Results 1 to 7 of 7
    Nov 11 2010
    Rochester, MN
    Any way to disable the brake pad warning light?
    Howdy fellas, long time no see. I'm still around, but I've been busy with other things for the past few months.
    Anyway, on my wife's Avant, the brake pad warning light is stuck on because the connector that clips onto the brake pad connector is broken. So, while I've got plenty of brake pad left, the car thinks that I don't.
    Why haven't I replaced the cable that contains the brake pad clip, you ask? Well, I tried, but the little 6mm bolt that holds the ABS sensor to the spindle snapped off when I tried to remove it, and I can't get a drill in there to drill it out. I also tried an easy-out, but that didn't work, either.
    So, now I'm trying to see if there's perhaps a way to disable that warning via VCDS or my Maxwell OBDII reader. Any thoughts?
    19" B8 S5 Peelers
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Cannot be disabled via VCDS. Can be disabled by cutting the wires and looping it together to close the circuit and have the warning go away. If the break in the wire is from the pad to the clip, then cut off those wires to loop together. Preserves the clip so it can be used with new pads that have sensor wires.
    USP CLUB MEMBER #34
    May 27 2016
    Westchester, NY
    Quote Originally Posted by CyberPMG View Post
    ^ This. If you want to be 100% anal about it, solder the ends of the wires in the cup for the connector and then cover with liquid electrician's tape. Did this a few months ago no warming yet.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    As CyberPMG mentioned... Here's a how-to: https://www.youtube.com/watch?v=YzsInYPW43A
    Ross-tech has a VCDS procedure for this, but only for VW instrument coding. :(
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Nov 11 2010
    Rochester, MN
    Yes, now THIS is why Audizine still rocks the house. I would never have thought of doing either of those solutions. Thanks, guys!
    Ha, on further reflection, I should be able to splice the new connector from the ABS cable into the old ABS cable. Brilliant! Sometimes, I surprise even myself.
    19" B8 S5 Peelers
    Jan 24 2010
    Paramus,NJ USA
    I would never do that.Better off just jumping the 2 pins together.
    Ziddy Autowerks
    Jan 15 2022
    Brentwood CA
    Not sure if this thread is still active but I made a video on this disable process. Maybe it helps someone out! https://youtu.be/CkHP-_NHyR8
    - - - Updated - - -
    - - - Updated - - -
