Page 1 of 3 123 LastLast
Results 1 to 40 of 94
    Veteran Member Three Rings Midnightblkb5's Avatar
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    YuH8MYB6? A4 B6 Cabriolet 2.7T build thread
    before i get into the thread i would like to thank a couple of people, Mr. Frank Hamza (engine teacher at Pennco tech), LOT4R (my boys for helping out), AudiA4_2.0t, Raul (street works tuning custom y pipe) Willson (all around performance) Blitz2190, bische, Corrado Rob (bully customs - powder coating), my wife for supporting me on this two year build, Jeremy castop for rush tig welding everything in a rush and the s4 lol, and last but definitely not least johnny blaycey!
    now on to buisness
    car- 03 A4 cabriolet
    apb 2.7t stock bore and pistons
    2.8l cams, bank2 coolant pipe, exhaust manifolds Vbanded flanges (streetworks tuning)
    custom exhaust manifold (streetworks tuning)
    OEM gaskets (every damn gasket and seal on the entire engine)
    SRM forged H Beam rods
    034 calico coated main and rod bearings
    034 ARP un-even main studs ( pan clearanced)
    034 fuel rail, Fpr housing, and fp gauge
    034 SAI block off plates
    034 2.0t adapter plates
    034 an10 22mm drian fittings
    034 sandwich plate adapter
    034 fuel pump bracket
    Pure stern motor mounts and trans mount
    Bosch 040 fuel pump w/ ss check valve on top
    Bosch ev14 injectors
    Fuel lab fuel filter
    Turbo Holset hx40 W/ 63ar hotside (all around performance)
    yonaka fmic 3" core
    AEM 52mm digital wideband gauge and sensor
    AEM 52mm digital boost gauge
    vibrant 2 port catch can
    Tial 38mm wategate
    Tial 38mm QR recirculating bov
    Gates blue racing belt
    audi R8 engine caps (all of them)
    russell an10 an6 fittings and hoses
    fx 6 puck clutch and stock dmfw
    brabus monoblock v 18x8.5 and 18x9.5 (powdercoated by bully costoms)
    b6 s4 everything under the car ( i mean everyting)
    "comp turbo" turbo blanket. (lol its there)
    ebay 2.5" turbo piping
    3" t304 stainless exhaust
    Euro boot.
    OEM B6 s4 mirror caps
    porsche 18z front calipers
    b8.5 s4 rotors
    SS braided brake lines
    s4 cabriolet upper and lower front grilles
    s4 gauge plates in original 3.0 cluster
    His 03 a4 cabby 3.0! quattro swapped 0A3 6 spd 2.7t single turbo holset hx40
    Hers 06 a4 b7 3.2 tip
    build thread@ http://www.audizine.com/forum/showth...2#post12428942
    Established Member Two Rings alexb6t's Avatar
    Mar 11 2016
    quebec canada
    Sub!
    Envoyé de mon SM-G903W en utilisant Tapatalk
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    i started off with an 01 a6 apb engine that i pulled from the yard myself
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    then i took it to work and completely tore it apart with the intentions of putting a 3.0 crank in it, but scrapped the idea
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    i started cleaning, honing, and re gasketing everyting
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    i met a guy out in P.A that had a dope b5 and found out he did powder coating. from there we became good friends and we went to work on powder coating everyting thx bully customs!
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    i got the turbo from a friend! thx wilson it just needed a hot side so i bought a 63 ar from tims turbos
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    i had a b6 3.0 i was trying to put it in but end up selling the car to a fellow crew member. i know pic whore lol
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    i snached up a jumper harness from clint awhile back and sold it when i got rid of the car! i kicked myself for selling that harness cause the wiring was a pita since the car started off originally a fwd cvt! but i grabbed a 5 spd swap for the car and began the quattro swap.
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    my boy jeremy sold me an 05 s4 in which i parted out with two of my boys so we ended up ripping out the 5 spd rear and tank and switched to the s4 rear and tank. we put in the s4 0A3 a week later along with the drivshaft and exhaust. i also took all the brakes and rotors along with the spindles. basically everything that was under the s4 now resides under the cabby!
