Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 129
  1. #81
    Active Member One Ring SnowballAvant's Avatar
    Nov 13 2017
    Grand Rapids Mi
    Dual zone, backup camera, backup sensors, navigation, and other things I’m sure I’m forgetting.
  2. #82
    Aug 19 2016
    Newport Beach/CA/USA
    What coding did you change? You shouldn’t have changed anything in backup camera, backup sensors, or anything like that, overall the changes should have been with climate control only.. is the backup camera and backup sensors not working?
  3. #83
    Nov 13 2017
    Grand Rapids Mi
    Quote Originally Posted by prkieffer View Post
    I actually got everything working. I have one weird issue where the display brightness doesn’t seem to change. Then when it’s light outside the screen is so dim that I can barely see it. Also tried to active drive select, got the options to come up on the mmi but I can’t select the different settings.
    Sent from my iPhone
  4. #84
    Aug 19 2016
    I had same issue go into green screen to fix. Go into hidden menu under display uncheck display then reset MMI.
    I attached picture uncheck top box, reset MMI and should be good to go.
  5. #85
    Nov 13 2017
    Grand Rapids Mi
    I’ll try that, thank you!
    Sent from my iPhone
  6. #86
    Dec 26 2008
    STL
    So this is really an incredible thread, great job guys!
    I have an 09 with build date of 04/09 and unfortunately it comes with 2G High, navigation, voice commands, camera, drive select, and B&O.
    What components will I need besides the obvious (New screen, screen trim, MMI unit that holds ESP switches, new center console unit that has joystick buttons)?
    Trying to upgrade to 3G+ as in 2013+ models.
    Thank you!
  7. #87
    Aug 19 2016
    That’s everything
  8. #88
    Dec 26 2008
    STL
    Thank you, what about any wiring harnesses or adapters/antenna connectors? I thought there was some new wiring needed from Kufatec between the Navigation screen and MMI?
  9. #89
    Aug 19 2016
    Kufatec wiring harness yes. It’s on their website. You can also hit the junkyard and possibly have them pull the wires from a total A4/S4 with MMI already.
  10. #90
    Dec 26 2008
    STL
    Thank you, I appreciate that! At least now I have a list to go by..
  11. #91
    Nov 13 2017
    Grand Rapids Mi
    I’ve activated drive select and it comes up on my screen but I’m not able to select the different modes, it’s stuck on individual. Anyone else have this issue?
    Sent from my iPhone
  12. #92
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by SnowballAvant View Post
    Sent from my iPhone
    Install a button!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
  13. #93
    Nov 13 2017
    Grand Rapids Mi
    Quote Originally Posted by Gunnark100 View Post
    Install a button!
    Is that the only way to get it to work?
    Sent from my iPhone
  14. #94
    Dec 26 2008
    STL
    Sent from my iPhone
    That’s a good question, my car has drive select but I have three buttons for it.. would I have to upgrade to a single button option?
  15. #95
    Nov 19 2017
    Naples Florida
    I have the same issue. I just updated my MMI from 3G to 3G+ and I can't control my drive select from the main screen unless I go to the "set to individual" on the bottom right of the screen. If anyone has a fix that would be great. Or the part numbers and guide on how to install the button. Thanks.
    Sent from my SM-G950U using Audizine mobile app
  16. #96
    Nov 19 2017
    Naples Florida
    Quote Originally Posted by Jeff V. View Post
    Keep in mind that my MMI3G is just a pile of parts on my workbench. But it does load up the maps and Google nav stuff. I have it connected to my home internet using a USB to ethernet adapter. I didn't have to do anything special to get that going. It worked out of the box. The media player just says 'initializing' but I chalked that up to it not actually being installed in a car. There's no radio or amp for it to talk to either.
    Can you see if your MMI unit has any error codes in it? When the system first starts up, you can see the little Google logo in the bottom corner fill up like a progress bar. It's not super obvious because it just changes from light gray to white. Is yours doing anything?
