Results 1 to 28 of 28
    Mar 17 2017
    2006 acura TL aspec 6MT
    Cleveland,oh
    Running 20x10 et25 on s6?
    Hello everyone. I browsed endlessly on this topic and really could not find the answer i was looking for so ive decided to post another wheel tire fitment question. Ive decided to purchase a set of AG m580s but they only come in 20x8.5 and 20x10. For the sake of concavity id really prefer to go with 20x10. He said if i decide on 20x10 i need a et25 to clear brakes but that the wheel would stick out past fender. He sent me a pic of an s6 with the 20x10 et 25 and said it sits rather flush but likely cambers / suspension were adjusted . My question is anyone running 20x10 et25 on their s6 and does it creep past the fenders?
    He also recommended 255 instead of 265/35/20 ? I was considering 265...
    Lastly i plan on purchasing a cete lowering module in the next month or so. Will this be an issue at all if i go with 20x10s all around .
    Here is a red s6 the fella at AG sent me .
    Also not trying to offend anyone or their knowledge on the matter because i dont know much but i would prefer feedback from c7 /s6 owners who are running similar setups.
    Thanks in advance
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Here's a calculator for figuring out wheel offset and clearance/poke. I believe the stock wheels are 20x8.5 et45.
    http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
    Sent from my SM-G935V using Tapatalk
    Active Member Two Rings kok0nutt's Avatar
    Mar 01 2017
    williamsburg VA
    20x10 Et35 is the way to go. It leaves the wheels flush.
    May 04 2010
    2013 Audi S6, 2014 Audi Q5 TDI, 2015 GSW TDI 6-spd
    Duluth GA
    I'm running 20x9 ET25 and while the wheel is inside the fender, the 265/35 tires protrude ever so slightly. You can see my photos here: http://robcheng.com/s6bbs
    The S6 in the photo is a C6. You might want to check with the wheel guy whether they have experience specifically with the C7 as I suspect the brakes aren't the same on the C6. Before I decided on the BBS, my local shop test fitted a 20x10 ET30 that cleared the brakes, but I don't recall the wheel model since I didn't care for the style. However I do recall it protruding past the fender a little.
    One last note, a 255 (and probably 265 too) will result in some stretch when mounted on a 10" wide wheel. This is likely why they recommended this size since it will provide additional clearance from the fender.
    Robert Cheng
    2014 Q5 TDI, Phantom Black, S-Line, B&O, Nav, Side Assist
    2013 S6, Estoril Blue, B&O, LED, cold weather, comfort seats, rear shade, BBS CH-R 20x9 ET25, Stasis 25.4mm RSB, Alu-Kreuz
    2010 S4, 6-spd, Meteor Gray, Prestige, Sport Diff, Strat shifter, H&R Rear Sway -- SOLD
    2000 S4, 6-spd, AWE stg3, lots of other stuff -- SOLD
    Mar 17 2017
    Cleveland,oh
    Quote Originally Posted by brad281 View Post
    Ive used the calculator / site but unsure what it means
    Mar 17 2017
    Cleveland,oh
    Quote Originally Posted by kok0nutt View Post
    Ag guy said 35 wouldnt be enough to clear calipers. Is that what u r riding on? Any chance u have a pic? Thank u
    Mar 17 2017
    Cleveland,oh
    Quote Originally Posted by maxhawk View Post
    Thanks maxhawk. Ur link did not work. Do u have ig?
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Looks like the wheel will extend out 39mm farther than the stock wheel, if the stocks are 8.5 wide et45. That's quite a bit. I recommend measuring against the stock wheel to get an idea what it will look like.
    Veteran Member Three Rings GameBreaker's Avatar
    Mar 19 2008
    Phantom Black S6, GONE but Not forgotten: Dolphin Grey B6 S4
    Chicago
    20x10 et25 will not work as your wheels will be sticking out, and would be really bad up front. It might work on a C6 S6 or A7/S7, but definitely not a C7 S6. If anything you would probably want to run et45 all around. However if you want an aggressive fitment, et40 up front and et 30 in back is as far as you would want to push it, but I would recommend slightly less.
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    They won't even be close to fitting in that width and offset. If the AG guy is telling you et35 won't fit that may apply to the wheels they have but it certainly will on a wheel that's supposed to be on the C7 S6 in the first place.
    I've had just about every size and offset on my S6 and can discuss this with you at length if you'd like. Shoot me a PM and I'll happily share my thoughts and experience.
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Veteran Member Three Rings MVcycleart's Avatar
    Feb 03 2013
    B7 S4 Avant - SOLD:C7.5 S6 - SOLD:B8.5 S4 - SOLD:B9 RS5 SB
    Gainesville, VA
    Iron, i just installed AG 590's 20x10 et 25's and i will tell you they 100% stick out past the fenders. With a 10" wheel you would never get away with et35 as there isn't much room for these wheels either. I am still trying to decide if this is the setup i want, and i will try and grab a couple pictures if you want. Shoot me a PM.
    B7 RS4 Avant Clone - Complete conversion with all the fixings
    Other: 2015 Mclaren 650S Spider: MSO, Akra, HRE, Velocity Tune
    2004 MV Agusta F4 1000S
    PAST - B7 S4 Avant, B9 RS5 SB, C7.5 S6, B8.5 S4, E-tron SB
    Get busy living, or get busy dying!
