Taking only load rating into account, you do not need XL tires on a S4 B8. You do need at least a 89 load index tire.
An S4 B8 can weight up to 2,300kg loaded (1800 kg for the car, 400kg for 5 x 80kg passengers, 100kg for 4 x 25kg language) or 575kg/tire (with the car loaded this way I would estimate a 50/50 weight distribution).
So we need tires with at least 89 load index (580kg). Most tires that fit our cars have a load index of 92 (630kg) or higher.
As reference, my OEM tires were 245/40-18 93Y
That said, a lot of people believe (me included, but I don't have any facts to prove this belief) that sidewall stiffness is related to (but not only determined by) load rating. The higher the load rating, the higher the sidewall stiffness for a given tire design/size/aspect ratio.
Here is a little info about XL nomenclature on tires
http://blog.tirerack.com/blog/bens-b...s-xl-stand-for . You can also look up your GAWR (my car is none US spec so I don’t have GAWR on my door placard) to double check.
By the way, 1kg=2.2lb.
