Results 1 to 40 of 41
    Senior Member Two Rings torrque's Avatar
    Aug 25 2015
    Andretti
    Braided brake lines... worth it ?
    Ok, my brakes are spongy. Or at least compared to the Brembos in the Shelby , they are very mushy, to the extent that I hate them now.
    Do stainless steel braided lines make a difference ? I never changed in any of my cars, as I always had good brakes..
    My 2001 GTi has Awesome brakes compared to the POS A4.
    Bought some new Motul Fluid I used to run on the track, RBF600, but wondering if I should do brake lines too.
    Thanks all.
    2016 Shelby GT350 Track pack - 6Gr wheels, otherwise stock
    2008 BMW 335XI sedan 6 SP Manual
    2001 VW Golf GTI VR6 5 sp Manual - Giac stage 1, intake
    Gone but not forgotten: 2013 Shelby GT500 .... sorely missed.
    Jun 17 2013
    jersey city nj
    worth every penny
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Quote Originally Posted by torrque View Post
    Thanks all.
    Stainless steel brake lines will wear out faster than your standard rubber ones. If you read the info on them they are designed for racing and meant to be changed after a certain amount of use. However, I can't say that they will improve or not improve anything. I guess in theory they should since they're designed for race use...If you're having spongy brakes you should check your fluid level and maybe even change it out. You may have old dirty fluid in there and you may have debris in your lines. If you are missing fluid then you have a leak somewhere and you should address that...brake fluid does not evaporate.
    Aug 25 2015
    Andretti
    Quote Originally Posted by i3oricua View Post
    Thanks, not missing any... Been changed 2 years ago when I did all pads and rotors... Used Audi oem fluid. Did some very aggressive mountain driving a few months ago, and they fade like crazy after 20 applications...
    It has been just city driven lately, so no need for extra braking, but just feels spongy.
    I will just flush to start with, but I was wondering about brake lines.
    Jan 13 2016
    They definitely make more of a difference than I thought they would, as far as "wearing out" faster I haven't had any issues after almost 80k miles.
    Mar 24 2013
    Oakdale, CT
    I ran my last set for about 60k with no issues, so while the life may be shorter, it's still totally acceptable for street use.
    -Adam
    Veteran Member Four Rings 4rings5stars's Avatar
    Jul 31 2011
    I can't imagine how they'd wear out quicker. It's essentially a corset of metal around the brake hose to keep it from expanding under pressure. Which is why they work well.
    Oh and get better pads. Makes a world of difference, too. And lastly some Tyrol pins. Best you'll do outside of a 17z upgrade
    The fleet
    2000 S4 EPL tuned Stage 3 -- Silver/Panda -- Latest fun project
    2002 S4 Avant 6spd -- Nogaro/Silver -- Long term rehab project
    2012 A8L -- Night Blue Pearl/Nougat
    2013 VW Touareg VR6 Lux -- Flint Grey/Black
    2001 BMW 540iA Sport -- Steel Blue/Grey
    2001 BMW 750iL -- Night Blue/Ivory
    2004 Jaguar XJ8 -- British Racing Green/Tan
    2005.5 A4 Avant 6spd -- Quartz/Black -- Sold
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by 4rings5stars View Post
    Cant go wrong with a caliper with multiple pistons for braking thats for sure...............
    Sep 17 2006
    Aurora, Colorado
    I'm not against the lines. I run them myself but just for FYI you can read the last 3 or so lines in the link.
    http://www.stoptech.com/technical-su...rake-lines-q-a
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    I had stainless braided lines in my B5. It was very noticeable compared to my wife's car, all else being equal.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    I've had this on my list of things to upgrade.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Jul 31 2011
    The way I interpreted it was the braid itself can wear through other objects, wires etc, after the protective plastic is gone. I can't recall seeing any failures in recent history, although like anything else I'm sure they exist. YMMV
    The fleet
    Jun 17 2013
    jersey city nj
    Ive on cars many years and Ive never SS lines protective plastic worn down. Well @ least on high quality lines that Ive . Cant speak for the cheap thats out there
    Aug 25 2015
    Andretti
    So you typically do front and rear, or just fronts ?
    Oct 31 2014
    NH
    I can't wait to make Mustang jokes to you.
