Originally Posted by
jygesq
Tell us how, please.
Here are the steps I took with pics.
- Remove driver side wheel
- Remove fender splash shield/liner
- Next to the headlight housing you wheel see a skinny plastic box, when you locate it, follow these steps.
**You will be working from under the fender, but all steps are exactly same**
STEP 1: Wiggle the skinny plastic box off the radiator support. (bracket has tight clips, but not will slide off)
STEP 2: Separate the metal clip from the black plastic box (You need to do this to be able to open the box, shown later)
STEP 3: Pull the cable slightly to the left and at the same time fling open the cover. (This step somehow took me 2 seconds, maybe I got lucky)
STEP 4: Remove the cover from the other end and see mechanism exposed
STEP 5: Dissemble the connection like so.. (I still had the cover on, but it should be removed)
STEP 6: Grab the black box **not the wire** and pull along the radiator support. Don't try to yank it open from first try, if it doesn't pop the hood release it and try it again. Play with it.
Hope this helps someone.
I'm still trying to figure out what is broken in the system to replace it.
