Any guesses on what the issue might be? I'm thinking one of these 3 base on scan results below.
1) Compressor Regulating Valve (N280) faulty
- this can be related to the intermittent fault I'm getting under: 00898 - Control Circuit A/C Compressor
2) Refrigerant is low
- doesn't seem plausible since it works fine sometimes??
3) Failing A/C Pressure/Temperature Sensor (G395)
- I have not seen a fault code for this, but it seems to be a common issue
Code:
------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA Component: KLIMA 1 ZONE H06 0140 Revision: A1000000 Serial number: 0106.10.080892 Coding: 64002000 Shop #: WSC 06335 000 00000 VCID: 70E848EFA3B0B4BEAD-8024 3 Faults Found: 00898 - Control Circuit A/C compressor 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 58 Mileage: 162410 km Time Indication: 0 Date: 2017.01.26 Time: 10:01:47 01273 - Fresh Air Blower (V2) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 80 Reset counter: 18 Mileage: 162410 km Time Indication: 0 Date: 2017.01.26 Time: 10:01:47 Freeze Frame: Temperature: 9.0°C Speed: 0.0 km/h Voltage: 0.00 V Current: 0.000 A Voltage: 12.40 V 01844 - Control Module for Fresh Air Blower (J126) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 3 Fault Frequency: 41 Reset counter: 49 Mileage: 162410 km Time Indication: 0 Date: 2017.01.26 Time: 10:01:47 Freeze Frame: Temperature: 9.0°C
