18945
Shop #: WSC 06435
VCID: E7DDDD1785988F26B59-4A9C
1 Fault Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0101
Coding: 01040
Shop #: WSC 06435
VCID: 2D51EF3FE7E4E5760F5-2580
2 Faults Found:
00785 - Temp Sensor in Instrument Panel (G56)
30-10 - Open or Short to Plus - Intermittent
00796 - Fan for Interior Temp Sensor (V42)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 3008
Coding: 00104
Shop #: WSC 06435
VCID: 4581B79F5F543D36E75-50E6
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 900 F
Component: KOMBI+WEGFAHRS. M73 D54
Coding: 08042
Shop #: WSC 39837
VCID: 2E53E833EAE29E6E36F-49D8
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
29-00 - Short to Ground
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14913
Shop #: WSC 06435
VCID: 2C57E23BDCFEEC7E18B-4E42
No fault code found.
End ---------------------------------------------------------------------
