Story: On Friday I come out and I see that only my passenger signal light and passenger tail light is on, (car is off and parked). My key button to unlock the car did not work so I manually keyed in. I enter the car and could smell something had burned. After checking all the fuses everything seemed fine, even the relays. After more digging around I inspect around under the steering column and find a strong odor from the CECM. So I removed it and opened it up and you can see for yourself the damage. I am just hoping this is the only thing that went out. I checked the driver signal pocket and one of the 3 pins were burned out. I did this because I had installed aftermarket signals that were causing hyper flash and sometimes no flash when I signaled. I was actually going to remove them that day. (Unlucky..)
I am waiting on the CECM to arrive and I read everywhere that I will need to recode it. I have the wire and software to do so, but need help on how to do it. I read a few threads on here which led me to this site, http://wiki.ross-tech.com/wiki/index...ED)#Adaptation, to do the following :
"Channel 081: Component Protection
To start the process of Vehicle Identification Number (VIN) learning, enter/save 46992 as new value."
Can anyone explain how I can code my new (used) CECM to my car. I ordered one that is the same part number, nearly everything is identical except the month and day of the board (same year 2002). This is the part number 8E0 907 279 E
Any help would be immensely appreciated. A video or a series of images would be great! Thank you and I hope to hear back soon. Your knowledge and input contributes to all.
