Car: 2007 Audi A4 B7 2.0t FSI front wheel drive.
Audi is seldom driven. It currently only has 43K miles.
I was driving this car until 2013 - that's when I gave it to my daughter.
She returned it (January 2017) due to it running sluggish and was emitting smoke on WOT. Plus it was consuming oil. 1 qt every 1K miles. Also, CEL is on.
Things I have done/replaced:
1. Replaced all 4 spark plugs with Bosh double platinum
2. Replaced all 4 coils
3 Replaced engine and cabin Air Filters
4. Replaced PCV and PCV Gasket
5. Replaced Cam Follower
6. Cleaned MAF
7. Battery and alternator checked at autozone . Found no issue with either one. Battery is at 12.58V
8. Replaced Diverter Valve with Upgraded Pierburg 06H145710D
No more CEL or error code and no more smoke. No signs of vacuum leak (sprayed brake fluid around intake, vacuum lines, etc).
Issue: When on the highway, and I floor it (WOT) the RPM will not go higher than 4K. I recall it use to climb well over 6K RPM.
The audi eventually gets upto 80 MPH - but takes more time than before.
I'm stuck - Can someone advice on what to check next?
Thank you in advance,
Jojo