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    once that was all buttoned up! i started ordering parts
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    i fitted the trunk (boot) and started sanding and priming the bumpers for a respray
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    i got some wood from the depot and did the trunk. im still working out the sub box as of now
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    my crew was getting ready for sowo in G.A. so i decided it was time to drop the engine in! my boy corrado rob let me bully the shop for two weeks and we got it done after i torqued down the engine and put on the clutch. i added a couple of shots in of me doing the wire tuck and raul doing the custom y pipe.
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    i had been watching a set of brabus monoblock v wheels that my cousin had at his house for about 8 years. so i finally bought them from him and had rob bully those things back to life. i think they give the car that timeless look! thx govi
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    and here it is on the first start, i mean running start, cause it rarely happens the first time ctfu!
    https://www.youtube.com/watch?v=S3R-...ature=youtu.be
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    very nice congrats on the swap. everything looks great. One quick note on the turbo up pipe, your going to want to put a short flex pipe in to keep the pipe/manifolds from cracking from heat expansion. other than that that engine looks great.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    May 27 2016
    Westchester, NY
    Love it!
    Established Member Two Rings Europotvin's Avatar
    Feb 03 2015
    Sherbrooke Quebec
    Wow !!! Sick project, keep up the good work.
    APE - Automotive Performance Engineering http://automotiveperformanceengineering.com
    A4 B6 TDI 6spd
    BUILD THREAD: http://www.audizine.com/forum/showth...o-Diesel-Build
    INSTAGRAM: euro.po
    Senior Member Three Rings dalazybastard's Avatar
    Apr 08 2016
    Orange County, CA
    Gonna be a sweet convertible when it's done.
    For the record...what yard has a lift for customer use. Never seen that in SoCal.
    Just a couple B5's, you know.
    Oct 29 2005
    10speed
    San Francisco, CA
    This is my favorite build on AZ hands down
    - Clint
    Established Member Two Rings bigab24's Avatar
    Jan 01 2016
    South Florida
    No this is actually happening? Subbed! Wanted to do this to my B6 Cab ever since I found out how much the 3.0 timing belt is.
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    Quote Originally Posted by dalazybastard View Post
    The OP is in NJ and not SoCal.
    I feel like I helped with this since I bought parts from the S4 :)
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    Nice work! why were you thinking of a 3.0 crank in the 2.7? First I hear of this.
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Saint Cloud, Fl
    Very nice progress.
    instagram ------------> low_enforcement
    Apr 08 2016
    Orange County, CA
    Quote Originally Posted by MurkyRivers_A4 View Post
    I know that, but still pretty cool to have it available.
    Jun 29 2014
    America
    very impressive work!!!
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    Quote Originally Posted by blitz2190 View Post
    thx bro i have already welded one in
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    Quote Originally Posted by Ephry73 View Post
    Love it!
    thx
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    its in nj! yard called blaceys
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    thx clint
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    facts lol
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    Quote Originally Posted by audireme View Post
    thx
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    Quote Originally Posted by Gosser View Post
    stroker brother lol
    Jun 27 2015
    buffalo ny
    Nice work
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    Quote Originally Posted by visabroke View Post
    Nice work
    thx
    Established Member Two Rings phantommenance's Avatar
    Jun 22 2009
    2018 AUDI Q5
    queens,ny
    Cant wait to see it run , there was one other project like this on the convertible thread but has disappeared. Glad to see decided to finally do once
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    update! wheels torqued and ready to be mounted on fresh pirelli p-zeros
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    L this is just plain dumb, you need to give this to me, to .. you know.. hide it.... lol or drive the shit out of it!! woohoo!
    Pretty epic work man! was wondering where you dropped off to, looks like you have been pretty busy! looks and sounds great!! I am still working on mine as well, I will PM you some pics.
    Keep up the great work!
    Subscribed as well.
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    Quote Originally Posted by Terry.Reese View Post
    Subscribed as well.
    thx t
