Results 1 to 23 of 23
    Active Member Two Rings Squisit's Avatar
    Aug 12 2013
    2015 lexus IS 250
    Fort Lauderdale Fl
    What aftermarket parts can transfer from B8 to B9 S5?
    Looking into buying a new 2018 Audi S5, wondering what aftermarket parts can be transfered to the new car from my 2011 S5. I know its a new chassis so assuming the AWE track exhaust won't fit the B9. I have H&R street coilovers, will they fit on the 2018? i would love to transfer my wheels, they are DPE SC5 20x10 all four corners with 275/30/20 Dunlops. Is this wheel setup too wide for the B9? I haven't seen any posts on mods for the B9 so I'm sure these are questions everyone is wondering. Maybe Mops the fitment guru can chime in. Thanks!!
    Registered Member One Ring AWSM-S5's Avatar
    May 16 2017
    2017 Audi Q7
    H&R should have coilovers out soon for the B9. The wheel fitment has not changed and your current wheels should fit just fine.
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by AWSM-S5 View Post
    I was told the wheel fitment for the b9 is less aggressive than the b8/8.5
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Senior Member Three Rings Alessandro's Avatar
    Sep 23 2010
    Audi Q3 2017
    spacer's for sure if you run any
    2018 Audi S5 SB /Glacier White/ Fully Loaded /
    Veteran Member Three Rings QuaTTrings's Avatar
    Aug 24 2005
    Denver, CO. USA
    I test fitted my RS7 spacers on the S5 Sportback, seemed to be about right. 17.5mm rear and 12mm front. Ended up tossing these wheels on since they were collecting dust.
    2024 RS e-tron GT - Suzuka Gray
    2022 M3 Competition - Dravit Grey
    2022 Model 3 Perf - Stealth Gray
    2018 RS5 - Glacier White
    2018 S5 SB - Mythos Black
    2016 RS7 - Daytona Gray Matte
    2016 RS7 - Prism Silver
    2013 RS5 - Suzuka Grey
    Veteran Member Four Rings freesole's Avatar
    Oct 30 2011
    Quote Originally Posted by QuaTTrings View Post
    Wow that looks hot. Ecodes? Do you have some side shots with those wheels?
    Current
    '22 RS6
    '22 X3M Comp
    Gone
    '19 SQ5
    '18 S5 Sportback /// Build Thread
    '16 Q5 3.0 /// Build Thread
    Insta: @frees5ole
    Veteran Member Three Rings socialpro's Avatar
    Sep 26 2013
    2023 RS6 || 2022 XC60
    scottsdale, az
    Beautiful! +1 on a side shot of this ride!
    Aug 24 2005
    Denver, CO. USA
    Thanks! Here's a couple of side shots.
    Oct 30 2011
    So good. Mind me asking for specs on wheels? I'm about to order the S5 Sportback as well and I am gathering ideas :)
    Current
    '22 RS6
    '22 X3M Comp
    Gone
    '19 SQ5
    Insta: @frees5ole
    Veteran Member Three Rings emnahum's Avatar
    Jan 10 2014
    BO grille looks great.
    2015 S4, P+, 6MT, Mythos/Black Nappa, SD, ADS, B&O, BO, Tech, Opticoat, Xpel Full Hood, 034 Transmission Mount, EC Sways & Links, CR-15
    Previous: 2004 A4 Avant 3.0 V6, 1995 90 Sport Quattro, 1984 4000 CS Sport Quattro, 1981 4000 5+5
    Aug 24 2005
    Denver, CO. USA
    Quote Originally Posted by freesole View Post
    The wheel specs are 21x10.5 32ET.
    Oct 30 2011
    Thanks, they look great. The blacked out theme with the red calipers really look sharp. I think I will probably go with 20's on mine.
    What did you do with the orange marker? Did you vinyl/tint it?
    Current
    '22 RS6
    '22 X3M Comp
    Gone
    '19 SQ5
    Insta: @frees5ole
    Aug 24 2005
    Denver, CO. USA
    20s will look awesome and after measuring the rear strut and edge of my rim, I think 11s will fit if someone wanted to go that route. I removed the headlights and separated them to get to the Amber reflector. It just pops off. Thankfully no oven needed unlike a past Audi ive had. The only thing is the led behind the reflector is Amber. I would like to turn it off with vagcom or Obd eleven if possible. It's not bad since it's a single LED but think it would look cleaner at night.
    Oct 30 2011
    No rubbing issues with your setup at all (not sure what your tire setup is though)? I would be happy with 10" width on wheels but I heard that wheel fitment is limited on this B9 A5/S5 platform. On the headlights, nice work. I did that once a long time ago with my first car but would be too chicken to try it with a new car lol.
    In any case, fantastic work. Your car is the best looking B9 S5 I have seen so far. Gives me some inspiration for when I get mine in.
    Current
    '22 RS6
    '22 X3M Comp
    Gone
    '19 SQ5
    Insta: @frees5ole
    Sep 28 2010
    NW NC / DE
    Yea, the previous 5 would take 20x10 ET25 on 275 no problem. That setup on the B9 5 cars pokes from the fender 6-8mm. So definitely no more 20x10.5 ET25 on 275/285 like we used to run.
    Very very nice!
    Aug 24 2005
    Denver, CO. USA
    Thank you, I dont have rubbing but I did remove that one front fender liner screw that's historically notorius for making noise just in case. I also have one of the more narrower 275s on the car so the tire stretch on the 10.5 definitely helps.
    Thanks Mops!
    Very very nice!
    Sep 28 2010
    NW NC / DE
    I feel like the new sweet spot is going to be 20x10 ET35 on 275/30. There are going to be come very lonely 20x10/10.5 BBS CH and CI sitting at headquarters in GA.
    Jan 09 2009
    1of50
    another local member is running 275/30/20 VFF103 +30 wheels, but had to use a 5mm spacer in front to clear the brakes. Waiting on him to send me a frontal pic to see what the poke looks like visually.
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by cheewy16 View Post
    Please do post. That sounds like 5mm+ poke to me.
    Vorsteiner now has a 20x10 ET30 made for larger brakes. So if the extra 5mm bothers him, there is an option.
    Oct 30 2011
    Other than the 103, I wonder how the 107 would look in carbon graphite on a florett.
    Current
    '22 RS6
    '22 X3M Comp
    Gone
    '19 SQ5
    Insta: @frees5ole
    Sep 28 2010
    NW NC / DE
    Could be hot! Only issue I foresee is the same we've dealt with on the Q's. Brake clearance. But thankfully the B9's have a nice looking larger caliper, so we cannot complain. We'll just have to wait and see what fitments clear.
    Jan 08 2014
    VW Tiguan R-line B9 S4 *SOLD 16 S3 *SOLD
    Delaware
    Looks Awesome!! I'm waiting for Audi to add Black Optic then it will be time to order
    Active Member Two Rings CAT3's Avatar
    May 03 2017
    Farr West/Utah
    Look Fantastic, you must only drive on airport runways with those.