    Jan 31 2009
    2016 RS7-P
    20x10 +35 with 265/35-20 is a great fit if you're lowered. I had no rubbing with that even though 21x9.5 +32 with 255/30-21 rubbed very slightly in the front. Neither of these will rub in the rear. 20x10 +25 could work but you would need to stretch a tire to get the clearance.
    Sep 28 2009
    suburb
    This is a stupid question but does +25 offset vs say +35 offset mean that the wheel is pushed out further towards the fender? The +35 would be more inside the fender?
    Thanks
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Jan 31 2009
    2016 RS7-P
    Correct, it is +35mm from the centerline of the wheel width so wheel widths matter when considering offset. The closer you get to 0 and negative offset the more outward the edge of the wheel goes.
    10" wide +35 is 10mm inward compared to 10" wide +25. Online calculators make it easy to compare widths, some do decent with tire sizing too which changes how much or less chance there is of rubbing. Lots of crazy offsets can fit with camber and tire stretch.
    Mar 17 2017
    Cleveland,oh
    Quote Originally Posted by flyfishing View Post
    Thanks
    That is how i understand it 🤷🏻*♂️
    Senior Member Two Rings Tidefan73's Avatar
    Sep 16 2016
    2014 Beetle R (Wife's), 2005 Nissan Titan LE
    F'Burg, VA
    For what its worth, here is my set up... 20x9.5 ET35 running 275/35/20 tires.
    Took delivery 12/05/2016:
    2017 S6 Prestige | Daytona Grey Pearl | Black Optics | Sport Package | Comfort Seats | Carbon Inlay | EPL Stage 1 ECU/TCU | CETE ASC v2 | Signature SV304S 20x9.5 ET35 w/ 275/35/20 | BlackVue DR650S-2CH
    "I love this car!!" -Me
    Insta: Tidefan73_S6
    Mar 17 2017
    Cleveland,oh
    Quote Originally Posted by Tidefan73 View Post
    Thats the stance im looking for! Nice color btw. Thank you. However Ive decided to hold off on purchasing the ag wheels and keep the search going until i find a lighter wheel. Wheels are a new thing for me and im really indecisive. Anyone looking to sell a set of wheels fitted for their s6 pm me.
    Dec 04 2016
    Ranson WV
    That's the same setup I'm looking to run. Could I trouble you for any more pictures? Maybe from almost straight ahead? I am trying to decide if the wheel and tire will poke out too far? I'm lowered 10mm over stock. I feel like it might work? I just don't want the tires throwing stuff on the side of the car when I am driving the back roads. Maybe 275 is too much in that case? IDK. Thanks for posting your setup!
    Sep 16 2016
    F'Burg, VA
    Quote Originally Posted by -Eric- View Post
    Not the best, but might help.
    Left is current setup. Middle is factory. Right is factory with 15mm spacers.
    Insta: Tidefan73_S6
    Mar 17 2017
    Cleveland,oh
    Factory with spacers looks damn near perfect . What spacers were u using?
    Sep 16 2016
    F'Burg, VA
    Quote Originally Posted by Ironlung1948 View Post
    ECS Tuning
    https://www.ecstuning.com/b-ecs-part...2411ecs03akt3/
    Insta: Tidefan73_S6
    Dec 04 2016
    Ranson WV
    Thanks!!
    Mar 17 2017
    Cleveland,oh
    R those considered hub centric? Seems expensive for what they r. When i purchased spacers for my acura they looked like these. Curious if this matters much.
    Sep 16 2016
    F'Burg, VA
    Yep, they are. Quality product.
    That price also includes the lug bolts needed.
    Insta: Tidefan73_S6
    Veteran Member Four Rings Street Nasty's Avatar
    Jan 20 2009
    B5 S4 Avant
    20x10 et35 fits fine on the front. I can lower my s6 in the front with the cete module. Clearing the front brakes will all depend on the wheel design, you will not know if it will clear at et35 or et25 unless you test fit it.
    20x10 et35 sticks the wheels out slightly in the rears even with rear camber adjustment. 20x10 et35 will stick out a lot.
    Mar 14 2016
    Cleveland, OH
    Anyone know if 20x9.5 +ET40 would clear the OEM suspension and brakes? Any ideas?
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    really in love with this fitment. Found a couple of your photos from some other threads last week and saved them for when I get wheels and suspension. nice work
    Oh and this is beautiful . Reminds me of my old B6. same color.
    2012 A6 3.0T prestige | Midnight Blue Metallic | Nougat | ACC | Stock (gone)
    2003 1.8t 5spd FW(trash) Quattro swap (in progress) | audiUP snub | Depo Ecodes | Mini H1 retro | 4300k | 07k FSI coils | BKR6E | de-badged | BC Type BR | Swift Springs | BBS LM Reps 18x9.5 | 25FTG F+R | Tasteful poke
    Sep 16 2016
    F'Burg, VA
    Quote Originally Posted by ZipMeUpJ View Post
    Thanks! I'm really happy with the look and outcome of the wheels/tires.
    T-
    Insta: Tidefan73_S6
