I recently installed H&R front and rear sway bars and since then I've noticed I've been getting some clunking from the front end at low speeds when turning the wheel (e.g. u-turns, parking lots, etc.). I double checked everything now to make sure it was all tight and I even made sure the links were installed at ride height with load on the car before torquing all the bolts. Could the noise be because I didn't replace the OE links? Also, the car is lowered on H&R OE springs, but the noise was never there before even when it was initially lowered and had factory sways.
Anyone else encounter this issue after installing sways?
