Results 1 to 20 of 20
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Cold Startup Rattle - Is Anyone Just Ignoring It?
    So we know this happens and there's been some threads on it. Some have had the fix, some have had dealers say it's normal.
    The TSB info is below, but it says "The noises do not lead to damage". I'm recently out of warranty, but I'm guessing we have a lot of people with this issue and no real failures.
    So who has done nothing and for how long?
    http://www.audizine.com/forum/showth...ighlight=start
    Technical Service Bulletin
    15 Engine rattling noises at cold start - V6 3.0 TFSI
    15 15 26 2039995/1 March 3, 2015.
    Model(s) Year VIN Range Vehicle-Specific Equipment
    All 2011 - 2014 All V6 3.0 TFSI
    Condition
    Rattling noises are heard from the timing chain drive for about 1-3 seconds after the first engine start of theday.
    Technical Background
    The noises are caused by one of the upper chain tensioners. The noises do not lead to damage.
    Production Solution
    Improved chain tensioner.
    Service
    1. Verify condition by observing engine sound during cold start.
    2. If the rattling noise comes from the area of the timing chains (back of the engine) for 1-3 seconds after the first start of the day, replace both upper chain tensioners of bank 1 and bank 2 with the optimized chain tensioners.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    I have this when I let my car sit for a few days....dunno if I am going to get it fixed since it supposedly doesnt damage anything. I have had it for at least the last 8-10K miles
    [B]Current: Shopping now....
    Jun 05 2007
    Nashville, TN
    Quote Originally Posted by cjw View Post
    I noticed the rattling after reading about it on here, and luckily while still under warranty. My dealership had me drop the car off overnight, so they could start it after sitting overnight, and had no problem at all in recreating the issue. They fixed it under warranty.
    If you're out of warranty, I think I'd just live with it. But for anyone who's covered, you might as well get it fixed. I know Audi says it doesn't lead to damage, but anytime I hear about an issue with a chain tensioner, it makes me nervous. I'd rather get it fixed.
    Good luck!
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    Yes.
    Jul 16 2012
    Mid-Atlantic
    If it won't cause any damage, I'll go ahead and leave it. Don't need anyone tearing apart my engine needlessly.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Mar 05 2012
    Omaha, Nebraska
    I'm ignoring it, it's intermittent for me sometimes it'll do it sometimes not. Not entirely concerned at this time, perhaps if I get a lot of money and time out of nowhere I will install updated tensioners ( out of warranty obv).
    2010 Audi S4 DSG Meteor Gray; Daily; USP intake/Miltek non-res W/Black Oval tips; Dual Pulley (3.139) GIAC/DSG Tune/APR CPS 11.884 @ 115.9
    Oldies-10 Blue A4 Stock,00 Nogaro Blue 6MT, 04 Moro Blue S4 6MT, 00 A4 Avant w/tip
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    I'm still under warranty and will likely have it looked at. Although, I can't really say that I've noticed this noise all that often.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Mines a 2010 and does it. I just ignore it.
    Senior Member Two Rings 00passat's Avatar
    Jul 31 2012
    2005 Gmc sierra 2500hd 6.6 dirtymax
    Lancaster,ca
    If your under warranty and it's making noise upon startup, I'd recommend getting the tensioniers replaced. I see the same problem on nissans and ford , eventually a guide or tensioning rail breaks. From the play in the chain upon startup. Mine has yet to make the noise. 2014 s4 with 42k
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    Mine is a 2014 and has done it as long as I can remember. I didn't pay much attention to it until I saw posts about it. Some members have reported horror stories from bringing it in to get fixed. I'm fine with it for now, but might bring it up to the dealership before my warranty expires at the end of February.
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
    Jun 05 2007
    Nashville, TN
    Quote Originally Posted by SForePlayin' View Post
    I guess it depends on the dealer. I really don't have any horror stories about my local dealer, they've always been fair with me and done good work. They fixed mine on the first try with no adverse effects, FWIW.
    Oct 02 2013
    Redstone, CO
    I had it fixed because my car is still under warranty. That being said, the dealership fugged up the repair and it took a long time to get right. I trust my SA. He's solid and he told me it wouldn't be a problem to leave it alone. Since my car was under warranty I said no dice, fix it. If I had the same issue out of warranty knowing what I know now, I'd leave it alone and just live with it.
    2014 S4 Estoril Blue, Black Opt, 19" Rotor, Side Assist, Carbon Inlay, B&O Sound, MMI/NAV, Rear Camera, Advanced Key, Supercharged badges, H&R OE, Track+ Spacers, 10/15mm, otherwise stock.
    Established Member Two Rings TheAsset's Avatar
    Jul 14 2016
    MO
    If there's a revised part and your car is still under warranty I don't see any reason not to have it done.
    2014 Audi S4 Prestige - Misano Red
    IG: @TheAss3t
    Feb 20 2006
    NC
    I had it done in the last month of warranty with no issues afterwards. No more rattle and i am glad I did it.
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    Registered Member One Ring butch_launch's Avatar
    Jun 13 2017
    south africa
    Mine is booked in for the repair come August. They currently have another S4 in for the same job and the Audi dealer said they have to remove the motor to complete the job. Not to happy about that seeing as the car has 60k kms on it, 2013 model and that I've owned the car for less than a month only. I get that its not damaging having the sound, but I'd have it fixed while the car is still under motorplan.
    Audi S4 B8.5 S-Tronic
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by Works2shoot View Post
    This. The techs at our local dealer said it's not an issue and common. No long term issues unless the rattle continues past the few seconds of start up. Mine only does it upon cold starts and even then it's occasional not always.
    I'm not interested in risking anyone pulling my entire motor apart to fix a sound. I'm likely going to keep my car another 2-3 years so unless it gives me a problem then I'm leaving it for the next owner/dealer to worry about.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Established Member Two Rings badazzstang's Avatar
    May 10 2017
    13 S4, 90 Mustang GT Convertible, 94 LS400, 07 F150 Supercrew, 2010 GX460
    Waco, Tx
    I am having this issue as well. I am needing to take mine in to see if I can get it fixed before warranty is gone. It only happens on the first start up of the day. It's noticeable to me because that start up is always in the garage. Also need to take mine in for the 100-160 glitching/flashing. The fuel does it to but not as often as the MPH.
    2013 Glacier White Metallic S4 DSG/Black Nappa - EPL Stage 2
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Mine does this occasionally and been ignoring for about 30k
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Established Member Two Rings DankFX's Avatar
    Jul 07 2014
    Have any of you replaced your timeing chain yet? Im at 75k miles and Ive heard of it failing at some point for people. Just thought if Im going to replace the cain, might as well get this fixed also?
    2013 b8.5 Audi S4 DSG Estroil Blue | no tune | CTS intake | AWE Touring exhaulst |
    Solorwerks Coilovers| CR-15 | 034 Xbrace | 034 rear sway | 034 Trans mount insert |
    Established Member Two Rings romanrnd's Avatar
    Nov 21 2017
    Cleveland, Ohio
    I've been living with the sound for a while and I'm almost at 100k miles.
    Definitely has gotten louder over time but fixing it out of warranty just isn't an option.
    Can't justify throwing $3k into it and then have the noise come back in a couple months...
