Results 1 to 7 of 7
    Mar 15 2017
    Dallas
    2011 a4 AC blowing warm air only
    The AC slowly started blowing warm air, now it only blows warm air only.
    I can hear the Compressor running when the AC is on.
    I had a bad battery, so I replaced that. Also replaced the high pressure switch. Checked power to the compressor and it's good. Have not scanned for codes yet.
    Still blowing hot air.
    Any suggestions?
    2011 Audi A4 Premium Plus with Titanium Package
    Established Member Two Rings hpmurdarah's Avatar
    Dec 26 2016
    Hyde park ma
    Put Freon in it or Go somewhere and have them check ur system, might just need Freon or maybe u have a leak, considering your asking this questing print a better idea to let the professionals handle it
    galaxy s7
    Mar 15 2017
    Dallas
    already did that, it's at my friends shop right now
    we just want to make sure it's not something cheaper before concluding it's a bad compressor
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Any codes? I had a similar issue, but it was a pinched wire to the G395.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Mar 15 2017
    Dallas
    when we pulled the compressor out, this valve fell out and was busted...wtf?
    Mar 15 2017
    Dallas
    no codes
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    Had the same issue with mine. Doesn't throw any hard codes, you have to scan the hvac controls in vagcom. I found that my high pressure sensor was bad, replaced for 70 bucks and all is well. Also, you can run an output test which will force the a/c compressor to turn on without input from the high pressure sensor which will allow you to confirm if the compressor is working or not.
