Page 27 of 33 FirstFirst ... 172526272829 ... LastLast
Results 1,041 to 1,080 of 1306
  1. #1041
    Jun 04 2018
    Orange County, California
    How did you get the spacer to fit with the ultracharger? Did you have to trim the Carbon fiber tube?
  2. #1042
    Jun 04 2018
    Quote Originally Posted by Jfonse81 View Post
    New to the Meth community. Just installed the Snow performance stage 2 system and figuring out the best settings , if anyone here has experience with this system and want to share some tips that'll be great !?? .
    Right now I have it on 10psi start and full at 17psi .
    The car is APR stage 2 dual pulley 100 oct file , at this moment I'm pumping 6 gallons of 91 gas and 4.5 of E85 and I'm in a over 3K elevation city so octane levels change than normal (so they say ) .
    With this mix and settings I'm getting at wot a lambda reading of 7.8 to 8.3 , which I believe is good.
    I still have to check the logs , in which I'll try to do this weekend. Attachment 168187Attachment 168189Attachment 168191
    Sent from my SM-G973U using Audizine mobile app
  3. #1043
    Oct 20 2015
    Southern%20Hemisphere
    Quote Originally Posted by Jamen View Post
    Yes, had to cut 20mm off my IE intake tube
  4. #1044
    Jun 04 2018
    Quote Originally Posted by byront8 View Post
    Not sure I have that much room to cut on the APR unless I also reposition the breather tube
  5. #1045
    Senior Member Two Rings Jfonse81's Avatar
    Apr 15 2019
    coming soon RS4
    Nyc
    I thought I would have to cut the CF tube but when I installed it back, it went right in with no problem
  6. #1046
    Jun 04 2018
    Brilliant!! Thank you!
  7. #1047
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    Anyone here running a UC with meth ? If so did u tap it or get a plate ? And what TB plate are you guys using ?
  8. #1048
    Oct 20 2015
    Quote Originally Posted by Rodizzle View Post
    Yep running the IE TB with a Snow performance 400072 (I think) plate.
  9. #1049
    Jun 17 2015
    Bayarea
    Thank you I might just tapped the boost noodle .
  10. #1050
    Nov 29 2018
    Edmonton
    I had a bung welded in. The guy that did it had a hard time. But it's in there.
  11. #1051
    Veteran Member Four Rings PeteRock's Avatar
    Mar 08 2017
    Chicago
    What’s up Ro! My guys were able to get 2 nozzles in the UC boost noodle without issue.....
    Pete
  12. #1052
    Account Terminated Two Rings
    Jun 05 2018
    magimmeMVE
    Usa
    Is anyone using the Torquebyte CM5-LTS?
    If so how have you tapped a feed for boost and rpm?
  13. #1053
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    How many cc are you guys spraying? I hear of guys running 1000+cc but I can't run over 750cc because stft will jump to -48 lol. I'm running 2 #3 devil's own nozzles spraying 100% meth pre throttle body and seems to be working 20200415_084907.jpeg
    Sent from my SM-G935V using Audizine mobile app
  14. #1054
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    Quote Originally Posted by stevephilp View Post
    You can get boost from a boost tap plate at the bypass (I have the 034 boost tap plate) and the rpm signal from the CAN bus. The guys at TorqByte ([email protected]) helped me get the square wave rpm signal from the CAN bus.
  15. #1055
    Jan 11 2018
    Florida
    Quote Originally Posted by Shane Horning View Post
    How many cc are you guys spraying? I hear of guys running 1000+cc but I can't run over 750cc because stft will jump to -48 lol. I'm running 2 #3 devil's own nozzles spraying 100% meth pre throttle body and seems to be working...
    Tuner would have to adjust tune for the extra meth.
  16. #1056
    Apr 15 2019
    coming soon RS4
    Nyc
    No problem!