    Can you explain the usb Ethernet set up?
  17. #97
    Mar 03 2014
    north nj
    I just got a 2011 a5 prestige s-line and want to upgrade to mmi 3g+.
    I checked these part numbers and only one is still available the rest are discontinued.
    HARDWARE:
    MMI head unit (Part #8R1035746C)
    MMI climate unit (part #8K1820043T)
    My control set (RS5 aluminum style buttons) is part (#8T0919609K)
    Are there other part numbers I can substitute with, can I keep my current climate control, mmi controls and just change out the head unit ??
  18. #98
    Dec 23 2017
    Florida
    Does anyone who performed the 3GP conversion have the optical parking enabled. I had it enabled on my 3g high but whenever I am able to activate (Park Menu Aid in 5f byte 7) the reverse camera image comes on for a second with the optical lines then reverts back to previous MMI screen
  19. #99
    Aug 19 2016
    Incorrect parking module?
  20. #100
    Aug 19 2017
    Arizona
    I have a 2008 as well. Any one done this?
  21. #101
    Feb 08 2013
    2019 Cayman GTS, 2016 Forester XT, 2013 S5, 2011 A4 avanti, 2004 TSX
    Quote Originally Posted by kl918 View Post
    HARDWARE:
    First, I dun think most of us did that will get brand new parts from audi. So most of us just grab from the classified section, so availability is purely based on if anyone post up for sale (most likely someone total their car or able to source from the junk yard). And you dun need to change the climate control, it is just a just to have for matching the color schema and also the new unit has better control layout. And the mmi controls is a bit mix info here. Some say it will work but I did try it myself that the old control didn't work with the new unit. So to be safe you better get the updated MMI control too plus the updated MMI control button layout is more logical then the old one.
    2019 718 Cayman GTS 6MT
    2016 Subaru Dark Grey Forester XT touring
    2013 Audi Phantom Black S5 6MT Sport Diff, 20" BBS CH-R, Navi, B&O, PSS10, AK, EC sway, Alcon BBK, RS grille & Ecode
    2011 Audi Deep Sea Blue A4 Avant prestige, 19" OEM Ti rotors, PSS10, AK, sway, RS style grille + rear spoiler, Votrex diffusor
    2004 Acura Premium White TSX 6MT
  22. #102
    Veteran Member Three Rings Sazexa's Avatar
    Jul 15 2017
    Colorado
    How do I find out which version of the MMI I have? It's a 2009, with aux input. Bluetooth and NAV, but, it is the 2D navigation, and no media playback through bluetooth. I guess 3G-basic?
  23. #103
    Oct 10 2016
    Madrid, Spain
    Quote Originally Posted by Sazexa View Post
    check your current firmware version in MMI and post a pic here...
    Sent from my SM-G935F using Tapatalk
  24. #104
    Active Member One Ring Lord Cavendish's Avatar
    Apr 14 2017
    Spain
    Is this guide suitable for B8.5 MMI 3G low from 2013? I exactly have an A4 allroad 177hp
    Enviado desde mi iPhone utilizando Tapatalk
  25. #105
    Oct 10 2016
    Madrid, Spain
    Quote Originally Posted by Lord Cavendish View Post
    Answer is yes, and coming from a 3G Low you only have to swap the main unit, the screen and eventually the control panel (I believe some don't even bother although some buttons are then wrongly labelled)...
  26. #106
    Mar 03 2014
    north nj
    I actually got everything working. For anyone having problems getting the navigation to work from Midwest keyless, you have to go into the hidden green menu. You have to set the navigation region to English/North America, on the one I got it was set to default and would not work until you change it to North America. it took me a long time but I got it working. I’ll post pictures later. The only thing I’m having problems with is getting the steering wheel controls to work
  27. #107
    Aug 19 2016
    Yes true same issue on mine.
  28. #108
    Mar 03 2014
    north nj
    did anyone figure out how to get the steering wheel controls to work??
