Results 1 to 40 of 47
    Apr 28 2017
    b6 2.7t swap. starting problems
    Hi. i did a 2.7 swap. did all wiring for starter as my b6 had been set with clutch relay. I cant even get starter to try when i turn the key. literally nothing not even a click. i rechecked wiring and even tried taking relay out. still nothing. i tried crossing terminals on starter and it engages and rolls over fine. does anyone have any idea as to why nothing is working? I also ran vcds on the acc/start auth. nothing comes up. cant read controller. thank you for any help you can give.
    Dec 25 2016
    Denmark
    Do you have wiring diagrams or did you follow the guide here on audizine?
    I had the same problems as you when following the wiring guide from this website. Had to rewire everything accoring to the diagrams afterwards.
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    I can tell you if you followed mine its correct, ive used it on an s4 as well as 3 different types of a4's if there was an issue its most likely because the additional connections under the chart was not followed. To the op do you have power to the supply side of the starter relay? Also side note the starter relay is not in my wiring diagram, its bypassed but can easily be added.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Apr 28 2017
    i have both and along with the pinout for ecu. everything in the car seems to work fine just wont try and start.
    Apr 28 2017
    blitz i followed your write up on the wiring. i tried with starter relay and also after taking it out. i have power going in. i tried crossing starter with screw driver and it engages and rolls the engine over.
    Senior Member Three Rings Bob Marley's Avatar
    Jan 18 2016
    Queens NY
    Not sure if you tried this already...remove the relay & try putting a jumper from 30 to 87 wires. I believe wires are Red & Red/Gray heavier gauge than the others...
    see if it tries to Start. This bypasses the Clutch pedal Switch
    Relay 219
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Jul 31 2014
    NH
    This^, quick question did this chassis start as an auto or manual? Also keep in mind that there is no starter relay unless you added it to the harness from the b6 harness. So you have to run the wire from the b6 plug to the starter relay coil(switched from ground at the clutch switch) and supply a 12v on the other side of the coil. This allowes power through the relay contacts which should have 12v on one side when the key is turned to start. The other contact then goes to the starter.
    Apr 28 2017
    my b6 started as a 6 speed. the 2.7 was tip. but i removed the relay from my b6 harness and wired it exactly the same as had both side by side
    Apr 28 2017
    don't know if this has anything to do with it. when I used vcds I tried scanning the 05-acc/start auth. it is coming up with cant find controller. could this be the problem? if so can someone please help me locate that to work
    Jul 31 2014
    NH
    Well to make sure its not the relay jump the contacts like Bob Marley suggested, remove said relay and jump the starter input to the starter wire and see if it cranks
    Apr 28 2017
    im confused about the relay you are talking about. is it the relay that gets triggered from clutch switch? or is there another relay under the dash? if it is the relay that gets triggered from the clutch(white connector pin 14) I have already taken the relay out and joined the wires direct.
    Jul 31 2014
    NH
    and you have power coming from T10a BROWN Pin4 red/black on the b6 plug with the key turned to start? If not you need to trace that back and find out why, that is supplied from post 30 under the dash to the key cylinder then to the body plugs.
    Apr 28 2017
    also can it be the fact that vcds cant find the acc/start auth. controller?
    Jul 31 2014
    NH
    are the keys a match to the dash? also it doesn't matter as the 2.7 has no immo.
    Apr 28 2017
    the key is the key that worked fine before did swap
    Jan 18 2016
    Queens NY
    Quote Originally Posted by mattvon83 View Post
    The clutch switch Provides the Ground for the Clutch Relay (Black Body Plug engine bay).
    When you fully depress the Clutch pedal it completes the circuit & closes the relay contacts and Allows +12v to pass from 30 post to 87 to your starter 50 post... if you're relay is bad...jumping 30 to 87 would reveal this... if it still doesn't start...then you can start trouble shooting the +12v ignition up to that point
    Apr 28 2017
    I have already cut the relay out completely and still nothing
    Jul 31 2014
    NH
    I'll ask one more time is there power to the wire i said above when the key is in the start position
    Apr 28 2017
    Yes I do
    Jul 31 2014
    NH
    then the issues is you wire to the starter, you have to trace it out. If you jumped the relay correctly then it should turn over as long as the connection to the starter is good.
    Jan 18 2016
    Queens NY
    Also confirm you're Ground Strap near the Starter along the Passenger frame rail is connected & Grounded properly
    Apr 28 2017
    k. I have power coming thru t10a brown pin 4. I am not going to trace the wire and I am just going to run a new one. how much power is supposed to run down the line? can I run it thru a relay from post 30 in ebox with the t10a brown pin 4 triggering it?
    Jul 31 2014
    NH
    I cant remember off hand what gauge wire it is but that wire is suppose to supply enough current to trigger the solenoid without needing a relay, the interlock relay is just a safety measure so you can't start the car in gear.