  17. #1057
    Established Member Two Rings S4b8.5black's Avatar
    Apr 20 2019
    Hamiton
    Where I mounted my meth nozzle with ultra charger . I think a snow performance adapter will fit tho as well . IMG_1398.jpg
  18. #1058
    Deactivated Two Rings
    Aug 06 2016
    ca san jose nor cal
    Dose it drop the egt a lot?
    Sent from my SM-N920T using Audizine mobile app
  19. #1059
    Apr 20 2019
    Hamiton
    Let's talk Water/Meth
    Yes helps a lot !
    In air intake temps
  20. #1060
    Jun 17 2015
    Bayarea
    Quote Originally Posted by S4b8.5black View Post
    I could confirm the snow adapter fits , you’ll just have to unbolt the ac line to give it room .
  21. #1061
    Nov 16 2018
    Upstate. New York.
    Hey man how is the ultracharger working out for you? Notice a big difference?
  22. #1062
    Registered Member One Ring R1XS4's Avatar
    May 11 2020
    2016 Mercedes C300 & 2016 Yamaha R1
    Omaha, NE
    Hey guys, new here. I apologise if I didn't see this already, but would you recommend thread tape any specific place?
  23. #1063
    Veteran Member Four Rings JACKAL's Avatar
    Mar 28 2017
    Infiniti QX70S, Indian Scout Bobber
    Southeastern Wisconsin
    Quote Originally Posted by R1XS4 View Post
    I know there are a fair amount of people who install the nozzles directly into the bungs/adapter plates w/o any additional sealant (myself included) and have no issues. Because of the nature of where the nozzles are installed (low pressure/vacuum zones) and how these cars monitor air intake (speed density vs MAF), even if you have a tiny amount of air sneaking in around the nozzle, it isn't an issue and you certainly won't be pulling in any particles larger than what would pass through your air filter.
    B8 Sprint Blue S4 | 6MT | 034 Motorsport Stage 2+ E40 (3.40 PR) | Tampa Autosports Ported Blower | AEM Water/Meth 1000cc | Test Pipes | CTS Turbo Downpipes | MF 11385 | AWE Touring | Injen Intake | 75mm Ported TB | Merc Racing HX | Stoptech 6 Piston BBK | Stainless Brake & Clutch Lines | SB Stage 3 End. Clutch | Eurocode Short Shifter | D-Steering Wheel | Autotech HPFP | 034 Motor Mounts | Low Kick Spoiler | RS Bumper | Verde V99 19x9.5 Wheels
  24. #1064
    Jun 17 2015
    Bayarea
    Quote Originally Posted by PeteRock View Post
    Pete
    Just saw this Pete , thanks for the input . I ended up adding a spacer . Worked great
    Definitely more responsive , pretty happy with it . No issues or anything weird about it . I feel like it gave me a slight bit more mid range
  25. #1065
    May 11 2020
    Omaha, NE
    Great to know! Thank you!!
    Also, regarding the throttle body options, is IABED the only option?
  26. #1066
    Established Member Two Rings darkstarghost's Avatar
    Feb 08 2014
    2014 Estoril blue s4
    Ill be writing a DIY for my setup in a while. But if anyone is installing a snow performance, Stage 2 MAF/MAP controller. It requires a 0-5V input from the MAP sensor. I'm unsure on if the wires match on all of the 3.0t models but for my 2014 S4 it is the YELLOW WITH BLUE stripe on the driver side MAP sensor. Hopefully this can help someone who was in my situation
    Estoril crystal blue,APR Tune ,stainless steel clutch line, Custom Audi ring subs, BFI weighted shift knob, Passport 9500ci stealth install(in mirror),custom 1 off carbon fibre inlay blue trim, ecs kohfllufl luft intake, Stasis challenge mode exhaust, USP stainless steel brake lines, P3 multi gauge, Snow Performance Meth
  27. #1067
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    speaking of 0-5v inputs... I'm really trying to avoid splicing our OEM MAP sensor. I want to install a torqbyte controller which needs RPM and MAP signals. I don't have the MAP sensor/pigtail and it's sold out from Torqbyte. Does anybody smarter than me have any ideas about replacing these components? I've gone down the rabbit hole a little bit but no luck so far. Here is what I'd be looking to source an alternative to.
