Hi everyone, I've owned a 2007 A4 2.0t for about 5 years now and it's recently started having issues. I just took it out for summer and it was running really bad, almost stalled whenever I gave it gas but idled okay with a slight hiccup every few mins, but would pull itself back. It had a check engine light so I bought a logger and pulled a coolant performance code (2181) and nothing else. I went through and did tune up stuff, plugs, coil check, fuel check, air filters etc, still couldn't give it gas.
I bought torque pro just to get some logs and found that anytime it went from closed loop to open loop was when it would show symptoms. Everything else seemed fine except for some smoke seemingly coming from the exhaust manifold and a ticking that I thought was lifter tick from my time with DSM's. I went to take the oil cap off and listen to if it was coming from inside the valve cover for sure and when I tried the suction was so high it nearly pulled the oil cap out of my hand and the car immediately started running super rough, nearly stalling. I worried it might be a head gasket issue at this point and took it to Audi.
I got a call this morning saying the valve cover is bad, I really don't know what that means, but ok, as well as a bad thermostat (2181 I assume) and the intercooler needs to be replaced. They all seemed like separate issues, but I was wondering how a leaky/bad valve cover would allow the type of vacuum that pulls an oil cap out of my hand and whistles when removed. Torque logged my vacuum between 18-21 inhg at idle and didn't show any spikes or dips, though that may just be what the computer thought.
I did some research since then and saw a few people talking about how a defective PCV that was under recall, and how it can cause the valve cover to leak oil into the turbo causing blowby. My intercooler definitely has oil in it, and I was burning through about a quart of oil every 2500 miles. Does this sound like a defective PCV problem more then a valve cover issue as the dealer says? They never mentioned the PCV on the phone, but I can do all the repairs myself if it's just a valve cover, thermostat, and intercooler, I just worry they are trying to get some paid business before replacing the PCV under recall, and that if I take the car home and replace the parts the problem will return because the PCV is actually defective. Any advice for me in this situation?
