Originally Posted by
2015S3
When I owned a shop with a dyno we used to see all OTS and custom tunes. We actually used to run the OTS rune as a baseline and then adjust with the Acessport. This was Subby/Evo and GTR tunes.
We have had some OTS tunes come in that we couldn't actually better (safely). All of OTS tunes were tuned to be safe to take into consideration all weather conditions, driving styles, altitude etc.
Even when we did Dyno tune we used to "turn it down a bit" before the customer left (everyone is sooo concerned about a Dyno sheet and 5 WHP they made over their buddies). This assured us that they weren't going to floor it in 5 or 6 gear at 3000 rpm and put extensive loads on the engine, ones that you cant see on the dyno. Todays OTS tunes are pretty damn good and our ECU's are super fast and reactive.
I am running stage-2 ED and Stage-2 ED TCU. Meastro is not out yet for our platform so I cant try to adjust myself, the adjustable map for Octane and boost in my opinion is a gimmick as the ECU reacts quicker to low octane levels and pulls timing anyway. Maestro is a different beast, you can make HARD settings on the ECU through the tuning suite.
We had a guy come in with a Dynosheet printed at 520 WHP on a 2011 STI, we didn't touch a thing and actually gave him a little on the correction factor, he made 415 WHP. I can make a Dyno read whatever I want it to keep that in mind here guys.
This is very good advice. I used to be in the Subaru game and everybody would be dick swinging about their Dyno numbers. I had one of the best tuners in the area tune my STI and I was super disappointed in the numbers. But, when you compared stock to tuned, the gains were huge. My stock 2007 STI was only putting 210 WHP down but after the tune I was putting down 265 whp and 315 ft lb of torque. While my peak numbers weren't touching others numbers, my overall gains were much higher than the others.
So basically, you can make a dyno read whatever you want it to read. The important thing is that the tune is safe and the total gains in AUC after the tune. That is why I take all flash tune marketing with a grain of salt.
This is why I have a similar thread started with my main goal of being safe and trouble free...because most tunes are within a stones throw of each other.