    2014 Audi S4 - 6MT
    2000 Audi A4
    Veteran Member Four Rings yxri's Avatar
    Dec 27 2016
    Ford Lighting
    Ohio
    Definitely change your brake fluid. Brake fluid has a shelf life and needs to be changed every so often. This is because brake fluid soaks up moisture in the air.
    Jun 17 2013
    jersey city nj
    Most members here just 034 RSB's. They leave the oem fronts alone.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by adam044 View Post
    The joke will be if he tries to drive that sucker in the snow............. Well thats if he lives in a place that gets snow anyway....
    Jun 27 2011
    The brake stiffener bushings make a bigger difference than stainless lines. Worn out OEM lines that might be bulging and whatnot, anything will be an upgrade from that.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 24 2015
    Perth, WA
    Only ever as good as your tyres.
    My respray thread
    Jun 27 2011
    Quote Originally Posted by Okedokey View Post
    Yup. All the other stuff can make a difference in pedal feel though. And while that doesn't affect stopping distance it can make the car more enjoyable to drive.
    But for stopping distance reduction, really the only way you can reduce that is by getting stickier tires. That's just how physics works.
    -CP
    2017 Q7 3.0t
    Active Member Two Rings audisick99's Avatar
    Nov 16 2015
    Long island, NY
    Might want to do a brake fluid flush see if that fixes the spongy feeling
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    https://www.youtube.com/watch?v=6LJiPDAr9f8
    Aug 25 2015
    Andretti
    Go ahead, I don't mind, I love that car to bits nothing will sway me.
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    As Charles says above stiffener bushings may help with overall brake pedal feel. But the main factor (also mentioned above) contributing to a soft feel is air in the lines. So the first order of business is to do a proper brake bleed including a complete change of fluid. This is very easy to do. The caliper bushings can be assessed while you are doing this. If neither of these efforts help much then it's likely that the rubber brake lines have become compliant possibly due to age. Change to new lines front and rear. Stainless lines like the StopTech lines are stiffer so you may want to go that direction. Beyond that the only other things affecting brake system compliancy is the condition of the master piston seals and perhaps the softness of the brake pads. You may consider refurbishing the master cylinder/piston. Lastly, if brake work has been done on your vehicle in the past they may have used brake pad anti-squeal shims between the caliper pistons and pads. If not installed properly, they will add to the spongy feel at the brake pedal. Check all this while bleeding the brakes. If you go to stainless lines you must get exact fit and install properly (no unusual bends, twists, or stretch fitting) as stainless lines are much more stress sensitive to routing than OEM lines. This would be my approach based on what you describe.
    Aug 25 2015
    Andretti
    Quote Originally Posted by Brillo View Post
    Thank you sir. Will do flush first, and then decide if SS lines are needed.. I mean I can lock up wheels/trigger ABS right now, just that the pedal travels a lot for that to happen, and way more than I am used to.
    I am using OEM pads and Meyle rotors, on all 4 corners.
    Jun 27 2011
    The OEM pads are sorta garbage too. I would look into some aftermarket performance pads. OEM pads tend to offer weird braking performance.
    -CP
    2017 Q7 3.0t
    Established Member Two Rings RG4's Avatar
    Jul 25 2016
    NJ/NC
    Maybe look into drilled/slotted rotors? Increased cooling should help with brake fade. Definitely do SS lines. Made a world of difference on my mk6 GTI and planning to do them on my B8 as well.
    2010 A4 2.0T Quartz Grey
    APR Stage II | APR Cast Downpipe | AWE Touring Exhaust | aFe Dry Flow | ECS Turbo Inlet | GFB DV+
    Aug 25 2015
    Andretti
    I don't know... Mainly concerned with sponginess now.. Fade, different story, it's not a track car.
    Feb 15 2016
    Cambridge,Ontario
    Something is wrong and it has nothing to do with SS brake lines.
    My car is on oe pads and it stops outstandingly. Only issue is brake dust. Definitely sounds like air in the line or bad mc.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 27 2011
    Maybe they're fine and he's just used to a harder pedal in his mustang? Saying the brakes are spongy is a very subjective description.
    -CP
    2017 Q7 3.0t
    Feb 15 2016
    Cambridge,Ontario
    this is true ... but after driving my company 2016 Murano and then getting in The Audi I nearly fired myself through the windshield ( okay maybe no comparison )
    1976 Yamaha XS 360
    Sep 30 2009
    Indiana
    That's a good point. I just recently drove a friend's late model Shelby and the brakes were hard as a rock. The clutch had a very different feel as well.
