Results 1 to 40 of 43
    Dec 05 2016
    Westminster, CO
    Shaving down caliper to clear wheel, good idea?
    Long story short, my ADV1 wheels barely don't fit over my S7 brakes, mainly because the calipers taper front to back (see below). Since nobody wants to buy them for some reason, I have thought about shaving the backside of them so I have 1-2mm clearance. Anybody done this before, and if so, how much shaving is too much?
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    If rather add a 3mm spacer.
    Sent from my SM-G935V using Tapatalk
    Dec 20 2006
    CAN
    Massive S7 brakes? lol. IF those wheels don't clear the S7 brake calipers, you can be sure as shit they won't fit an RS7 fyi. I would recommend not claiming they might fit an RS7 unless you can prove otherwise.
    Yeah, just add a spacer dude, easy solution.
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Headliner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Nov 18 2014
    Jersey
    would never do that. spacer or change your wheels.
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    Dec 05 2016
    Westminster, CO
    1. S7 has 400mm brakes, RS7 have 380mm brakes. The only ones that are bigger are the carbon ceramic brakes at 420mm. So I would be willing to bet that they fit the RS7.
    2. Spacer would probably do nothing, as the caliper is not hitting the spoke, it rubs on the inner barrel of the wheel. I could check and see if the wheel barrel is tapered, but I am already on a bit of a poke as-is with the lower offset, so I-d like to avoid the spacer (if that would solve the issue in the first place).
    Mar 29 2014
    Hampshire, UK
    You have the wrong wheels... Cut your losses, sell the wheels, and buy the right set to fit your car. Simple really.
    No one with an RS7 will want to downgrade to S7 brakes, so Im not sure why thats even entered the discussion thread.
    The S6 brakes (or S7 since they have in fact an identical brake set -up) would be considered an upgrade to an A6 or A7, and may be of interest to those who are tuning the 3.0T engine.
    The question you should be asking is what can you replace the existing S6 brakes with, that are equal or greater in performance than the OEM ones.
    Standard RS7 brakes may work, but its going to cost you $$$ unless you can find a set from a breakers yard, or from someone who is upgrading to ceramic. You need callipers, discs and pads from the RS7 set up. Suggest you find someone with an RS7 and see if your wheel will actually fit before you buy!
    You may find a specialist motorsport supplier who can supply something like AP racing brakes as a complete set, which may be smaller and lighter than the OEM set.
    So Im going to ask.... How did you end up with wheels that don't fit your car?.....
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    Quote Originally Posted by RAF_S7 View Post
    ^That's the golden question.
    If the manufacturer or dealer said they'd fit but they don't, I'd raise hell.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Dec 20 2006
    CAN
    Quote Originally Posted by ericw. View Post
    I'll make a guess and say he bought them used assuming they would fit given that he had to bore them out to begin with before finding out they wouldn't clear the brake system.
    Apr 23 2011
    Sac Area, CA
    Quote Originally Posted by CanuckRS View Post
    What did he bore out? The wheel hub ring?
    Sent from my SM-N920P using Tapatalk
    IG @lolzhax
    //AGILITYDRIVES.US
    Dec 20 2006
    CAN
    http://www.audizine.com/forum/showth...75-35-19-tires
    Apr 23 2011
    Sac Area, CA
    Thanks! What a mess. 🙄
    IG @lolzhax
    //AGILITYDRIVES.US
    Mar 29 2014
    Hampshire, UK
    Ah, that explains a lot then.
    Dam shame, good looking set of wheels there....
    I still think selling the wheels on (maybe without the tires - easier to ship) would be the best thing do do here. - or - Buy two front wheels that actually fit, and match the rears since they are already custom....
    Dec 05 2016
    Westminster, CO
    1. I bought these used under the impression that any 19" rim would work on an S7, as that is what my car came with. Lesson learned that is not the case.
    2. I bored them out so that they would fit on a 66.6mm hub, as they were made with a 57.1mm diameter.
    3. Yes, it would be nice to sell them and get a decent 20" setup, but I have listed them here, CL, and now eBay with no takers. So now I am getting desperate to either sell them for a four figure loss, or make them work on my car.
    4. I wasn't suggesting an RS7 "downgrade" to S7 brakes (even though it would be an upgrade), I was suggesting that since the RS7 has a smaller diameter brake setup, these might work for an RS7 as a track or strip wheel/tire setup. Very likely would be reducing a lot of unsprung and rotating mass using a 19" setup versus a 20" or 21" setup.
    Nov 03 2007
    A6(C7.5), Q7(4M), Q5, A5(B8.5), Escalade(MY08/MY15), H2, 360
    What part of the caliper is actually hitting? and what part of the wheel is hitting?
