Results 1 to 7 of 7
Thread: What is AMAX?
    Oct 27 2013
    What is AMAX?
    I see AMAX referenced multiple times in multiple posts but can't seem to find a post that says what it is, can someone help me out here?
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    I think this is good enough
    Quote Originally Posted by Sean@APR View Post
    Amax uses both clutches simultaneously and slips between the gears.
    A normal shift de-rates the engine by telling the ECU to pull timing. It does this to prevent free-revving and to lower the torque at the clutch to make shifting easier. It has the engine de-rate while it's opening the first clutch. The engine free-wheels for 50ms or so while the second one is being closed and then the TCU tells the engine to bring back the power. That de-rate timing retard is what causes the DSG "farts" you can hear on videos.
    Amax doesn't work like that. When in this mode, the TCU keeps the beans on the entire time. There is no de-rate at all. It controls the engine RPM by having both clutches engaged in the linear (slip) region together while it transitions between the two. The upshot of this is that there is no de-rate, the engine is making full power the entire time and is transmitting it to the ground even during the shift. The downside is that it's extremely delicate. If the transition time is too fast, the clutches won't slip enough, will be working against each other and will rip themselves out of the transmission. On the other side, if the transition time is too slow, the engine will free rev, hit the limiter and de-rate via the rev limiter. It comes back as soon as the clutch closes a bit more and pulls it off the redline, but it still spent some time in de-rate.
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Oct 27 2013
    This applies to DSG and ZF transmissions?
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    Based on the above description including 2 clutches, no, DSG only.
    Aug 03 2014
    Queens
    ZF would be the same concept I'd imagine, no derate in amax mode. Power is kept in between shifts
    Previous
    Established Member Four Rings limeypride's Avatar
    Mar 18 2017
    Snohomish
    Quote Originally Posted by DGVR6 View Post
    That's a great description for the DSG but I'm not sure how to translate that to the ZF 8-speed. It doesn't have a single clutch, let alone 2. I'd be interested to hear such a description for the ZF because, however it works, it makes a huge difference (and oh how I wish it would shift like that whenever the car is driven aggressively but alas...)
    2018 ////AMG E63S in Diamond White/Nut Brown, lowered 20mm front/back, spacers, tints, EuroCharged tune
    Gone but never forgotten
    2017//RS7 Performance in Mythos Black, Audi exclusive Titanium edition w/ Akrapovic exhaust
    Feb 09 2016
    Houston
    Whatever the details, the gist I think is that normally the TCU tells the ECU to pull timing and power between shifts in order to preserve the transmission, but AMAX mode turns that protection off. You power straight through the gears.
    2014 A8L 4.0T - RS7 Turbos, DS1 Stage 3 Tune, Full E85, Stock Downpipes, Stock LPFP. [email protected] mph
