Hi guys, this may be my first post on the B7 forum. I just had something I wanted to share that may help another B7 owner in the future.
Quick background: my father owns an import repair shop specializing in Audi/VW and Toyota/Lexus. I am not a mechanic, but sometimes consult with him on VCDS, diagnostics, research on pattern failures, etc.
We recently had a 2005 B7 A4 3.2 FSI Quattro Tiptronic roll in with a tricky problem.
- Engine RPM will "surge" moderately, along with a very soft misfire, especially with engine at operating temp
- Surging happens at idle, when creeping, when cruising at light load - pretty much anything other than hard accel
- Usually worse with A/C on
- Not super dangerous really, but it does pull against the brakes slightly in a parking lot or at a stop sign for example. Could lead to a mishap.
- No codes whatsoever - scanned with VCDS
Ruled out: Carbon deposits on valves
- Car accelerates extremely well and issue does not occur when cold
Ruled out: Timing issue
- No timing codes, all cam advance values in VCDS are spot on
Ruled out: Mixture issue
- Instant and Long Term Fuel trims are perfect
Initial Diagnosis: Vacuum leak or PCV issue
- Checked all the stuff, no leaks could be identified
- Crankcase vacuum is normal
Second Diagnosis: ECU Software issue possibly related to TSB 240857 2010890/8 (engine runs rough with no codes)
- Sent the customer to the nearest Audi dealer for a possible software update.
- They charged the customer $55 to tell her there were no codes (this was known) and they were unable to even attempt to fix the issue until it throws a code.
Car comes back for me to look at more in depth. Test drive reproduces problem and I'm able to park it and watch it surge and stumble.
- Can hear a weird tapping/rattling noise in the engine bay at the exact moment the revs jump around and the soft misfire occurs
- Listened with a mechanics stethoscope - tapping comes from the throttle body
- Logged throttle body with VCDS. It does seem to have erratic movement during the surging.
New Diagnosis: Faulty Throttle body
- Really not sure, though
- Re-adapt throttle body several times. Always adapts just fine.
- Find THIS THREAD with video online:
- This is EXACTLY what this customer's A4 3.2 was doing.
- I now feel better about faulty throttle body diagnosis
- Replace throttle body with used unit from a C5 A6 2.7T (shares same part number)
- Re-adapt TB, All fixed!
This one was pretty tricky to figure out due to zero codes from the ECU. It is amazing that the idle could surge like it did (sometimes 400 rpm more than it should be) without throwing any codes. Not even an "idle RPM higher than expected" code. I believe this is due to Audi significantly loosening the misfire and idle roughness thresholds in response to their issues with the FSI intake valve clogging.
Anyway, I just thought I would make a post in case somebody else runs into this. Also, I'm a little disappointed in Roth Audi in Erie PA for not taking care of this customer's concern. The throttle control on the car was acting up (a potential safety issue) and they didn't really do anything other than a $55 "thanks for stopping by" fee. I expected a little more from them.