  29. #109
    Active Member One Ring mau5pad's Avatar
    Feb 25 2018
    So I decided to do the MMI swap on my 2012 S4 Prestige, the car is fully loaded. I installed the MMI from a b8.5 S5 and everything worked other then the volume, and i mean every single option that was in there. I take it to the dealer they remove component protection everything stops working other then sound and nav. Like drive select is gone, rear view camera is gone, steering wheel controls are gone the climate control and heated seats will not show up. The guys at the dealer told me all they did was remove the CP but looks like they tried to do something else as well and this is the only dealer that was willing to do the CP for me... Anyone know why this happened and what I can do to fix it ? I asked them to try and fix it and they said that the software adaptation that was required is discontinued. Anything would help!
  30. #110
    Aug 19 2016
    Do you have the logs for vagcom prior to cp removal? If so, copy all coding back to how it was. Sounds like they messed it up.
  31. #111
    May 11 2016
    CA
    Guys, CP removal Adaptation by dealer puts the unit in to factory virgin state. If you have Rosstech cable, check options in long coding section for 5F, Steering, Gateway and Convenience modules. All settings are there in diff bytes and need to be turned on.
  32. #112
    Feb 25 2018
    I dont have the old coding from the new MMI unit but i can get the coding from the original unit from the car will that work ? Also I did put in the old one back in and they got that one to work again, will me putting in the new MMI now that it has the CP removed work or will it say that the component protection is enabled?
  33. #113
    May 11 2016
    CA
    Yeah old coding will work, if its mmi unit, gateway, radio, DIS and climate set with CP removed it will work. If any component is swapped whole system goes in CP again and requires dealer visit again.
  34. #114
    Aug 19 2017
    Arizona
    I have a 2008 S5. B&O system. I think I have a 2G high. How do I get to 3G+? There seem to be threads that go on for days and days. Anything concise? Anyone in Arizona do this?
    TIA!
    https://www.dropbox.com/s/2m76kkle3v5pswg/MMI.jpg?dl=0
  35. #115
    Dec 06 2016
    Florida
    I purchased a new unit from Midwest Keyless on ebay and went through with the install. Had my local stealership remove CP and now the unit works perfect. With one caveat. When I shut the car for a short period (getting gas, running into the store, etc.) and come back the audio drops out every 10 seconds or so. Once I give the radio the three finger reset it works perfectly. So the issue seems to occur when coming out of sleep. Does anybody have any recommendations?
  36. #116
    Established Member Two Rings Carbonfiber2gsx's Avatar
    Aug 15 2016
    1999 Mitsubishi eclipse GSX
    Saint Joseph MO
    I'm having this same issue
  37. #117
    Aug 15 2016
    Saint Joseph MO
    Okay so my car won't from non 3g to 3g+ and I'm having random shutting off issues the MMI unit seems to go black completely and only come back on when I shut car off and reboot etc also I'm stuck in intializing nav and media doesn't work either only radio also I'm having conflicting issues with my gateway I used to have lane assist and apparently this gateway doesn't have it or it's not letting me enable it help please
  38. #118
    Established Member Two Rings sly9's Avatar
    Sep 29 2015
    Columbus,OH
    I have a 2010 A5, so I believe I have same MMI system that you has before. MMI 3G?
    2010 Audi A5 2.0T Premium Plus Ibis White
    APR Stage II | APR Downpipe | H&R Street Performance Coilover
  39. #119
    Aug 19 2016
    Quote Originally Posted by Carbonfiber2gsx View Post
    That sounds like the gateway issue. You need what’s called the extended can bus which governs blind spot assist, memory seats, lane assist, and adaptive cruise control.
    There is a correct list of can bus let me see if I can find it for you.
    This has the pre facelift cars for correct can bus and the facelift model 2013+
    Please reference your part with the list below under the hardware category. Once you know if you have the extended can bus. That will eliminate a couple of questions and we can go from there.