    Apr 28 2017
    im only asking that and thinking of that because instead of trying to trace the problem in that wire, or even running a new wire along the side of the harness and actually having to secure it. i was going to run a wire over to the battery and put the relay there then just run the wire down from there to the starter.
    Jul 31 2014
    NH
    ah well yeah you could do that if thats the way you want to.
    Apr 28 2017
    update. i had 3 bent intake valves. i have since replaced and lapped all 30 valves just to be certain. it started when i put back together. but it will rev to 1000, then down to 500 and stall. gas pedal does nothing. sometimes will do it 2-3 times before stalling. but i cant get it to idle or gas pedal to do anything. anybody have any ideas?
    Jun 26 2015
    Tampa, FL
    What year ECU are you using?
    Apr 28 2017
    im using an ecu from an 01 s4
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Unplug the MAF and see if it runs better. Also could be a big vacuum leak. I assume you've checked fault codes.
    What do the timing values show in VCDS, block 093?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 29 2005
    10speed
    San Francisco, CA
    Glad it's fixed up, almost there
    - Clint
    Apr 28 2017
    hi guys. cant figure it out. found 2 vacuum leaks which i fixed. also realized ecu was still coded for auto. that is now fixed too. so i finally got the full version of VCDS. here is the autoscan.
    VCDS-Lite Version: Release 1.2
    Monday, 31 July 2017, 23:47:40:9917
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
    Address 01: Engine Labels: 078-907-551-AZA.LBL
    Controller: 8D0 907 551 M
    Component: 2.7l V6/5VT G 0002
    Coding: 06711
    Shop #: WSC 87119
    VCID: 341BB96E1723
    No fault code found.
    Readiness: 0110 0100
    Address 03: ABS Brakes Labels: 8E0-614-517.LBL
    Controller: 8E0 614 517 A
    Component: ABS/ESP allrad 1726
    Coding: 04495
    Shop #: WSC 00000
    VCID: 263F5326D1FF
    2 Faults Found:
    18256 - Please check DTC Memory of Engine Controller
    P1848 - 35-10 - - - Intermittent
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    30-00 - Open or Short to Plus
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Controller: 8E0 820 043 G
    Component: A4 Klimaautomat 0712
    Coding: 00000
    Shop #: WSC 63351
    VCID: 253D542AACF9
    3 Faults Found:
    01592 - Air Quality Sensor (G238)
    37-00 - Faulty
    00819 - High Pressure Sensor (G65)
    01317 - Control Module in Instrument Cluster (J285)
    79-00 - Please Check Fault Codes
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
    Controller: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 00000
    VCID: 341BB96E1723
    11 Faults Found:
    01494 - Bulb for Parking Lamps; Left (M1)
    57-00 - Electric Circuit Failure
    01498 - Bulb for Parking Lamps; Right (M3)
    00984 - Left Tail Light (M4)
    00978 - Lamp for Low Beam; Left (M29)
    00979 - Lamp for Low Beam; Right (M31)
    01495 - Bulb for High-Beams; Left (M30)
    01499 - Bulb for High-Beams; Right (M32)
    01496 - Bulb for Fog-Lamps; Left (L22)
    01500 - Bulb for Fog-Lamps; Right (L23)
    01493 - Bulb for Blinkers; Front Left (M5)
    01497 - Bulb for Blinkers; Front Right (M7)
    Address 15: Airbags Labels: 8E0-959-655-84.LBL
    Controller: 8E0 959 655 A
    Component: Airbag 8.4E 3000
    Coding: 0010607
    Shop #: WSC 63351
    VCID: 351D846A1C59
    4 Faults Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
    011 - Open Circuit
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    011 - Open Circuit
    Address 16: Steering wheel Labels: 8E0-953-549.LBL
    Controller: 8E0 953 549 L
    Component: Lenksáulenmodul 0308
    Coding: 00041
    Shop #: WSC 63351
    VCID: 3C0B914E3F73
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Controller: 8E0 920 900 H
    Component: KOMBI+WEGFAHRS. RB4 D25
    Coding: 03300
    Shop #: WSC 00779
    VCID: 2925581AC0E1
    WAULT68E02A137618 AUZ6Z0A0262409
    4 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    00668 - Supply Voltage Terminal 30
    53-10 - Supply Voltage Too Low - Intermittent
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    01316 - ABS Control Module
    Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
    Controller: 8E0 951 177
    Component: Innenraumueberw. 0504
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBA9E2128A9D
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
    Controller: 8E0 959 433 T
    Component: Komfortgerát T5B 0617
    Coding: 11788
    Shop #: WSC 63351
    VCID: 42F7EFB65D97
    26 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    52-10 - Supply Voltage Too High - Intermittent
    01134 - Alarm Horn (H12)
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    01573 - Alarm triggered by Door Contact Switch; Left Rear
    35-00 - -
    01331 - Door Control Module; Driver Side (J386)
    80-00 - Single-Wire Operation
    00932 - Electric Window Motor; Drivers Side (V147)
    01034 - Electric Window Thermal Protection Active; Driver
    27-10 - Implausible Signal - Intermittent
    00912 - Window Regulator Switch; Front Left (E40)
    01340 - Mirror Adjustment Switch
    57-10 - Electric Circuit Failure - Intermittent
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
    37-00 - Faulty
    01332 - Door Control Module; Passenger Side (J387)
    01561 - Left Rear Door
    59-10 - Can't Unlock - Intermittent
    01803 - Door Warning Lamp; Rear Left (W37)
    00934 - Electric Window Motor; Rear Left (V26)
    62-10 - No or Incorrect Adjustment - Intermittent
    01333 - Door Control Module; Rear Left (J388)
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
    37-10 - Faulty - Intermittent
    01562 - Right Rear Door
    01037 - Electric Window Thermal Protection Active; Rear Right
    01334 - Door Control Module; Rear Right (J398)
    00935 - Electric Window Motor; Rear Right (V27)
    Address 55: Xenon Range Labels: 4Z7-907-357.LBL
    Controller: 4Z7 907 357
    Component: dynamische LWR D06
    Coding: 00060
    Shop #: WSC 63351
    VCID: 047B29AE0703
    3 Faults Found:
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
    07-10 - Signal too Low - Intermittent
    End --------------------------------------------------------------------------------------------------
    i dont have front clip on yet, so that is why so many errors for lights and stuff. let me know if you see anything that looks wrong.
