Results 1 to 14 of 14
    Oct 05 2016
    Ohio
    Manual shifter rebuild
    I'm thinking about buying this shifter rebuild kit from ECS Tuning for my B6 A4 manual 6 speed
    Does anyone have any experience with installing this, and could possibly lead me to a write up on how to install it
    https://www.ecstuning.com/b-genuine-.../8e0798151bkt/
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    that only replaces a small part of the linkage, the ball joint by the selector shaft.
    (red thing in pic)
    link is an 01E but its the same idea on 02X that you have.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    On my 02X that ball joint was really worn out. The rest of the linkages were fine.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    JHM makes a nice replacement.
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Mar 05 2013
    CA
    Quote Originally Posted by EMN1.8 View Post
    I don't know if anyone on US forums has done a write-up yet. Maybe the first will be you? me?
    wonder if ELSA has it.
    Speaking of that area, maybe there's some other stuff you could do while you're in there? such as selector shaft seal.
    maybe depending what site you order from, to rack the total up enough to qualify for Free Shipping.
    Quote Originally Posted by Kevin C View Post
    can't you see it if you remove the shift knob/boot? You'll need to replace the clamp.
    I don't think mine has much play.
    but as for the one at the transmission, I haven't checked it.
    well I guess if yours had it, then why wouldn't all of them.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Go JHM!
    2019 SQ5 Prestige
    Mar 28 2015
    The JHM kit doesn't come with that bushing. If you put in a JHM shifter, you will now have a short shifter with a sloppy bushing. Seems to make sense to fix or check out the front bushing first or do both. Mine was quite worn. I'm pretty sure my transmission isn't the only one to have this happen.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    My shifter does not have slack, but certainly doesn't feel slick like a new shifter in my friend's 2015 Audi. I wonder if I need to rebuild the whole thing to restore the feeling if I don't have any free play besides side-to-side needing some lubrication, so it springs back to central neutral position easily.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Apr 01 2007
    houston texas
    https://jhmotorsports.com/shop/catal...html?cPath=0_2
    2019 SQ5 Prestige
    Apr 15 2014
    Ottawa/Gatineau Canada
    Quote Originally Posted by eljay View Post
    Most times my shifter, when in neutral, will come back to center if pushed to the right or left and then let go. However, sometimes it will stick if pushed to the left...how does one lube this?
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Apr 03 2016
    Up North
    Quote Originally Posted by Luxus Panzer View Post
    Its that bushing in the first post of this thread that causes that. My shifter was worse than yours. It would almost stay where you left it. The problem is the bushing, and the cap (the black plastic, gold metal inner unit pictured above) as stock has a small hole in it. This allows water to penetrate and dilute/wash out the grease. Voila, stiff shifter. You can take it apart and lube it, but by the time you have hit the point its stiff, the bushing likely needs replacement from wear. My pivot ball was super rusty and scaled too. 3M wheel fixed that up, new ECS bushing kit did the rest.
    I've replaced mine obviously. Hardest part is getting shifter arm back through the rubber boot to the shifter box after replacement. Not a ton of room up there, and I got big hands. Other than that, the bushing socket is crimped into the metal arm, but a pair of pliers to straighten things allows replacement. No real DIY needed. Just remove the assembly from the trans on both sides then the shifter and go to work...
    Mar 28 2015
    My bad... I was thinking the shifter kit and forgot about the linkage upgrade kit.
    Apr 15 2014
    Quote Originally Posted by Human Garbage View Post
    Thanks for the info.
    I do wish there was a DIY as I like to orientate myself to the ground before I step off for battle ;)
    Apr 01 2007
    houston texas
    JHM's site has detailed DIYs for their parts, should be the same process as OEM.
    2019 SQ5 Prestige