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Cut your losses and move on before you cost yourself more money.
    May 17 2016
    Seal Beach, CA
    can you highlight the area on the caliper you need to shave and how much needs to be shaved off? In my 26 years of modding cars most of my friends and myself have shaved down calipers dozens of times with no issues. As long as its a small area and only a few MMs on a "meaty" part of the caliper that won't compromise the strength or function of the caliper, it should be fine. Better pictures would help.
    Dec 05 2016
    Westminster, CO
    See red area:
    Nov 03 2007
    just run a 3mm spacer
    Oct 13 2016
    El Paso texas
    I would try half and half shave the caliper 1-1.5 mm and run a 1-1.5 mm spacer it will be fine. Believe it or not the front fenders have more room then the rears to fit wider wheels
    May 17 2016
    Seal Beach, CA
    LOL at all of the people suggesting spacers. If they actually read the whole thread they would know that the caliper is rubbing on the barrel, not the face so spacers won't do shit for you. Thanks for the pic with the circled area on it. How much needs to come off of that hump to clear the barrel? Looked at my stock S6 calipers today (have the RS6 carbon ceramics now) and the area you circled can be ground down a few MM no problem IMO. How much is it "off" by? if its only 2-3 mm, I say grind it down. You are only grinding a narrow strip (to remove the peak) and 1 mm of clearance is all you probably need. Grind it while its on the car, only do a little at a time and keep testing the fit until it clears.
    Dec 05 2016
    Westminster, CO
    Quote Originally Posted by Horti Kris View Post
    Exactly. I'm going to give it another shot this weekend. I just moved and now have all my tools at my new house, so I can get calipers, feeler gauges, etc to get a more precise story.
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    Quote Originally Posted by WhiteWhiteS7 View Post
    You can totally shave the caliper down a bit and it can be done quite simply. Theres nothing on the outer perimeter of the caliper other then the casting material itself. It will not compromise the integrity of the caliper in any way shape or form.
    Still would never run a 19" wheel on or cars as they look way too small but shaving the caliper down is a non issue.
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    May 17 2016
    Seal Beach, CA
    Quote Originally Posted by madyspop View Post
    21's and done.
    Dec 05 2016
    Westminster, CO
    I would never run a 21" rim, looks terrible. 19" or 20", that's it.
    Mar 11 2007
    Colorado Springs
    Yes Massive S7 brakes...they are bigger than stock RS7 brakes except for the ceramic. They are big!
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Mar 11 2007
    Colorado Springs
    See red area:
    As most have said get a different wheel, or use a spacer. Altering the caliper is ridicules. Good luck.
    2012 A8L 4.2
    Dec 05 2016
    Westminster, CO
    Here are some pictures to show what I was up against:
    Wheel on the hub, but does not sit flush with the brake rotor. As you can see, I have no issues with spacing between the caliper and the spokes, as many people who thought was my issue:
    Next, I put a flashlight behind the wheel to see where it was hitting the caliper. Indeed, it is on the top and bottom of the caliper, but in general, it would need to be clearanced the entire back side of it:
    Next, I used a square to see if the barrel is indeed tapered. Yes it is, but the way the ADV1 wheels are machined, a lip is forged into the barrel right where the caliper hits (about 5" away from the wheel mounting face). I can only assume that this is where the RS4 brakes are since this wheel was meant for that car:
    I got my stock 19" rim and looked at that. It has more taper, and no lip, hence why it fits (with about 2-3 mm my guess):
    Bottom line, it will take a fair amount of grinding to get the wheel to fit. The other problem is that the bolt heads for the caliper are close to the surface of the caliper and would possibly need to be ground down as well. To the "spacers" people, yes, your idea might have worked (whether you understood the original problem or not), but I'm guessing at least a 10-15mm spacer would be needed to move the wheel barrel far enough away to have the beveled caliper edge clear the lip. Talk about poke....... I also roughly measured the rotor diameter. Eyeballed it at about 15.5", which translates to 394mm, so yes, bigger than RS7.
    Still for sale.
    Nov 03 2007
    Sell these wheels and buy the proper fitment wheels. not worth damaging your calipers for a set of wheels. These should fit a Q5 even a A5/S5, post these in the 19" wheel classified
    Dec 05 2016
    Westminster, CO
    Quote Originally Posted by lx4life View Post
    I did, not one offer. Even threw in the tires for free.
