Originally Posted by
DGVR6
I've notice some oils that are 504 run 5w30 but the 2017 schedule calls for 504 5w40 while the 2016 schedule calls for 502 5w30/5w40/0w40.
Regardless I guess it's fine to run 504 5w30, just a little confusing on the USA maintenance book
How is fuel and oil consumption on 5w30 weight ?
All sort of muddled to me on what weight is used/best/recommended by Audi. On 2017 S8's (always "Plus" in USA), owner's manual punts it to an underhood sticker per the owner's manual. Manual alludes to 0W30, 5W30 and 5W40, but only as interim fix if stranded. Meantime, 2015 underhood sticker just says 502 and kicks it elsewhere, while 2015 manual is specific to 502 or 504 and the weights. Add to it the "Audi recommends" language now in the 2017 manual (Castrol Profesional) and I'm not sure marketing/ad dollars aren't speaking here some these days too. When I see that, my skepto meter goes up. However, you can get either 502 or 504 Castrol Professional from dealers, and actually mail order from a discount dealer for a lot less than I found a 504 oil anywhere else, whether ECS or Amazon or eBay or...
I looked again at the EPA master spreadsheet (findable online), and Audi did certify 2017 S6, S7, S8 and RS7 on 5W30 504/507. Also the Bentley Continentals with either 4.0T or W12. They do also certify other models on 502/505, including 2.0T's and 3.0T. Some Bentleys like the Mulsanne get run on 0W40 in 502, so someone is making a conscious decision about these presumably, as opposed to just spec optimization or one size fits all.
Meantime answering question, I haven't seen any A:B regimented test type stuff, but IIRC I have seen numbers in the 1-2% range. If you try the Lubrizol spider tool for 502/505 spec as against 504/507, 504 shows as better in a variety of meaningful areas, including fuel economy.
https://online.lubrizol.com/relperftool/pc.html Turbos included, I'm a lot more concerned about start up flow and high heat breakdown than about hot viscosity specifically--once you get to a high quality spec compliant synthetic that is. Fortunately Audi has a lot of experience over the 30+ years now on water cooling of bearings, after run cooling and the like.
