Results 1 to 25 of 25
    Veteran Member Three Rings VeNoMS4's Avatar
    Feb 02 2016
    Peoria, Arizona
    Question Signs of mechatronic failure
    As mentioned on my signature.. i have a 2011 with DSG tune from GIAC and it's around 68k miles. couple questions are:
    1) Is there an average mileage where the mechatronic failures tends to happen?
    2) Are there any signs that one can watch out for? (visual, sound, smell, etc)?
    Thanks
    2011 S4 -Ibis White // GIAC Stage I // GIAC DSG tune // AWE Track Cat back // Injen SP Intake // VMR V710 19x9.5 //
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    http://www.audizine.com/forum/showth...t=Mech+failure
    Tons of threads with a lot of information. Search is your friend, friend.
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by DBL R View Post
    i guess there is no answer to my first question since the miles seems to all over the place. As for signs, people speak of this bucking motion whenever you shift from 1-->2. However, no one speaks of where during the rev range it happens. It sometimes happens to me when i shift (electronically lol) at RPMs below 3k. Above it, i dont see it. I just want to prevent a $5k repair bill.
    Mar 20 2010
    2010 B8 S4 red with red inter, 77 Trans Am (orignal owner); 2005 Subaru Impreza RS
    MD
    I had about 76K miles when mine was replaced. The issue was that after about 15 min of DC traffic or hot weather, the shift from 2 to 1 when making a stop I would all of the sudden get a big clunk noise and lunge forward. Since being replaced no more issues. I have 92K
    My car is a 2010.
    When I purchased the car new I bought the extra extended warranty. Saved my ass twice: Thermostat and Mech replaced.
    Nov 02 2016
    New England
    Quote Originally Posted by jscaf View Post
    My car is a 2010.
    Hey, can you explain more? My 2014 does this when I downshift from 2 to 1 below 2000rpm. Is that not normal?
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    Quote Originally Posted by xxdunnxx View Post
    mine does the same 2013 here
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Feb 02 2016
    Peoria, Arizona
    My car is a 2010.
    i have aftermarket warranty as well. But they denied a claim for the serpentine belt and S/C drive unit because my car has an after market exhaust. I wonder if they will deny me again if my trans ever gives out.
    Established Member Two Rings vanguard12's Avatar
    Jan 05 2017
    2014 s4 here. Had the bucking motion from 2nd gear to 1st gear at 14k miles in 2016. At its worst in the stop and go traffic in NYC. Took it to a NJ dealership and they replaced the entire transmission. No bs steps in between from them such as "we'll replace the trans oil" or "no error codes" or even "might need a new mech unit." The service advisor just went for the jugular right out of the gate and said we found some iron content in the tran oil and will be replacing the transmission under warranty. ~2 weeks later the thing was shifting fast and crisp.
    Veteran Member Three Rings toastsauce's Avatar
    Apr 08 2014
    Jersey City, NJ
    Quote Originally Posted by vanguard12 View Post
    were you tuned/modded at the time?
    2014 Audi S5
    034 Stage 2+ ECU & TCU | 75mm TB | Ported SC | Roc Euro CAI | Merc Hx | B12 Pro Kit | 034 Rear Sway + Links | 034 Motor Mounts
    JHM Test Pipes | EC Alu Kruez | CR-15 | EC T&B Diff & Trans Mounts | USP SS Brake Lines | EBC Yellow Stuff Pad | BP Slotted & Drilled Rotors
    Established Member Two Rings SQuattro08's Avatar
    Jan 09 2015
    San Jose, California
    I had mine replaced (2010 S4) at no cost due to a CA emissions warranty which was awesome news. I had the horrible bucking from 2nd to 1st (would get increasingly worse if sitting in any traffic). There was a software update available that Audi release to help with this issue. One night I got the notice on my dash that said that there was a transmission malfunction but could continue to drive.
    Brought her in and they found that the much unit needed to be replaced. Below are the error codes found. Took 2 days to get my car back but all issues seem to be long gone (at least for now).
    Sent from my SM-G930V using Tapatalk
    Established Member Two Rings TheAsset's Avatar
    Jul 14 2016
    MO
    Quote Originally Posted by VeNoMS4 View Post
    Who did you have your warranty through? That's nuts. That'd have my blood boiling.
