Results 1 to 20 of 20
    Established Member Two Rings ScottNH's Avatar
    Jan 23 2014
    NH
    A4 B6 Alarm Siren trouble
    Recently the alarm siren on my B6 sedan started acting up. After I lock/alarm the car, I get the "chirp," and then the alarm starts beeping and doesn't want to stop. Here's what's happening:
    Based on reading here, I thought the problem was the battery in the alarm siren, so I replaced the siren unit with a new one. Same problem.
    Sometimes I can cycle the fob to lock/unlock/lock, etc. and get it to stop. Sometimes I can get it to stop by putting the key in the door and cycling the alarm.
    Any ideas what I'm looking at here? Starting to drive me slightly crazy.
    Thanks for the help.
    Apr 15 2014
    Ottawa/Gatineau Canada
    Battery. Just unplug the alarm until you find a replacement, or if the alarm PCB is not burnt you can swap in a new battery.
    http://www.audizine.com/forum/showth...1#post12049520
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    I would unplug it also, when those batteries start to deteriorate they leak acid onto the circuit board making it pretty much useless and causing weird issues just like you're getting. Eventually the h12 alarm horn stopped working all together. I would say unplug it now because it can short out getting into the connector then your cutting and splicing, not hateful to do but the down time of ordering a connector and wires to splice from the dealership can possibly be avoided now.
    You win some, you lose some...
    Jan 23 2014
    NH
    Quote Originally Posted by Luxus Panzer View Post
    That was my first thought, but I just replaced the siren unit with a new one. The video is from after I replaced the unit.
    Dec 30 2014
    South Carolina
    Pull back the harness and look at the wires as well as down into the connector.
    Dec 30 2014
    South Carolina
    It's possible the new siren is having the same deterioration as the previous unit. Was this purchased used?
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Quote Originally Posted by KHARDa4 View Post
    Good advice. When the batteries leaked on my unit they leaked badly enough to corrode the connector pins.
    Jan 23 2014
    NH
    I took a good look at the connections when I replaced the unit. All looked good. No signs of battery leakage on the unit or the wiring.
    I have access to another unit (known good), so I'll swap again and report back.
    Irritating as all get out.
    Dec 30 2014
    South Carolina
    You wont see it from the outside of the case, you would see corrosion down on the terminals of the alarm horn. If the old one damaged the connector it could be shorting the new one out.
    Jan 24 2010
    Paramus,NJ USA
    I agree to check the connector internally also peel back the rubber boot and look at the terminals from the other side.Mine were shot.The board was toast.If that all turns out fine.Check for water in the ccm or scan for faults.I've seen bad wiring at the door hinges do this on b6 cars all the time.The wiring for the door normally brakes in the hinge point.This is a common issue on these cars.
    Ziddy Autowerks
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    I too did the remote battery. Pics here: Alarm-Beep-Stop-Working-DIY-Fix. Probably overkill for most owners.
    Active Member Two Rings khancept94's Avatar
    May 30 2017
    2004 Volvo XC90 2.5T
    Oregon
    i just got done peeling back the trunk liner to unplug the thing today. It was at the point where itd sound every single time i locked the car. Also heard faulty wiring to door latches/ trunk and hood latch may be the culprit. The siren looked in good condition besides the dust collected in that compartment. No signs of corrosion or anything. Just a temporary fix until i can get the system scanned :) no more people staring at me in parking lots when i lock my car haha
    Jan 23 2014
    NH
    Quote Originally Posted by khancept94 View Post
    I'm pretty close to that point (disconnect) myself. Examination of the connector leads and the siren connectors reveals no signs of corrosion or leakage. I'm going to check it later this week with a known-good unit (from my other A4, hence the delay) and see. I'll also scan tonight and see if that reveals any good info.
    Established Member Two Rings Rubba's Avatar
    Feb 12 2016
    A6 C7, Passat B7
    Libya
    Remove and put back the fuse
    Aug 27 2013
    Philly
    You cant see if the batteries are leaking without cutting open the unit. I bet you have another unit with a similar issue as your first one.
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Few months back my alarm started randomly going off. The hood latch sensor wires were severely deteriorated and were the cause. The "hood open" icon wasn't displayed or anything. I just unplugged and removed the entire thing, and issue was resolved. Note, if you unplug it, if your low oil light comes on you will need to jumper across the wiring again to trick the car into thinking you opened the hood and topped up the oil otherwise the icon won't go away :)
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Apr 15 2014
    YOU MUST IOPEN THE UNIT.
    IT MUSR BE CUT OPEN.
    THEN YOU WIL SEE THE PROBLEM (99%)
    Hope I/we have been clear enough. Good luck
    - - - Updated - - -
    YOU MUST OPEN THE UNIT.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Jan 23 2014
    NH
    - - - Updated - - -
    Is that directed at me? Because I'm not opening anything. I'm replacing the unit.
    O-level maintenance all the way for me.
    I just have to wait for the unit.
    Apr 15 2014
    Quote Originally Posted by ScottNH View Post
    If $$ is no obstacle, you have the correct course of action.
    Jan 23 2014
    NH
    Haha. If $$ was no obstacle, I'd just buy a new car when something like this happened.
    But, for $35 shipped for the part, I'll replace it, and I'm happy to report the problem solved. Seems like my first replacement siren was defective. Back to "chirp" with no "after-chirping."