    https://torqbyte.com/products/honeyw...45f33c6d&_ss=r
  28. #1068
    Apr 28 2019
    Baltimore,MD
    Quote Originally Posted by GandalfTheIbis View Post
    How about just get a GM 3 bar map sensor instead, they are good for ~30pis over sea level
    2014 S4 stage 2+ DP Revo HX
  29. #1069
    Apr 04 2017
    Chicago IL
    That is a good route, still need the pigtail though
  30. #1070
    Nov 29 2018
    Edmonton
  31. #1071
    Apr 28 2019
    Baltimore,MD
    https://www.amazon.com/MAP-Sensor-Wi.../dp/B07KQD2SP5
    or make your own, weatherpack connectors are pretty easy to work with.
  32. #1072
    Apr 04 2017
    Chicago IL
    Realized I meant the plug after the fact. And this is why I need you fine folks. My tech is probably reading this and laughing anyways
  33. #1073
    Jul 03 2018
    Asia
    Hi Ro im looking forward for the same setup..where can i buy the bolt to secure tb-plate-uc adapter and wht is the length thanks
  34. #1074
    Jun 17 2015
    Bayarea
    Quote Originally Posted by brojohn View Post
    Bro ,
    I was lucky to have them from my old set up . They came in Iabed meth TB spacer . They were to long so I ended up using my stock ones .
    Which worked out great for the Uc meth spacer
    Someone correct me if I’m wrong :
    But I believe the throttle bolts are M6x1.00 (from hemi ) x 70mm ( I just measured the length )
    Mine are 80mm that’s why they stick out
  35. #1075
    Jul 03 2018
    Asia
    Bro ,
    Thanks Ro appreciate it, i’ll look into my local hardware store which is specialist in bolts and nut then haha..im running custom pipe with porsche 82mm tb..looking to inject post tb at the iabed meth plate which was ported at 82mm...what is the best single nozzle cc then for iat?..running 187/57 dual pulley with divorce merc currently..bought mine Snow stage 3 and going for trunk setup..heard devil own nozzle and solenoid were superior might want to order that as well from them and combined altogether
  36. #1076
    Jun 11 2014
    Ny
    Newbie questions .
    I just order the AEM 30-3300 kit, iabed tb plate, prometh 630 and 1100 nozzles. I was recommended to use solenoid, which ones to buy ? Do most people use solenoid and another fail safe options? How often do you guys refill a 1 gallon tank? Ideally, I'd want it to last a full tank of gas . I was leaning mounting the pump and tank between the firewall.
    Am I overlooking anything?
    How easy is it to switch nozzles? Do you have to buy a TB for each nozzle or are they easily interchangeable ? How do you determine which size nozzle works best ?
    Can someone direct me to which solenoid to get?
  37. #1077
    Jun 17 2015
    Bayarea
    No worries ..if you can’t find the bolts , Amazon had some believe and fasteners . I spray 1000cc single nozzle (8psi/18psi) , IAT stay pretty stable .
    Quote Originally Posted by Gkit19986 View Post
    Newbie questions .
    This the solenoid I run and works great .
    https://www.summitracing.com/parts/sno-40060
  38. #1078
    May 05 2018
    South Florida
    I think most of us run that same one. I believe theres a newer revision of the Snow one and AEM has released their own, which I have as a backup but I never had a problem with my Snow one that Ro posted.
  39. #1079
    Nov 16 2018
    Upstate. New York.
    What % methenal do you spray
  40. #1080
    Jun 11 2014
    Ny
    Quote Originally Posted by killer_s4 View Post
    Thank you guys!.
