Couple notes assuming healthy plugs:
1. You won't see any more power unless you run a bigger gap - that's the benefit of better plugs, the ability to run a wider gap
2. Manfuacturers tell you NOT to gap Iridium plugs. Not to say you can't, but odds are good you may regret it (fatigued components, popping off or chipping the bonded Iridium)
3. With crummier plugs, a smaller gap with lots of boost may fire more reliably.
4. Colder plugs with lots of boost may prevent the sparkplug from getting overheated and acting as glow plug - depends on the engine and tune if that is needed or not.
All that said, in my past "Stage 3" builds I've run Denso Iridiums with a .044 gap one step colder than stock and had great results up to about 30PSI. If I can find out what the gap is on those RS7 plugs I may try those instead this time as they look like a good design. If you want to do more than guess or follow "Internet wisdom", This is a good book that while pimping his stuff also has lots of good info to help you understand all the variables that go into ignition and how to get the most out of your plugs
https://www.amazon.com/Doctors-Step-.../dp/0965085600