    You need a yes & yes for both the most and the extended can. Please make sure your part number says yes and yes and if it doesn’t we have at least diagnosed one problem for sure.
    Thanks and keeps me posted.
    Paul
    Part no | Software | Hardware | Hardware-type | MOST | Extended CAN
    8T0 907 468 D | 0084 | 8T0 907 468 D | H04 | NO | NO
    8T0 907 468 E | 0084 | 8T0 907 468 E | H04 | NO | YES
    8T0 907 468 F | 0083 | 8T0 907 468 F | H07 | YES | NO
    8T0 907 468 G | 0084 | 8T0 907 468 G | H08 | YES | YES
    8T0 907 468 H | 0091 | 8T0 907 468 H | H06 | NO | NO
    8T0 907 468 J | 0091 | 8T0 907 468 J | H06 | NO | YES
    8T0 907 468 K | 0092 | 8T0 907 468 K | H09 | YES | NO
    8T0 907 468 L | 0092 | 8T0 907 468 L | H10 | YES | YES
    8T0 907 468 M | 0095 | 8T0 907 468 H | H06 | NO | NO
    8T0 907 468 N | 0095 | 8T0 907 468 J | H06 | NO | YES
    8T0 907 468 P | 0095 | 8T0 907 468 K | H09 | YES | NO
    8T0 907 468 Q | 0095 | 8T0 907 468 L | H10 | YES | YES
    8T0 907 468 R | 0101 | 8T0 907 468 H | H06 | NO | NO
    8T0 907 468 S | 0105 | 8T0 907 468 J | H06 | NO | YES
    8T0 907 468 T | 0101 | 8T0 907 468 K | H09 | YES | NO
    8T0 907 468 AA | 0105 | 8T0 907 468 L | H10 | YES | YES
    8T0 907 468 AB | 0117 | 8T0 907 468 H | H06 | NO | NO
    8T0 907 468 AC | 0117 | 8T0 907 468 J | H06 | NO | YES
    8T0 907 468 AD | 0117 | 8T0 907 468 K | H09 | YES | NO
    8T0 907 468 AE | 0117 | 8T0 907 468 L | H10 | YES | YES
    8T0 907 468 AF | 0120 | 8T0 907 468 H | H06 | NO | NO
    8T0 907 468 AG | 0120 | 8T0 907 468 J | H06 | NO | YES
    8T0 907 468 AH | 0120 | 8T0 907 468 K | H09 | YES | NO
    8T0 907 468 AJ | 0120 | 8T0 907 468 L | H10 | YES | YES
    B8.5 2012-2015
    8R0 907 468 A | 0025 | 8R0 907 468 A | H10 | NO | NO
    8R0 907 468 B | 0025 | 8R0 907 468 B | H10 | NO | YES
    8R0 907 468 C | 0025 | 8R0 907 468 C | H10 | YES | NO
    8R0 907 468 D | 0025 | 8R0 907 468 D | H10 | YES | YES
    8R0 907 468 F | 0051 | 8R0 907 468 A | H11 | NO | NO
    8R0 907 468 G | 0051 | 8R0 907 468 B | H11 | NO | YES
    8R0 907 468 H | 0051 | 8R0 907 468 C | H11 | YES | NO
    8R0 907 468 J | 0051 | 8R0 907 468 D | H11 | YES | YES
    8R0 907 468 L | 0055 | 8R0 907 468 A | H11 | NO | NO
    8R0 907 468 M | 0055 | 8R0 907 468 B | H11 | NO | YES
    8R0 907 468 N | 0055 | 8R0 907 468 C | H11 | YES | NO
    8R0 907 468 P | 0055 | 8R0 907 468 D | H11 | YES | YES
  40. #120
    Aug 19 2016
    Quote Originally Posted by banditti View Post
    TIA!
    It does look long but it’s actually straight forward.
    I can get you the entire system if you like. Let me know. Wiring and all.