    Aug 25 2015
    Andretti
    Ok. I spent 2 hours with the old girl today, and flushed all brake fluid with Motul RBF600. a full liter of it. Bled the brakes the proper way, with someone at the wheel, pumping, sitting on brake, bleeding. Pumping again, sitting on brake, bleeding.
    NO CHANGE. Still spongy. Maybe , juuuuust maybe a tad better which I expect due to newer fluid, but nothing to write home about .... Pedal travels over half way to lock wheels and set the abs in motion.
    Ok, not comparing it to the GT350, not fair. Those are new 6 piston Brembos front, and 4 pistons back, with floating disks which expand on a pin system for improved ventilation and cooling. After 10 laps on the track they were just like I started, rock hard....
    ... but My GTI which is 6 years older than the Audi, and has firmer brakes. I also have a water content meter for the brake fluid, and the GTI is older, it shows over 4% water. And brakes are still hard as a rock.
    Must be either : a. master cylinder problem of b.Crappy pads or/and disks.
    Did anyone successfully bled the abs pump electronically with vag-com and had improved pedal feel ? That is one thing I have not done.
    Sep 30 2009
    Indiana
    Question - With the engine off can you quickly pump up the system so that the brake pedal pressurizes at a higher level? Then turn the engine on so that the ABS is active and see if you can pump it up. And if you can pump it up with the engine on does the pedal slowly travel down? When pumped up (if you can) and slowly moving down points to the master cylinder/piston seals. The pedal moving half way down is not good and makes me think that there may be a region of corrosion in the master cylinder. If, when you get beyond that half-way point, the cylinder is good again, the piston seals might be re-engaging, and you are getting pressure back. If the above doesn't happen, that would point away from a master cylinder/piston seal problem.
    Sep 30 2009
    Indiana
    Further comments - If you can pump your brakes up with the engine on and the pedal holds its position that usually means there is too much compliancy in the system. This points to the pads, pad backing plate/anti-squeal system, or the old rubber brake lines. But from what your are describing the old rubber lines alone cannot account for that much pedal travel. Regarding ABS, with the engine on the ABS system is active but not functioning (because no wheels are skidding relative to the other wheels). In other words, the valves for each wheel in the ABS unit are closed and any air in the reservoir and ABS pump should not come into play. Bleeding the system as you have done should also bleed any air from the ABS unit on the brake pedal side of the valves. Only by having the ABS system function by you driving it and skidding one tire or one set of tires (as if one side of you car were on gravel and the other side on clean pavement) would there be the potential of re-introducing air back into the system (brake lines). This is air in the reservoir/pump side of the ABS system.
    Oct 24 2015
    Perth, WA
    I found the pedal bleeding was insufficient.
    My respray thread
    Jul 31 2011
    ABS Bleed via VAGCOM?
    The fleet
    Sep 30 2009
    Indiana
    Yes, if you really suspect air in the pump section of the ABS, VAGCOM, as I understand it, will have to be employed to independently activate the valves in the ABS unit to bleed them. I have to admit that I've never done this, nor have ever needed to do this but have successfully bled plenty of brake systems with ABS including a number of A4s.
    If torrque follows the steps outlined above he should be able to systematically determine what the problem is, and then determine if he needs to bleed the pump side of the ABS unit. He initially asked about ss lines, but what he describes sounds to me like it is way beyond what ss will solve.
    Okeydokey I'm curious why you found traditional pedal bleed insufficient. Any theory on why this didn't work for you?
    torrque Keep us posted on your findings.
    Aug 25 2015
    Andretti
    Yes, with engine off it is hard as a rock, it pressurizes very high. If engine is running, if you pump it it will become harder and stay up. But if you keep pressing the pedal, it travels down slowly about half way, point where it kinda locks up. pumping again will make it harder, etc.
    On the road, the feeling is pretty spongy, as to come to a complete stop like emergency lock, to get the abs to flash, you need to push it almost all the way down. Normal driving, probably half way.
    So there is braking, car can lock up wheels. But the feeling is not very secure. I remember on my wife's A3, I upgraded the caliper carriers to a TT carrier, and used TT disks which are bigger... I had improved brakes, and some of the sponginess was gone, but some has still remained. I wonder if the problem there was also ABS unit bleeding, as it was similar. Or all Audi brakes are like this, which I doubt. They did not win several rally championships on spongy brakes.