    Nov 03 2007
    I think you scared most buyers off with your situation even though its not bad. I just think people are more apprehensive because of the issues you are having. You might have to cut your losses hard maybe even lose close to 1k just to get right. Separate the tires and wheels to get more buyers. Good Luck though!
    Veteran Member Three Rings Frenetic's Avatar
    Dec 13 2015
    '17 Audi S7
    CA
    I wouldn't personally touch such a critical component in the manner you are describing.
    While it may seem cosmetic only, you never know, especially as tolerances get smaller and smaller, tighter and tighter. Some Audi engineer could have designed it with a certain mass and shape in mind to dissipate a certain amount of heat under worst-case conditions. Modifying that could negatively impact those properties. While such components are typically robust, why risk it?
    I would just mark this up as a lesson learned and move on. List them on Ebay, Craigslist and just be patient. Such items aren't fast movers, but keep listing them as one day, someone looking for such wheels will eventually stumble upon them and deal done. If you get no takers after a few months, lower the price and keep trying. Good luck.
    Dec 20 2006
    CAN
    Food for thought.
    If you think it's a pain in the ass selling mangled rims, just imagine how easy it will be to sell the S7 with shaved calipers. That kind of mod will leave interested buyers scratching their heads and wondering what the hell else is wrong with the vehicle... Just my 0.02c. I know I wouldn't touch it with a ten foot pole.
    Apr 29 2016
    2021 Q7 Prestige
    Los Angeles, CA
    Not quite the same example but I had a mod'd Infiniti Q70S - and I just had to have a certain wheel on it. The wheels I put on require that I grind the stud 1/8" (1 thread) to get a perfect hub fit. When I went to sell it...I gave the records to the new owner. He was not happy about the ground studs - so I had to have new studs put on all 4 wheels and put the stock 20's back on. I learned to never ever do that again unless I was keeping the car. Had I traded it I'm certain the dealer would not have caught it...but that is not the point.
    With any running gear of the car...I just do it right.
    Veteran Member Four Rings IowaRS7's Avatar
    Mar 22 2017
    69 Camaro SS
    Iowa
    Consider your market. Look at what the wheels will fit on and go that route vs the cars in this group that will not be interested. There are also hubcentric ring adapters that would allow these to still work on a 57.1 hub. I run those on a set of volks on my GTI. Also, hard to tell from pics if the finish is dirty or needs repair, but maybe have the wheels powdercoated. Those are nice name brand wheels and have value, just need to find the right market.
    I would not modify my brakes to fit wheels. I would put my tail between my legs and move forward.
    Nov 19 2005
    Central IL
    Quote Originally Posted by Frenetic View Post
    I'd like to know how an iron caliper dissipates heat, especially one that's covered in powder coat.
    Nov 19 2005
    Central IL
    21" wheels look terrible on our cars? Yet you bought a hideous set of 19's that are heavy as boat anchors.
    I'm not seeing anything hideous here.
    Senior Member Three Rings S6Express's Avatar
    Jan 14 2014
    Miami, FL
    Yeah, my car looks terrible with 21" HREs, but shaving brake calipers seems logical to fit 19s . S7s have huge wheel wells that eat up those wheels. To each his own, I wouldn't put 19s on an S7, but I would never make a blanket statement about people's cars looking terrible.
    2013 S6
    Ibis White / Black Int / Innovation / Bang & Olufsen / LED Headlights / Carbon Inlays / Black Headliner / Sunshades / Cold Weather
    Mods:
    HRE P47SC 21" x 9.5" Wheels / RS7 Rear Diffuser & Oval Exhaust Tips / Red Bembos / Bigger Rear Spoiler / Dead Pedal S6 Badge / Black Wrapped Grille Slats / Black Wrapped Grille Edge / Black Window Trim / K&N Drop In / Escort Max360 Hardwired w/ Remote SmartCord / VAG COM Mods / 35% Tint
    Nov 19 2005
    Central IL
    Shaved calipers, wouldn't know it if I didn't tell you. No ill effects just the pros of not being handcuffed to certain wheel fitments.
    21's....
    Dec 13 2015
    '17 Audi S7
    CA
    Oh, I honestly don't know. I was just speculating. However, I doubt they build things to tolerances that allows anyone to randomly shave things off without some impact.
    Senior Member Two Rings goliath1's Avatar
    Apr 13 2014
    custom built softail
    RI
    The vast majority of the energy is dissipated in that heat sink called a rotor. Some heat in the brake pad and even less in the caliper.
    2016 S6 Mythos Black Metallic, B&O Sound, Sport Package, Driver Assistance, Comfort Seating, Black Optics, Audi Exclusive Interior.
    My wife said its golf or her, gosh I'll miss her!!