    Oct 29 2005
    10speed
    San Francisco, CA
    It's hard to know until you clear the codes and see what comes back
    - Clint
    Apr 28 2017
    which codes do you want me to clear?
    Oct 29 2005
    10speed
    San Francisco, CA
    All of them.
    - Clint
    Apr 28 2017
    ok i went thru and cleared codes. some came back instantly as i dont have front clip on so no lights or anything.
    Coding: 06711
    Shop #: WSC 87119
    VCID: 341BB96E1723
    Coding: 04495
    Shop #: WSC 00000
    VCID: 263F5326D1FF
    1 Fault Found:
    Coding: 00000
    Shop #: WSC 63351
    VCID: 253D542AACF9
    3 Faults Found:
    37-00 - Faulty
    Coding: 00001
    Shop #: WSC 00000
    VCID: 341BB96E1723
    7 Faults Found:
    Coding: 0010607
    Shop #: WSC 63351
    VCID: 351D846A1C59
    3 Faults Found:
    011 - Open Circuit
    011 - Open Circuit
    Coding: 00041
    Shop #: WSC 63351
    VCID: 3C0B914E3F73
    Coding: 03300
    Shop #: WSC 00779
    VCID: 2925581AC0E1
    1 Fault Found:
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBA9E2128A9D
    Coding: 11788
    Shop #: WSC 63351
    VCID: 42F7EFB65D97
    Coding: 00060
    Shop #: WSC 63351
    VCID: 047B29AE0703
    2 Faults Found:
    Jun 26 2015
    Tampa, FL
    Coding: 00000
    Shop #: WSC 63351
    VCID: 253D542AACF9
    3 Faults Found:
    37-00 - Faulty
    Coding: 0010607
    Shop #: WSC 63351
    VCID: 351D846A1C59
    3 Faults Found:
    011 - Open Circuit
    011 - Open Circuit
    Coding: 03300
    Shop #: WSC 00779
    VCID: 2925581AC0E1
    1 Fault Found:
    Fault 01592 - no info on ross-tech.
    00819 - High Pressure Sensor (G65) - possible bad pressure switch near the condenser. Not the problem.
    01317 - Control Module in Instrument Cluster (J285) - ECU can't talk to the cluster. I assume this is normal on a 2.7 swap?
    I highly doubt the airbag codes would cause this, but hopefully someone else can confirm. I would think if anything the airbag faults would prevent the car from starting at all.
    Which leaves the Outside Air Temp Sensor. This is certainly a possible cause, although it's hard to tell from a keyboard. Basically the ECU gets confused as to what the air temperature should be, air:fuel ratios go crazy, and it stalls out. At least that's my guess. Have you tried with the MAF unplugged?
    Apr 28 2017
    thanks. i was actually thinking the same thing about the outside air temp last night. i dont have the front clip on the car which would be why it is not getting a signal. when i get off work tonight im going to put the front end on and hope for the best
    Jul 31 2014
    NH
    none of that will affect the engine starting including that temp sensor the only ones thats matter are the coolant temp and iat as far as temps go. Start with the basics, does it have spark (needs a test light)? does it have fuel? does it have compression, figure out which is wrong trace that system backwards, I'm going to gues something with wiring.
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    Ive been driving with the outside air temp sensor ripped off for years. Its just 2 wires hanging there (well, taped and tucked up).
    Dash reads 10 deg. higher, but never any starting or running rich, or any kind of issues.
    I would think the ecu has to talk to the cluster.
    Any other 2.7 swaps showing that code?
    Oct 29 2005
    10speed
    San Francisco, CA
    I'm at a loss... Something legit is wrong and there's no sign of it.
    - Clint