    2014 Audi S4 Prestige - Misano Red
    IG: @TheAss3t
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by SQuattro08 View Post
    Can you elaborate on this more please? Your 2010 is out of warranty, but cali has some emissions warranty that helped repair the trans??
    Sent from my iPhone using TapaMilf
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by TheAsset View Post
    fortegra.. the fact they wont cover it pissed me off to no end and i even thinking about getting a lawyer due to the magnusson moss act. But fine prints in the contract which i signed said any modifications to exhaust will void drivetrain. I didnt know what to do after that but just pay for the repairs myself.
    Jan 09 2015
    I'm not 100% sure really and didn't take the time to read up on it fully. But yes, my car was out of warranty. Took it in and they found the codes. Got quoted $1700.00 if I recall originally to replace the mech board in the trans. I agreed to the work being done not knowing about the warranty but got a call back from my SA who said I have some good news the work will be covered under warranty at no cost.
    Dec 30 2015
    Sacramento, Ca
    Ahhhh ok all good brotha...figured you might have more specifics. Well shit that was great news, Christmas came early lol.
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    How do they justify voiding a drivetrain warranty just because of an exhaust? That's ridiculous.
    Also, how did the warranty company even find out that you have an exhaust?
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Feb 02 2016
    Peoria, Arizona
    They can't justify that there is any correlation. But the contract was signed unfortunately. They sent out an inspector.
    Mar 21 2015
    I would just cancel that warranty and try to get some of your money back. It's useless.
    Apr 29 2017
    Edmonton Alberta Canada
    A lurch downshifting from 2-1 is a sign of mech faluire? iv got this happening mostly when i shift manually. 2012 dsg 86k KM( roughly 53k miles)
    New to the car so i have no idea what normal is for this thing.
    May 09 2012
    United States
    Quote Originally Posted by Status1 View Post
    Slow speed downshift from 2-1 lurch is normal.
    Jan 01 2010
    2010 B8 S4, 2014 Audi Q5 TDI, 2013 BMW S1000RR
    Wayland, MA
    I have 2010 B8 S4 and the tranny started misbehaving at around 50K miles. All of the symptoms noted above and definitely not just a normal DSG lurch. It got so bad I had to be really careful with nose-in parking not to slam the front of the car into walls. It got to be intolerable driving in heavy traffic. The dealer did a $300 reprogramming that more or less fixed the problem but only after another 2K miles of driving. The dealer also said that the tranny's tiny brain has trouble "adapting" to different driving styles so my wife and I stopped swapping cars for our commutes. Now at 75K the symptoms are creeping back so I have traded for a B9 that will arrive in July. Got a good trade-in appraisal so I'm putting as few miles as possible on the B8 until the new car arrives. Can't wait for the ZF - never imagined I would feel that way!
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    I'm at 60k and haven't had any issues with the DSG or Mech unit. Knock on wood. I recently had the TCU tuned though, which was well worth it IMO. Time will tell. I'm about out of warranty anyways.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    2012 with 50K miles, no issues yet...knock on wood
    there will be times where the 2-1 shift gives a little clunk, but nothing major as it only happens in dynamic mode. Auto or comfort is smooth always
    I do get a weird hesitation or delay when downshifting though in manual mode. I can change gears and it will take a few seconds for the revs to catch up and popup to where they should be. Happens 4-3, 5-4 mainly and in any mode. Anyone else get this? Im tempted to get a TCU tune with EPL when i pull the trigger on stage 1.
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    May 15 2017
    Central TX
    Quote Originally Posted by SDV325 View Post
    I get some delay on downshifts as well in manual mode. I have a TCU tune from APR too.
    Established Member Two Rings Dark-e's Avatar
    Sep 23 2018
    2006 CBR600RR
    Belleville, IL
    So I bought the car with 76k miles on it. I had the dsg fluid and filter changed around 80k miles. I have never received a code for any malfunctions, but on a cold start in first gear the revs will bounce a little like the clutch is not engaging. I do not know what to do because this does not seem like a mechatronic failure as I am not getting any codes.
    2010 B8 S4 Ice Silver Metallic unitronic stage 1+, audi flood lights, IE Intake, magnaflow 11385 resonator delete, RS style Grille, Michelin AS3+
